Piston
Elite Member
Hey guys,
I had some Basspro gift cards that were sitting around collecting dust and decided to use them on an electric winch for my log arch. I built the log arch last year and it has come in handy for the most part, the only mistake I made was buying a cheapo winch from Northern Tool. It broke the first time I used it. Since then, I have used a cumalong which really isn't all that convenient, so I decided to upgrade to ultimate laziness. :laughing:
I bought the Superwinch Terra 4500 ATV Winch from Basspro for 37 dollars after gift cards and coupon code. It comes with wiring for a permanent mount installation but I would like to make it portable.
I will weld a piece of square tubing to the top of my log arch that will accept the 2" winch mount hitch I am getting for it. I want to be able to slide it from the log arch, to my truck hitch, and back, fairly easy. My truck already has a 7 pin connector on it.
Is it possible to wire up a 7 pin connector to the winch? Or is that easiest way? If so, can I easily wire a 7 pin female end to my tractor?
Do you have any better ideas that you could suggest to me?
I'm only saying the 7 pin connector because that is what's already there, but if there is a better way to do it then I'm all ears.
The tractor is an L4610 if that matters. I'll post a pic of the log arch.
