Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
  1. #11
    Join Date
    Aug 2006
    Posts
    737
    Buckhannon, WV
    1947 Ford 2N and 2003 Kubota B7500
    Default Re: How do you hang it from you bucket?
    I just welded a couple of grab hooks to the top of my bucket. Of course, mine is reinforced for the grapple mount as well.
    -=Mark=- 03 Kubota B7500, 47 Ford 2N
  2. #12
    Gold Member
    Join Date
    Oct 2007
    Posts
    440
    Levittown & Long Eddy NY
    09 kubota L4400, 4x4, R4's
    welded 3/8" 2x2 angle then the hooks
  3. #13
    Elite Member Baby Grand's Avatar
    Join Date
    Nov 2007
    Posts
    4,583
    Windsor, CT.
    Kubotas: L3240GST B2320HST B5100D & G5200H
    Quote Originally Posted by moored4 View Post
    Ok! I've got to make me a tooth bar, I'm in the process of making a brush rake for my bucket now (buying materials) and think I'll modify it so they will inter-change.
    Baby Grand; in the 3rd and 4th picture you have a red connector, I've never seen one like that before, what's it called and where you get?
    It's called a grab link and I got mine at Bailey's, but Northern has them too:
    http://www.baileysonline.com/itemdetail.asp?item=17938
    Chain Saddle Grab Link | Electric Chain Hoists | Northern Tool + Equipment
    Very handy item to keep around.
    That's the problem with trouble.
    It always starts out as such fun."
    - Randall Brown
  4. #14
    Bronze Member massy1635's Avatar
    Join Date
    Apr 2010
    Posts
    63
    Central Maine
    Massey Ferguson 1635 with a factory cab and HEAT
    I welded a full length piece of 3" channel iron across the top edge of my bucket then welded three weld-on 3/8 grab hooks to the channel iron. One in the middle and the other two 6" in fron each end. I would suggest that you reinforce the top edge of your bucket and remove the bucket from the tractor before welding.
    There is no $50 job I can't do without $100 worth of new tools.
  5. #15
    Gold Member Sandlot's Avatar
    Join Date
    Aug 2006
    Posts
    281
    CA. High Desert
    Kioti CK20(Gear)
    These are my bucket hooks that I added.
    Attached Images Attached Images
    Kioti, CK20(Gear), Loader, Backhoe, Box Scraper, and Post Hole Digger.
  6. #16
    Join Date
    Dec 2009
    Posts
    113
    cataract wi
    2003 New Holland tc 29d
    I put both grap hook and slip hook on, facing grab hooks in opposite directions so I can hook in front of the bucket or behind. Also put a set on both ends of bucket.
    Attached Thumbnails Attached Thumbnails How do you hang it from you bucket?-grapple-005-jpg
  7. #17
    Join Date
    Aug 2006
    Posts
    737
    Buckhannon, WV
    Quote Originally Posted by massy1635 View Post
    Why remove the bucket?
  8. #18
    Gold Member Casco1's Avatar
    Join Date
    Aug 2004
    Posts
    424
    New England
    Kubota L series
    I've been using this for about ten years now and would have the same setup on a new tractor tomorrow.
    I have three slip hooks two on the ends and one in the middle.
    Two grab hooks in between. This allows me numerous combinations of chain setups to lift and move rocks, roots, trees etc. I also have a 2" receiver mounted top/center I use this to move my trailers around, with the front wheels so close to the hitch I can move and turn my trailers on a dime. It's a lot but over the years I've used them all.
  9. #19
    Veteran Member K7LN's Avatar
    Join Date
    Feb 2009
    Posts
    1,796
    Michigan
    JD455 & JD790
    Quote Originally Posted by wvpolekat View Post
    With the currents and voltages involved in arc welding, it could induce some damaging currents or voltages into delicate electronics. Even with everything grounded, 100-200 amps could easily damage a CMOS device that will pop just from static.
    JD 790 w/70 FEL & 7 BH on turf tires
    JD 455 w/60" MMM & 54" front blade
  10. #20
    Join Date
    Aug 2006
    Posts
    737
    Buckhannon, WV
    Quote Originally Posted by K7LN View Post
    I have heard rumors of such, but never seen it happen and have seen and done welding done plenty of times on things with way more electronics than a tractor. Muffler shops weld mufflers on all day long without incident. Body shops weld on cars all the time without incident. I assure you they are not removing the electronics prior to doing it.
    You aren't passing the welding current through everything in the vehicle. Only from where you are welding to your ground clamp. And, you pass that many amps through the chassis every time you start it. Path of least resistance and all that.
    As far as I am concerned it's a wive's tale, but I am sure I will get plenty of replies from people who had it happen to their sisters cousins uncle or something.
Similar Threads
  1. 2cuyd Leaf bucket for scut - it works!
    By RedDirt in forum Build-It Yourself
    Last Post: 01-04-2011, 05:22 PM
  2. welding chain links on bucket and loader arms
    By stevef in forum Attachments
    Last Post: 01-19-2010, 07:46 AM
  3. Bucket suggestions for a LA481
    By boxr_fan in forum Kubota Owning/Operating
    Last Post: 09-21-2009, 04:26 PM
  4. hooks for my bucket
    By jmt1271 in forum Projects
    Last Post: 09-02-2006, 04:09 PM
  5. 3130 Bucket Options
    By DaNag in forum Attachments
    Last Post: 11-27-2004, 05:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
