J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,928
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
Any other ideas out there?
Clayton
I did the same thing about 5 years ago with my splitter also. Mine is a 3 point splitter that runs off the tractors remotes. The main difference between mine and JJ's is mine has a fixed foot and the wedge moves in a track on the beam and is attached to the ram. I simply made a press piece that goes in place of the wedge.
You just pull the pin on the end of the piston rod, tilt the cylinder up 90 deg, slide the ram out, put the press piece in, drop the cylinder back down and install the pin.
Used it quite a few times.
Chris
Thought some of you might be interested in this setup. Make an adapter to use you splitter as a press.
A log splitter has to have more than just one use, as you have shown us here. Any other ideas out there?
Clayton
...... but it needs a specific shaped adapter to make it work right. Thanks for reminding me of a good winter welding project
Sean
I have the same setup. Could you post a picture of the press piece? How thick is the material?
Thanks.
