Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Elite Member SSdoxie's Avatar
    Join Date
    Jun 2010
    Posts
    2,508
    Cumberland Plateau, TN
    Bobcat CT225
    Default Post hole digger to Quick Hitch?
    Has anyone out there modified the boom on a Post hole digger to hook up to a 3 point quick hitch. I have all my attachments set up no to use off the QH except have to remove it for the PHD. If anyone has done it and has pics would be greatly appreciated.
  2. #2
    Gold Member XSKIER's Avatar
    Join Date
    Apr 2011
    Posts
    450
    Fenton, MI
    '11 Deere 1026R
    Default
    Take a closer look at the geometry of the post hole digger. When attached to the quick hitch, you would have very limited working lift range. It would be easy to hook up and would look nice on there, but the functionality would suffer.
  3. #3
    Join Date
    Jun 2010
    Posts
    2,508
    Bobcat CT225
    Default Re: Post hole digger to Quick Hitch?
    I think I can overcome the geometry with hydrualic top link, but I hit my first road block today. The A frame won't fit the Quick Attach, needs to be 1/2" wider on each side or 1 1/2" narrower.
  4. #4
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    Please post pictures of your modification; but I agree with Xskier concerning the geometry being all wrong.
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  5. #5
    Gold Member
    Join Date
    Feb 2011
    Posts
    405
    princeton nc.
    JD 2320
    Quote Originally Posted by XSKIER View Post
    I was thinking it would work if you took the top link off the tractor and took the A-frame off the PHD then you use the QH as the A-Frame for the PHD.
  6. #6
    Join Date
    Dec 2000
    Posts
    966
    Tescott, Kansas
    Kubota M6040/cab
    I tryed that a few years ago the geometry changed to much from up to down position.
    Kubotam6040,cab,Hyd top link, Kubota RTV 900 Camo. 04 Dodge/cummins-6 speed with extras
  7. #7
    Join Date
    Jun 2010
    Posts
    2,508
    Bobcat CT225
    I decided to bring this thread back to life now that I've had a couple days to get started on the Post Hole digger mount to QH mode. For all those that advised me of the geometry problem, Thank You. It will not work without using Hydraulic Top Link. On mine I would loose about 18" of travel without moving the top link.
    First came the top link, I did this a few months ago. I modified a short grapple cylinder that I had laying around, used a rod eye end from an extra top link cut it to link and weld to base of the cylinder to same length as original top link.
    Then the PHD: Relocted the lower lift pins to clear the lock taps on QH, moved them forward and slightly down.
    Cut the PHD tube off same length as top link fully retracted. Then notched out bottom of the tube for QH hook to slide in.
    The bar stock added on top is (3) 1/4" pieces to match width of the hook. They help pull the digger up tight and reduce side movement of the gear box when under torque.
    To mount it: Drop the lift pins in lower hooks, raise end of PHD boom to slide pin through the hook, the raise little more and slide smaller hitch pin in.
    Getting alot of pics here so will start another reply showing the movement.
    Attached Thumbnails Attached Thumbnails Post hole digger to Quick Hitch?-top-link-made-grapple-cyl   Post hole digger to Quick Hitch?-relocate-lift-pins-frame-clearanc   Post hole digger to Quick Hitch?-inside-auger-frame-brace-interference   Post hole digger to Quick Hitch?-notch-auger-tube-qh-hook   Post hole digger to Quick Hitch?-frame-ready-hook-up-jpg
    Post hole digger to Quick Hitch?-set-auger-lower-lift-points   Post hole digger to Quick Hitch?-raise-rear-auger-frame-slide   Post hole digger to Quick Hitch?-auger-frame-locked-jpg
    Dennis
    CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
  8. #8
    Join Date
    Jun 2010
    Posts
    2,508
    Bobcat CT225
    1st pic is with 3pt down and top link retracted, end of boom 22" off ground.
    2nd is with top link extended part way, boom hits the ground.
    3rd & 4th pics are at fully raised top link retracted = 6'. Gear box with auger are 4'8" so I should have plenty of height.
    If weather holds tomorrow I will get neighbor to help hang gear box and auger back on, stress test my welding and maybe shoot a little video.
    Attached Thumbnails Attached Thumbnails Post hole digger to Quick Hitch?-3pt-lowered-top-link-retracted   Post hole digger to Quick Hitch?-3pt-lowered-top-link-extended   Post hole digger to Quick Hitch?-full-lift-jpg   Post hole digger to Quick Hitch?-full-lift-height-top-link
    Dennis
  9. #9
    Join Date
    Dec 2000
    Posts
    966
    Tescott, Kansas
    Kubota M6040/cab
    Good luck SSdoxie... Let us know the out come
  10. #10
    Platinum Member catdozer's Avatar
    Join Date
    Sep 2011
    Posts
    508
    Indiana
    Bobcat CT235
    Default
    Well have you used it? Did it work good?
    Bobcat CT235 with Deere Imatch, And a very bad addiction of attachments
Similar Threads
  1. Post hole digger vs. mini hoe
    By TimOb in forum Power Trac
    Last Post: 05-02-2006, 05:29 PM
  2. What Post Hole Digger Should I Buy?
    By GreenAcres in forum New Holland Buying/Pricing
    Last Post: 08-25-2004, 10:28 AM
  3. Posthole Digger Post Hole Digger Questions
    By rmonio in forum Attachments
    Last Post: 07-27-2004, 03:13 PM
  4. Posthole Digger Post Hole Digger
    By Anonymous Poster in forum Attachments
    Last Post: 03-25-2003, 07:44 PM
  5. Posthole Digger Pricing a post hole digger
    By GlennT in forum Attachments
    Last Post: 12-10-2002, 12:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
