Results 1 to 4 of 4
  1. #1
    Gold Member HarleyScooter's Avatar
    Join Date
    Jun 2004
    Posts
    265
    Canton, Ohio
    Kubota/ BX2230
    Default I added a Warn ATV winch to the BX
    I had a Warn 2500 lb winch on the ATV and I never used it. So I added a 2" square tube and some gussets to the mounting plate and a extra mounting plate for the relay and remote switch connector. Now it is all in a small unit with the only connections needed are the 12 volt power and the remote plug. I used 120 amp connectors for the 12 volt power leads, I bought those from Granger.
    Attached Thumbnails Attached Thumbnails I added a Warn ATV winch to the BX-winch-5.jpg   I added a Warn ATV winch to the BX-winch-1.jpg   I added a Warn ATV winch to the BX-winch-2.jpg   I added a Warn ATV winch to the BX-winch-3.jpg
  2. #2
    Gold Member
    Join Date
    Jul 2002
    Posts
    442
    Northeast Ohio
    GC 2310
    Default Re: I added a Warn ATV winch to the BX
    This looks like it was made for the tracktor Very nice
  3. #3
    Join Date
    Jun 2004
    Posts
    265
    Canton, Ohio
    Kubota/ BX2230
    Thanks Doug, the winch will fit on my little log skidding setup. on the boom pole, and on the counter weight I made for the three point. I have plans to dig out the small pond my daughter has in her back yard, I thought I could use the winch if (when) I get stuck doing that.
  4. #4
    Join Date
    Aug 2005
    Posts
    1,020
    Guernsey Co. Ohio
    Ford 3000
    Nice idea. Of course, next week you'll get the ATV stuck and need the winch.
Similar Threads
  1. Winches Logging winch on B7100
    By Bluelick in forum Kubota Owning/Operating
    Last Post: 09-16-2012, 07:21 PM
  2. Anyone added a winch to their ASV?????
    By rutwad in forum Construction Equipment
    Last Post: 03-17-2007, 02:27 PM
  3. Tires ATV tires on a BX?
    By Spudgunner in forum Kubota Owning/Operating
    Last Post: 01-03-2007, 06:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
