Results 1 to 5 of 5
05-14-2011, 08:32 PM #1Elite Member
- Join Date
- Feb 2011
- Posts
- 3,439
- Location
- Tucson AZ
- Tractor
- New Holland TC-45
"T" Hooks & Bucket Hooks
Before getting into the hooks. No one should ever get under a load in the air. It makes no difference how it is being held or what is holding it. NUFF Said.
Almost every one with a front end loader needs hooks on the bucket. I like grab hooks, but many like slip hooks. Weld on or bolt on? The good thing about bolt on is they can be changed or taken off. With no desire to remove mine, they got welded.
"T" hooks can be very handy, quick to install or remove. Mine are used when something can't be reached with the FEL. The back hoe will reach out about 10' and swing from side to side. The "T" hooks and the back hoe reaching out are not for a heavy load. Maybe around 400 to 500 Lbs.
A simple Keyhole slot has been cut in both sides of my BH bucket. The keyhole could be cut into the ends of your loader bucket. In seconds you can slip in the "T" hooks, once your done lifting they come right back out.
I haven't been able to find any "T"s with the grab hook on them, so you may have to put your own on. Or work with the loop that most come with.
A side note, the hooks on my bucket were forged from RR spikes. The spike metal is a little better than mild steel. I have forged a few more hooks from the RR spikes, they are strong enough that I have broken 1 chain and 2 cables with them. OK crappy chain
But one of the cables was a guy wire cable used on power poles.
::"I STARTED out with nothing....I still have most of it."
New Holland TC45 1,300+ hours - FEL - back hoe - post hole digger - Hydraulic Gannon - cement mixer - pressure washer - 1975 Dodge 500 flat bed - 1974 chevy C65 6 yard dump truck.
All home made by me. loading forks - 2 drags - roller - Sheep's Foot - Pusher (to unload flat bed truck.) - pickle fork digger - Log splitter -
05-15-2011, 10:30 AM #2
Re: "T" Hooks & Bucket Hooks
Interesting idea. I have a bunch of T hooks hanging around, since I used to be in the towing industry. I've never given any thought to using them in a tractor application, but I can see where it would be a good option in certain applications.
05-15-2011, 12:54 PM #3
I have been holding out from having some hooks welded on because I am uncertain wich way they would be more useful and by there positioning, If I would use a chain from the backside of the bucket? or the front side. the hook would have to be welded in one way or the other
having some of these T-hooks would resolve the issue of me not knowing where or how to posistion hooks on the bucket or welding on the hooks
I could simply cut some key-holes and drop the T's in and only use when I need them.....
hey! want to trade for some old rusty hooks I cannot figure any use for?
05-15-2011, 08:29 PM #4Elite Member
- Join Date
- Feb 2011
- Posts
- 3,439
- Location
- Tucson AZ
- Tractor
- New Holland TC-45
[QUOTE=deepNdirt
[/QUOTE]
Hi Deep
One good thing is if you get it wrong. just weld up the holes and start over.
You have a couple of grab hokes there, look like different sizes in the picture. You will need them if you have to buy "T" hooks. It appears that they no longer can be had with a hook on them.
Just send them 2 me, I never have enough hooks.
05-16-2011, 01:13 PM #5Silver Member
- Join Date
- Aug 2006
- Posts
- 120
- Location
- Hard by the Elk Fork of the Salt River, Missouri
- Tractor
- 2009 Mahindra 4110
I have three chain hooks on my FEL. One on each side and one in the middle. I can usually catch two on a lift whick hopefully spreads the load.
Mahindra 4110, FEL, Sun Screen, Bush Hog 84RDTH Finishing Mower, Howse 5 ft. brush hog, Yanmara 5 ft. tiller, PHD; Box Blade; 3pt. forks, Cub Cadet LT 1050, Polaris Sportsman 500, Beretta 92FS, Taurus Judge. And a new Subaru Outback 2.51i CVT. Retired on 9/30/2011!
Similar Threads
JD 3032E brush guard and bucket hooks
By picker77 in forum Build-It YourselfReplies: 16Last Post: 09-26-2012, 08:06 AM -
Bucket Hook(s) Placement
By Snapper Head in forum CustomizationReplies: 33Last Post: 12-09-2010, 08:42 PM -
Bucket Hooks Revisited (Again!)
By Dascro in forum Kubota Owning/OperatingReplies: 15Last Post: 07-09-2007, 10:23 PM -
weight and capacity of loader bucket
By radman1 in forum John Deere Owning/OperatingReplies: 9Last Post: 08-28-2006, 07:29 PM -
BX 22 Bucket Hooks
By bmac in forum Kubota Owning/OperatingReplies: 38Last Post: 02-18-2004, 11:44 AM
