Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Mar 2011
    Posts
    2
    John Deere 5020
    Default 9400/5020
    Does anyone know if a flywheel from a 9400 [12.5L] will bolt up to a 532/619ci engine crank ?
  2. #2
    Join Date
    Dec 2010
    Posts
    505
    Default Re: 9400/5020
    Crow,
    Apparently you are new to Deere. Accurate information is nearly impossible without:
    1) tractor serial numbers
    2) engine serial numbers
    3) any part numbers on the castings
    I'm showing 4 different flywheels for the 5020. Please explain your problem.
  3. #3
    New Member
    Join Date
    Mar 2011
    Posts
    2
    John Deere 5020
    I think you are the one who is new to Deere because a flywheel from a 1968 5020 will fit a 6030, 8630, 8640, 8650 [all big blocks] and as far as my problem, read my first post again.
  4. #4
    Join Date
    Dec 2010
    Posts
    505
    Seems like you've got it all figured out. Good luck with your problem.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
