Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
  1. #21
    Join Date
    Nov 2007
    Posts
    131
    Default Re: Painting and working on old tractor
    Kreem tank sealer works very well, but is only as good as your procedure in appying it.
    Ethenol has no effect on Kreem.
    For large tanks, we buy the quarts or gallons. You can buy muratic acid in gallons at your local pool and spa store. MEK can be found at Sherwin Williams.
    If you TAKE THE PROPER TIME and follow procedure youu will have no further problems with your coated tank. We have several tanks coated 15 - 20 years ago.
    The most amasing example is the tank on my Ford 9N:
    When I got to the step of etching / rust removal with acid, the bottom of the tank not only leaked like a sieve; it LOOKED like a sieve!! I continued on and coated the tank and that was over 15 years ago. The lining still looks and works like new.
    Last winter I made 2- 21 gallon tanks for a forklift. I decided to line them right off the bat while new. It took a better part of a day EACH to go through the proper steps. They turned out perfect!
  2. #22
    Join Date
    Apr 2005
    Posts
    127
    New Hampshire, USA
    JD 4500
    Quote Originally Posted by scott_vt View Post
    Good Evenin Code54,
    On the tank issue, I just poured a box of locknuts and a couple quarts of kerosene into the fuel tank and then let it spin on an old paint mixer. You could also strap it to one of your tractor tire rims and let it spin slowly for a couple of hours. The inside of the tank came out like brand new. I then washed it and flushed it with water and let it dry. I have never had rust return...
    It could be a cheap way out for you...
    Scott_VT - If I'm not mistaken, isn't that a picture of a Farmall Super A? My dad had both the cub and Super A and the picture you show is from the rear of a Super A, if my memory is correct.
    Great looking tractor. I miss the one my dad had. It was so easy to service, etc...
    Thanks for posting the pic.
    Roger
  3. #23
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    5,679
    Northern California-Tehama Co.
    2008 Mahindra 5525, 1964 MF-135 diesel, 1951 Farmall Super A, 1951 Minneapolis Moline BF, 1945 Oliver 60 Row Crop, 1949 JD B widefront
    Quote Originally Posted by Roger2561 View Post
    Roger
    Here's my 1951 Farmall Super A with it's 3pt hitch
    And my 1948 Farmall Cub
  4. #24
    New Member
    Join Date
    Sep 2011
    Posts
    18
    John Deere 4510
  5. #25
    Elite Member tcreeley's Avatar
    Join Date
    Feb 2011
    Posts
    4,486
    Central Maine
    2003 New Holland TC30
    Quote Originally Posted by tcreeley View Post
    Nice cub- had one for years- great tractor- rugged.
    Wrong on that one! nice looking super A , I'm corrected!
    2003 NH TC30, International Agritech 5' Bushhog, Carryall, Camo brush trailer, Gravel gravity dump trailer, International single plow, International disc harrow, Bucket mount Snowbear snowplow, hiller/bedder, Craftsman ZTL 7000, CCRT4, My favorite 20oz hammer I left on the woodpile a month ago.
  6. #26
    Elite Member scott_vt's Avatar
    Join Date
    Oct 2004
    Posts
    4,920
    east wells,vt
    1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
    Roger
    Good Evenin Roger,
    Yep it is and thanks !
    Good Evenin tcreeley,
    No problem, if you had a picture of those two tractors side by side, the Super A looks like its on steriods compared to the Cub !
    Attached Images Attached Images
    scotty
    ,,,course,,it is gas,and gas is,,well,gas,,so,,but it kills the @#$$ oughta them yellow jackets,,,thingy
    http://www.tractorbynet.com/content/...onth-scott_vt/
  7. #27
    Platinum Member Code54's Avatar
    Join Date
    Aug 2005
    Posts
    944
    Putnam Co. West Virginia
    Kubota MX5100 (50 Hp, 42.5 pto) 1968 Cub, B7200 HST
    Thanks!!! I am going to call the Rad shop downtown on Monday and see what they can do on the tank. Overall it is just a little surface rust so it should be rather easy. No holes or flaking rust or anything.
    Thanks again!!!
    1985 B7200 HST
    1968 IH Cub Lowboy (being rebuilt currently)
  8. #28
    Join Date
    Aug 2005
    Posts
    944
    Thanks again!!!
    1985 B7200 HST
  9. #29
    Join Date
    Apr 2005
    Posts
    127
    New Hampshire, USA
    JD 4500
    Good Evenin Roger,
    Scotty, I love that side view of the Super "A". Did you restore it? If yes, you did wonderful job.
    If I'm not mistaken the only difference between the "A" and Super "A" is the hydraulics. The "A" did not have hydraulics, correct? Roger
  10. #30
    Join Date
    Oct 2004
    Posts
    4,920
    east wells,vt
    Good Afternoon Roger,
    Yes I did and thanks so much on the compliment !
    Yes the only real difference is the touch control hydraulic unit under the fuel tank. I also rebuilt that unit durring the restore, it was about $100 for the rebuild kit from Case IH dealer...
    Here is a link to the thread I had started a number of years ago when I was restoring the Super A ...
    http://www.tractorbynet.com/forums/p...w-any-day.html
    scotty
Similar Threads
  1. New member- old tractor
    By mattgo in forum Massey Ferguson Owning/Operating
    Last Post: 04-09-2008, 02:09 PM
  2. Replies: 64
    Last Post: 06-20-2007, 02:19 PM
  3. JD 4000 series wheel bolts
    By Anonymous Poster in forum John Deere Owning/Operating
    Last Post: 04-13-2002, 10:56 AM
  4. Chain of command
    Last Post: 04-13-2002, 06:17 AM
  5. Working in the Bucket
    By JYH in forum Safety
    Last Post: 11-17-2000, 11:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
