flusher
Super Member
- Joined
- Jun 4, 2005
- Messages
- 7,538
- Location
- Sacramento
- Tractor
- Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
I don't like working under my 6-ft Hawkline mower so I rigged up an access panel for blade sharpening and removal.
Layed out the pattern. Drilled 1/2" holes in the corners for stress relief.
Cut the 1/8" sheet metal (it's non-structural) with my 4-1/2" angle grinder.
Drilled some scrap steel angle for 5/16" hex bolts (slip fit).
Welded it up.
Now all I have to do is use a 4x4 and a 2x4 wedge under the blade to keep it fixed when sharpening with the angle grinder. And the large hex bolt that attaches the blade to the stump jumper is a lot easier to access for replacement.
Welded it up.
