Modify rear blade to front blade and back?
   / Modify rear blade to front blade and back? #1
corey9212
Red Deer County, AB
2015 John Deere 3046R
Hello I have a BX2660 with a FEL and rear blade and am wandering if it's possible to mod the rear blade so it can attach to the FEL to use as a front blade for the winter and then put it back onto the 3 point for summer driveway maintenance, the reason I ask is cause of money being tight right now to go out and buy a new front blade to attach to the FEL so I figure it might be cheaper to make a conversion. Any help and advice on this would be appreciated.
Thanks in advance.
Corey
   / Modify rear blade to front blade and back? #2
I thought of this several times myself. I think I remember seeing some kind of front 3 point mount that would work for many implements.
   / Modify rear blade to front blade and back? #3
I've thought the same thing. I plan to modify a quick hitch to quick tac so I can mount 3pt implements such as a blade and carry-all on the loader arms.
Just gotta find the time and a little cash.
M.D.
   / Modify rear blade to front blade and back? #4
It's doable for sure, the way Mighty Dodge mentioned is the way I would do it.
get a cheap HF QH and mod it to work with JD's Quick attach system.
you don't want to mod the blade, just need an adaptor
Does your Kubota have a quick remove bucket?
I thought of it myself but to this point I have not had a need. I already have a front plow and forks.
3 point to skid steer - Google Search
Google image search shows many, mostly for skid steer type quick attach.
Funny thing I see a contraption I made in that search, it's the JD with the bucket on the back. click the picture it links to TBN and a prev thread on the subject.
JB.
   / Modify rear blade to front blade and back? #5
I'm in the prosess of making one now. I got a quick hitch and a quick attach plate and am ready to weld it together. I just sent a complete setup back today. Nothing was straight on it! Hmmm I'll see if i can get a pic tomorrow.
   / Modify rear blade to front blade and back? #6
You can make yourself a loader-mounted quick hitch like this.
   / Modify rear blade to front blade and back? #7
My only concern would be that it puts it a couple feet out past the end of the loader arms.
   / Modify rear blade to front blade and back? #8
I would be concerned about that also. I am working on a design that would mount on the Q/A on the loader and the 3PH. You could use it on the loader in the winter and the 3PH in the summer. The design eliminates your concerns.
   / Modify rear blade to front blade and back? #9
How? It sounds like the same thing.
How about a front frame mount 3 PH, shouldn't be too diffecult, just the lift and you could maybe use the loader for that?
I don't like the idea of impliments way out in front of the loader either.
JB.
JB.
No the bucket is attached to the loader arms permanently. I do have a quick hitch sitting doing nothing, just have to figure out how to attach it to the bucket in such a way it can be removed.
