Results 1 to 4 of 4
  1. #1
    New Member dsails380's Avatar
    Join Date
    Oct 2010
    Posts
    21
    Pennsylvania
    MF GC2410
    Default Aerator Conversion to 3 pt Hitch
    This is a pull behind Agri Fab plug aerator that I modified to 3 pt hitch. I became tired of operating the lever arm to raise and lower the wheels to clear the driveway and sidewalks - especially with four 100lb cement blocks on board (we have poor soil here in PA). Not to mention the force on the lever arm is a accident waiting to happen with this much weight. I used 1/4"x3"x4" angle that I had laying around to put a frame under the aerator and attach the 3 pt lift arm pins. For the mast, I had some 1-1/2x3" box channel from an old trailer I cut apart. This implement is a breeze to use, now. I move the 100lb cement blocks from the ballast box to the aerator with a chain and the FEL (each block has a lifting eye - see my ballast box post). Instead of wrestling with the lever arm on the aerator, I now use the 3 pt hitch to raise and lower the entire aerator as needed. This will really save my back, and hope this idea can help you too.
    Attached Thumbnails Attached Thumbnails Aerator Conversion to 3 pt Hitch-aerator-outside-3-jpg   Aerator Conversion to 3 pt Hitch-aerator-outside-4-jpg   Aerator Conversion to 3 pt Hitch-aerator-outside-6-jpg
  2. #2
    Gold Member
    Join Date
    Apr 2007
    Posts
    325
    Minnesota
    '07 Kubota BX2350
    Default Re: Aerator Conversion to 3 pt Hitch
    How well do you think this one follows the contour of the land as compared to when it was a tow behind? I've considered doing the same for all the reasons you mentioned but can't seem to convince myself of this one issue.
    '07 BX2350, FEL w/ toothbar, 60" MMM, 5' KK back blade, BX2750C front snowblower, 42" home built disc, carry all
  3. #3
    Elite Member bigtiller's Avatar
    Join Date
    Feb 2006
    Posts
    3,551
    central Iowa
    JD 2720
    I like it! I have been threatening my aerator with the conversion for a long time.
    HAVE FUN
    Life is easier when you plow around the stumps.
    2720
  4. #4
    Join Date
    Oct 2010
    Posts
    21
    Pennsylvania
    MF GC2410
    Thanks Bigtiller. Go for it - the conversion took one weekend to drill, weld and paint. I now use the draw bar from the aerator for the MTD chipper that I now tow behind. What a pain it was dragging that thing around the property by hand.
    Fish 6943 - I leave the 3 pt hitch control lever in the down position so the aerator can float over the countour of the land. The wheels act as my draft control, same as tow behind. I have a hilly lawn, and it follows the contour nicely. One thing to watch though, are turns. Since the aerator is now essentially a part of the tractor, trying to turn with it engaging the ground will place a lot of stress on the 3pt hitch and aerator. So, I only aerate in relatively straight lines. It works like a charm and I can honestly say, it's a pleasure to aerate instead of a chore.
Similar Threads
  1. 3-Point Hitch 3 PT hitch keeps dropping
    By ScottyChip in forum Kubota Owning/Operating
    Last Post: 06-20-2011, 05:20 PM
  2. 3 pt. drawbar hitch question
    By Beervangelist in forum General Vintage Tractors
    Last Post: 10-29-2010, 10:15 PM
  3. 3-Point Hitch 3 pt trailer hitch
    By Bamacummins in forum Kubota Owning/Operating
    Last Post: 04-23-2010, 11:19 PM
  4. 3 Pt. Hitch Slow to Start Lifting On CT235
    By Skinnyman in forum Bobcat Tractors
    Last Post: 04-19-2010, 09:33 AM
  5. 3 PT hitch receiver hitch
    By Ira in forum John Deere Buying/Pricing
    Last Post: 09-08-2007, 09:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
