Results 1 to 10 of 10
  1. #1
    Platinum Member bubbacuse77's Avatar
    Join Date
    Jul 2008
    Posts
    575
    Wisconsin
    John Deere 3520, John Deere X749
    Default Snow Plow Wings
    Any body put wings on there snow plows? After market or homebuilt? I could use some pics and some advice as to if they are worth it. I've heard they can cause damage to the plow.
  2. #2
    New Member
    Join Date
    Dec 2010
    Posts
    9
    Oliver 77RC
    Default Re: Snow Plow Wings
    I built a set for my Boss straight blade plow. I only plow around the farm but it has been a nice improvement. The biggest advantage for me was being able to wing the snow farther off the shoulder of the driveway. They also made it nicer for cleanup.
  3. #3
    Bronze Member sixgun's Avatar
    Join Date
    Mar 2009
    Posts
    60
    Loudon, NH
    Kubota B2710
    Default
    I added a set of wings to my 60" blade over the summer but haven't had the opportuity to try them out yet. They are the PW22 model available at Northern Tool and added about a foot to each end. They are secured using brackets and pins so they can be removed (the wings but not the brackets) very easily. Search the "snow removal" forum for the thread, which has several photos of the installation.
    2005 Kubota B-2710HST owner and small-time farmer...
  4. #4
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    7,162
    north idaho
    Kioti DK45SE hst cab
    Quote Originally Posted by sixgun View Post
    by wings do you mean a gate to convert the blade to a push? or simply to lengthen the actual blade??
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  5. #5
    Join Date
    Mar 2009
    Posts
    60
    Loudon, NH
    Kubota B2710
    Here are a few photos. They both add length and help to keep the snow from trailing off the sides. Sort of halfway between a straight blade and a pusher.
    Attached Thumbnails Attached Thumbnails Snow Plow Wings-dsc00451-jpg   Snow Plow Wings-dsc00454-jpg   Snow Plow Wings-dsc00455-jpg   Snow Plow Wings-dsc00462-jpg
  6. #6
    Join Date
    Jul 2008
    Posts
    575
    Wisconsin
    Thanks for the pics, that is exactly what I was looking at. Have you used them for a winter yet?
  7. #7
    Join Date
    Mar 2009
    Posts
    60
    Loudon, NH
    Kubota B2710
    Unfortunately, no use yet. I almost used the plow after the Halloween storm (16") but I still had several jobs for the loader before I could put the plow on. Plus, my drive was (and still) not frozen so I would have made a mess of things.
  8. #8
    Join Date
    Jan 2008
    Posts
    238
    Default
    Those are Buyers Pro Wings. They are decent and available cheaper at places other than northern tool. They have a rubber cutting edge and if you catch something with the wing itself they will bend. But they are great for the money. You just have to treat them nicely. Biggest benefit with wings is the ability to carry snow.
  9. #9
    Join Date
    Nov 2006
    Posts
    1,386
    Missouri
    Case 55C CVT
    These came with the blade I purchased from quickattach. They fold back out of the way when not needed.
  10. #10
    Join Date
    Jan 2011
    Posts
    7,162
    north idaho
    Quote Originally Posted by jk96 View Post
    hay...i have the same thing
    so far im VERY impressed with the blade also.
    Attached Thumbnails Attached Thumbnails Snow Plow Wings-plow-1-jpg   Snow Plow Wings-plow-2-jpg   Snow Plow Wings-plow-hitch-1-jpg
    currently own
Similar Threads
  1. Blower questions for a kubota l3540
    By arsenix2001 in forum Snow Removal
    Last Post: 12-22-2013, 06:14 AM
  2. Snow plow, Frame mount, Front lift
    By JB4310 in forum Build-It Yourself
    Last Post: 02-06-2012, 12:18 AM
  3. Buying Advice Getting closer to pulling the trigger but have snow plow question.
    By tjl5709 in forum Kubota Buying/Pricing
    Last Post: 09-12-2011, 08:32 PM
  4. Snow Loader Mounted Snow Plow for 2305
    By johnnydel29 in forum John Deere Owning/Operating
    Last Post: 01-06-2009, 07:00 PM
  5. yet another snow plow question
    By shawnrogan in forum Customization
    Last Post: 12-25-2005, 12:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
