Results 21 to 24 of 24
03-28-2011, 11:10 AM #21
Re: 3pt quick hitch (iMatch) ideas
On the iMatch the top hook is fixed and the bottom of the hook is flush with the underside of the top crossbar. For instance your pic shows a drop hitch where the drop bar extends above the receiver tube. Also the receiver hitch tube itself has a typical double wall end. These would have clearance issues with the iMatch top hook if mounted directly underneath.
With the receiver tube on top it's perfect for moving a gooseneck trailer. You could build a long drop hitch to yard move a standard tongue trailer..
Darrell
JD2320, 200CX, 53" Bucket, 54" QH SnowBlower, iMatch, Ballast Box, LR1072, RC2048, GM3060, 647 Tiller, SS1023B
03-28-2011, 12:43 PM #22
JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 48", 61"HD & 73" high volume bucket.
FORD 1700; 2 WD, 2600 hrs.
JD 320; Hydra lift, 48" deck and 48" snow blade.
2007 Dodge Ram 3500, Cummins 6.7L, Aisin 6 speed, 9ft utility body.
03-31-2011, 02:36 PM #23
Well I copied most of your ideas, even the top receiver and the side boxes
The lower center mount receiver is now not only handy, but I already consider it a necessity, as I used it twice yesterday.
I will start another thread so I don't hijack yours anymore, but will give you credit for the idea.
Also for the boxes on the side I used 4x4 cause that's what I had, but that size is limited to just 9-10 ft of 3/8 chain. I wanted to use 4x6 but could not find it. I just tacked these on so when I find some light 4x6 I'll put that on.
With 4x6 you could put a sledge hammer or an axe and much more chain etc.
JB.JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 48", 61"HD & 73" high volume bucket.
03-31-2011, 02:47 PM #24
Similar Threads
Anyone put Kubota's front quick hitch on their new B yet??
By RRbota in forum Kubota Owning/OperatingReplies: 30Last Post: 08-26-2015, 09:51 PM -
Loader Mounted Quick Hitch
By Runner in forum Build-It YourselfReplies: 21Last Post: 07-23-2011, 04:57 PM -
2520 Front Quick Hitch
By revitupfaster in forum John Deere Owning/OperatingReplies: 0Last Post: 09-28-2010, 06:03 PM -
3-Point Hitch 3PT Quick Hitch
By YM2310JC in forum YanmarReplies: 13Last Post: 09-15-2008, 03:39 PM -
2520 62D and Quick Hitch Compatibility Issue?
By Holiday in forum John Deere Owning/OperatingReplies: 0Last Post: 04-12-2006, 10:52 PM
