Results 1 to 10 of 12
10-30-2011, 08:35 PM #1Veteran Member
- Join Date
- Jun 2010
- Posts
- 1,063
- Location
- Somewhere north of Roseau,MN
- Tractor
- Fordson Major Diesel, Ford 1510, John Deere L111
Better battery access.
Okay, I'm sick and tired of having to remove the FEL brace to open the hood to reach in front of the radiator to put clamps on the battery to either charge the battery or jump-start the tractor.
Solution? I purchased heavy duty quick connects, inserted a pair in my jumper cables (about 1/4 to 2/3 from one end, giving me long and short cables to work with) and using a section scavenged from my jumper cables, made a charge/jump point on the side of the tractor with a matching plug to mate with the jumper cables.
I can now charge or jump the tractor without having to touch the hood.
JoeFordson Major Diesel
Ford 1510
Du-Al 105 Loader
"The Thumb" Grapple
Bush Hog RBC60 Rear Blade
Woods HC54 Rotary Cutter
Tarter 5' Heavy-Duty Hinge Back Box Blade
Buhler Farm King Y600 Snowblower
10-30-2011, 09:07 PM #2Veteran Member
- Join Date
- Jul 2008
- Posts
- 2,385
- Location
- Bay Roberts, Newfoundland, Canada
- Tractor
- Custom 2011 Kubota 5740 HSTC-3, Grand Cab. Yep. Life is grand! 2013 Kubota BX25D.
Re: Better battery access.
They sure are great. I did the same thing a few years ago with my old forklift. Good stuff.
...Excellence is not just a skill. It is also an attitude...
Photo's of my restoration work and tooling: http://www.flickr.com/photos/15602393@N05/
YouTube Video's: http://www.youtube.com/results?searc...rch_type=&aq=f
2011 Kubota 5740/854 FEL/L2674 Blower/Artic Angle blade with 3rd function set up,Rain Tracker Wiper system, custom built vertical exhaust,Grammer Air Ride Seat and other custom stuff
2013 Kubota BX25DTLB With Wallenstein BXM32
Kubota ZTR ZG 222 Z
10-30-2011, 09:34 PM #3Gold Member
- Join Date
- Oct 2003
- Posts
- 324
- Location
- Central Maine
- Tractor
- John Deere 4600, Craftsman YT4000
Both of these are nice setups.
I'm "going green" - my "4-wheeler" is a John Deere 4600 HST!
11-04-2011, 07:56 PM #4Veteran Member
- Join Date
- Jul 2004
- Posts
- 1,553
- Location
- Bancroft, Ontario
- Tractor
- JD4300
I've got a set as well, sticking out from the grill of my JD4300, (also a set on my pickup) Booster cables will plug into either one...or if needed I can hook the battery charger clips to them
11-04-2011, 10:51 PM #5
How many amps will those connectors handle ?
E/S
2009 Kubota M8540HDC12-1 4x4 w/ Cab
LA1353 FEL w/ 7' Bucket & Pallet Forks
McMillen X1475 Earth Auger w/ 9", 18" & 24" augers - Land Pride RCR3596 Rotary Cutter
Gearmore 4G4 Series 7' Box Scraper w/ hydraulic rippers
11-05-2011, 04:25 PM #6Veteran Member
- Join Date
- Jul 2008
- Posts
- 2,385
- Location
- Tractor
Kubota ZTR ZG 222 Z
11-05-2011, 10:08 PM #7
It 50 amps enough to jump start a tractor ?
E/S
11-11-2011, 11:30 PM #8Veteran Member
- Join Date
- Jul 2004
- Posts
- 1,553
- Location
- Bancroft, Ontario
- Tractor
- JD4300
Depends on the size you buy. Some of mine are good for #2 wire (over 100amp continuous rating), others came with connectors for #10 wire (smaller size plugs). Many sets of booster cables are made of #6 wire which is normally rated for about 50-60 amps continuous use. I believe the large connectors say 400amps on them....but that would be for booster cable type use(intermittent), not lift trucks (continuous)....
I use a set on my 8000lb winch and have never had a heating problem...much the same load as a starter but for longer periods
11-12-2011, 11:03 AM #9
Interesting.
Thanks
E/S
11-12-2011, 03:56 PM #10
I got a set (gift) made by Warn. Since my winch is portable, I already had the hookups on the front and back of my truck. I've given people a jump using the back hookup, comes in very handy. Don't have to face traffic on a busy highway.
Warn Industries - Electrical Accessories for Jeep, Truck & SUV Winches: Booster CablesJD 2520CUT; 62D MMM; 200CX FEL W/61" Bucket; Rhino 148 Cutter; 1800# Forks
Similar Threads
A Battery Rejuvenator
By ETpilot in forum Owning/OperatingReplies: 87Last Post: 04-25-2013, 08:36 AM -
Lithium ion battery life - in years?
By alchemysa in forum Related TopicsReplies: 14Last Post: 04-14-2010, 01:11 PM -
Dirty battery tray on class III boomers
By grainger12002 in forum New Holland Owning/OperatingReplies: 13Last Post: 11-11-2003, 01:57 PM -
battery question
By Billc in forum Rural LivingReplies: 13Last Post: 04-04-2001, 07:05 AM
