Results 1 to 10 of 44
11-24-2011, 03:26 PM #1Silver Member
- Join Date
- Oct 2007
- Posts
- 193
- Location
- Guilderland, New York
- Tractor
- 2010 SC2450 Cub Cadet/Yanmar 2003 Craftsman GT5000 1969 Wheelhorse GT14 1969 Gravely L 5' Back Blade Subsoiler/Middlebuster 52" Ratchet Rake
Linear Actuator
I want to add a linear actuator to the chute deflector on my snowblower and was wondering what thrust pounds will work the best?
Here is what I am lookning at:
115 lbs. Thrust Linear ActuatorsCub Cadet/Yanmar TLB Sc2450, Ratchet Rake, Front Snowblower, Back Blade, Spreader, Middlebuster.
Craftsman GT5000
Wheelhorse GT-14
11-24-2011, 07:28 PM #2
Re: Linear Actuator
The only thoughts I have is for you to turn the chute by hand and use a guess as to how many pounds of thrust you think it needs. What you also need to consider is how many degrees of rotation you require for the chute. There will be some angular vector forces to take into account.
I think your 115 LBS thrust is a good starting point, and stroke is the another consideration ?
Craig Clayton
11-24-2011, 10:02 PM #3
Re: Linear Actuator
Northern tool sells one that's a little more money but I think would work much better. It's designed to dump garden tractor carts. That one you listed may work but I would want to know if it was weather tight. Plus it sounds like it has an aluminum rod. Moving the chute isn't too hard but it needs to hold the chute where you want it. I'm not sure if aluminum will handle it or bend (would need to know the diameter of the rod).
Wel-Bilt Linear Actuator 12 Volt, 11 13/16in. stroke | Lawn + Garden Utility Trailers | Northern Tool + EquipmentKubota L4240,Case 580K backhoe, Case 450 Dozer
11-24-2011, 10:22 PM #4
11-24-2011, 10:48 PM #5Veteran Member
- Join Date
- Nov 2008
- Posts
- 2,306
- Location
- South Central Iowa
- Tractor
- TYM 330 HST with FEL
Re: Linear Actuator
Ladia
TYM 330 HST with FEL, box blade, rotary mower, post digger, three point sprayer, homemade backhoe, Jinma chipper, Leinbach rake and Lincoln 255XT MIG.
Tasker harrow disc, PTO driven 5 cuft concrete mixer. My wife Julie has Grasshopper 725K.
We live in a barn (aircraft hanger) converted into a house. Our PV system: https://enlighten.enphaseenergy.com/...ems/h2eX136588
http://pvoutput.org/intraday.jsp?id=20209&sid=18073
11-25-2011, 12:08 AM #6
Re: Linear Actuator
mine uses a small hydraulic cyllinder on the deflector, but i have no idea how much force is beilg applied to it from the snow while its blowing. Considering the tonnage of snow blown out the thing, it could be quite alot. They have a pretty beefy cyllinder on mine.
currently own
2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
Quick Attach 79" loader mount snowblower & rear powerpack
Quick Attach 84" Snow Blade
Quick Attach 42" pallet forks
11-25-2011, 07:17 PM #7
Try this.
http://www.firgelliauto.com/product_...roducts_id=129
FA-MS-15-12-xx"( Standard Force)
I have used this for 3 winter snow blowing seasons and have had no issues
You do not need 100lbs
This model is 15lbsericher69
IAFF Local 849
11-25-2011, 07:25 PM #8
Re: Linear Actuator
I incorrectly in my read the orginal posters question. So I looked at the last posters picture of his chute deflectors hydraulic cylinder. So if we were to guess at a 30 LBS thrust at the tip of the chute and the chute is 9 " from the pivot point. The cylinders pivot point might be 3 " from its pivot point . This would create a 3 times mechaincal load on the actuator. So in guessing the actuator might have to push a 30 X 3 = 90 LBS thrust. ( more or less )
Craig Clayton
11-25-2011, 07:35 PM #9Elite Member
- Join Date
- Aug 2004
- Posts
- 2,714
- Location
- North of Mtl,Que,Can (Ste Adele)
- Tractor
- MT180D
Re: Linear Actuator
Also there is a big difference in power needs depending on whether you activate before you blow or while blowing. At idle very little power would be needed.
11-25-2011, 10:09 PM #10
Re: Linear Actuator
If you are looking to build your own, check out an old 6 foot satallite dish actuator. Most are outdated and people will give them to you just to remove it. It will run on 12-36 volt and the rod can be cut off as short as needed. As for force leverage will make up if there is any shortfall in power.
Russell
Similar Threads
linear actuator to run grapple???????
By wftree in forum CustomizationReplies: 21Last Post: 02-12-2012, 06:38 PM -
Snow Attachments Chut Deflector adding a linear actuator
By kub3030ota in forum Snow RemovalReplies: 0Last Post: 08-06-2011, 09:01 AM -
linear actuator for plow blade
By rfowler in forum Build-It YourselfReplies: 12Last Post: 08-23-2010, 07:28 PM -
RTV900 Plow Electric Lift Linear Actuator
By lloyd123 in forum ATVs & Utility VehiclesReplies: 8Last Post: 03-06-2005, 03:04 PM -
source for Linear Actuator?
By Larry_Van_Horn in forum Build-It YourselfReplies: 5Last Post: 08-26-2003, 08:41 PM
