Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Gold Member
    Join Date
    Oct 2010
    Posts
    313
    Sabetha, KS
    Kubota BX25D
    Default Adapting a JD series 600/700 quick tach loader bucket to a JD146 loader?
    Could someone give me some ideas to attach a JD 600/700 series bucket to a JD 146 loader? I think either need to cut/weld/modify brackets on the bucket to fit the attachment on the loader or somehow add a quick attach bracket to the loader to fit the bucket.
    Any recommendations would be welcome and thanks in advance.
  2. #2
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,926
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Default Re: Adapting a JD series 600/700 quick tach loader bucket to a JD146 loader?
    I am unfamiliar with those loaders...can you post some pictures?
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  3. #3
    Gold Member
    Join Date
    Oct 2010
    Posts
    313
    Sabetha, KS
    Kubota BX25D
    I'm pretty slow at getting the pictures you requested, but I had some time while I was driving by the farm and took a few quick ones:
    Pictures in order:
    1) JD 2440 Tractor
    2) JD 146 Loader Front View
    3) JD 146 Loader Side View
    4) JD 600/700 Series quick tach bucket
    5) JD 600/700 Series quick tach bucket closeup
    Note: I have no idea why the parts were cut out of the bucket quick tach bracket. The price was right and we knew we were going to have to make something to get this bucket on the 146 loader.
    Attached Thumbnails Attached Thumbnails Adapting a JD series 600/700 quick tach loader bucket to a JD146 loader?-jd2440-146loader-jpg   Adapting a JD series 600/700 quick tach loader bucket to a JD146 loader?-146loaderfront-jpg   Adapting a JD series 600/700 quick tach loader bucket to a JD146 loader?-146loadersize-jpg   Adapting a JD series 600/700 quick tach loader bucket to a JD146 loader?-600-700bucketcenter-jpg   Adapting a JD series 600/700 quick tach loader bucket to a JD146 loader?-600-700bucketleft-jpg
  4. #4
    Gold Member
    Join Date
    Oct 2010
    Posts
    313
    Sabetha, KS
    Kubota BX25D
    One thing you may or not be able to tell from the picture is that the cylinder is leaking on the loader right side (or left side in the picture).
    I have to figure out how to rebuild the cylinder or reseal it.
    The oil on the floor is from a messy oil change on a truck.
  5. #5
    Join Date
    Jul 2003
    Posts
    12,926
    Westminster, MD
    Good pictures Jeff, that helps a lot
    As far as the cylinder-they are easy to rebuilt, but do both of them at the same time.
    I assume you want to convert your loader to accept the new QA bucket, then convert your spear to QA? Do you want to change to the JD propietary or move to the standardized SSQA (skid steer)
    This company have some stuff:
    Skid steer hitch adapters any skidsteer tractor loader conversion
    Not exactly what you need though-but close.
    On other option is to fabricate the loader side "holder" , like #10 in the picture. They are $435 each in JDParts!
    Bottom line is this: How much do you want to spend and/or how much fabrication can you do?
    My vote would be to convert to SSQA.
    Attached Thumbnails Attached Thumbnails Adapting a JD series 600/700 quick tach loader bucket to a JD146 loader?-620-gif
    KennyD
    www.boltonhooks.com
  6. #6
    Gold Member
    Join Date
    Oct 2010
    Posts
    313
    Sabetha, KS
    Kubota BX25D
    Quote Originally Posted by kennyd View Post
    Thanks for the tip.
    I would like to make the loader hook up to the bucket without modifiying the loader. Whether the bucket gets modified or there is some sort of adapter that can go onto the loader to attach to the bucket (for a reasonable price) is probably what we'll do.
    The hayspear is probably going to set in the back of the barn unless something arises that can't be accomplished with the bucket.
    The tractor is mainly going to be a snow/rock/dirt scooper depending on the season. It will be doing a little bit of shredding too.
    P.S. Where is the best location to weld chain hooks on the bucket? I was thinking one on each side at the top 1/3 of the distance in from the side.
  7. #7
    Join Date
    Jul 2003
    Posts
    12,926
    Westminster, MD
    Quote Originally Posted by jjsjeff View Post
    Inline with the cylinder is best. Also one in the center is OK if used carefully.
    KennyD
    www.boltonhooks.com
  8. #8
    Join Date
    Jul 2003
    Posts
    12,926
    Westminster, MD
    OK Jeff,
    I think I have it figured out for you-you will still need to add the proper sized and spaced bushing to the rear of this-but that should be easy if you can do basic welding/fabrication: SSQA to JD 600/700 Adapter
    Then you could get one of these for your spear: Latch Box Set
    I just don't see how you could do this cheaper and have a QA setup.
    Note that since these will move the bucket out away from the pins some,and the added weight of the adapter that lift capacity will be reduced some.
    KennyD
    www.boltonhooks.com
  9. #9
    Gold Member
    Join Date
    Oct 2010
    Posts
    313
    Sabetha, KS
    Kubota BX25D
    That adapter looks like it would work for what I'm talking about.
  10. #10
    Join Date
    Jun 2010
    Posts
    701
    north Mississippi
    NH 3040
    you might look at Hay Farm Equipment | Skidsteer Attachments | Hay Spear Attachments they have a lot of the quick attach components and even mention your loader.
    NH 3040 fel 6' cutter
    JD 737 zero turn
    polaris ranger xp
    99 honda 300
    Trek Emonda SL8.
Similar Threads
  1. quick tach plates on 00 series and incompatible attachments
    By Tim_in_IA in forum Mahindra Owning/Operating
    Last Post: 05-08-2007, 07:07 AM
  2. Price Check JD 4x20 Series Pricing and Comments
    By boatermark in forum John Deere Buying/Pricing
    Last Post: 03-31-2007, 03:52 PM
  3. weight and capacity of loader bucket
    By radman1 in forum John Deere Owning/Operating
    Last Post: 08-28-2006, 08:29 PM
  4. question: loader / bucket sizeB series Kubota
    By moosetracks in forum Kubota Buying/Pricing
    Last Post: 08-23-2004, 10:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
