My Work Light Installation
   / My Work Light Installation #1
DennisFolsom
Gold Member
Central Maine
John Deere 4600, John Deere X380
This afternoon, I made a pair of "brush guard" type light mounts for my John Deere 4600. I used 1.25 " x 1/8" steel, which I bent cold using a vise, hammer and anvil. These are a similar design to the John Deere Brush Guards, and mount the same way.
The photos show the trial fit, before painting and hooking up the wiring. There's also a shot of the mounts just before painting.
I painted the primer coat earlier this evening. I brought them into the Living Room after painting, so the paint would cure faster. I'm not sure I can get away with this, but I'd like to top coat them before I go to bed tonight, so I can install them, and hook up my wiring tomorrow.
The way my ROPS is built, the access at the bottom is poor. It may be tricky fishing the wires through them. The best method I have thought of is to pull out the existing wires, using them to pull some twine down through. Then, I can pull the new and existing wires back up with the twine.
The lights are Halogen Work Lights from Harbor Freight. If I remember correctly, I paid about 8 bucks apiece for them.
If all goes well, I'll post more photos tomorrow evening.
   / My Work Light Installation #2
Good job, looks great.
   / My Work Light Installation #3
Looks Good :thumbsup: I mounted a bracket and lights on the inside of my rops . I used mechanics wire to feed the wire up inside the tube . Be patient , it's worth it . :thumbsup:
   / My Work Light Installation #4
Looks great I also have the same lights. For the money you can't beat them.
   / My Work Light Installation #5
Fishing the wires through the ROPS isn't as difficult as you may think as I've run a number of wires through mine.
   / My Work Light Installation #6
I think what you have done.
Two questions, 1) how do you plan to bring the wiring out of the ROPS? 2) What size gauge wire are you using?
   / My Work Light Installation #7
Good job:thumbsup:
I did the same thing you did(kinda).
My Massey came with metal guards around the turn signals, so I just attached my worklights to those. I placed 1 one each side, 1 forward, 1 backward.
There is a hole for the wiring between the two bolt holes where the original tail lights mount. The thickness of my brush guard/bracket is 1/8" which provides enough clearance for the wire to come out between the tail light and the ROPS. I am also using the split plastic conduit to protect the wires and neaten the installation.
I am using 16 gauge wire. I believe that should be adequate and I already had some on hand.
I'm part way through the wiring now. Gotta have lunch and get back to it.
I'll post some photos tonight.
   / My Work Light Installation #9
Nice Job :thumbsup:
My Work Light project is done - at least for now. I have a change I might make.
Pulling the wires did turn out to be less trouble than I anticipated. On somebody's post (either on TBN or on another forum) I saw them using a garage door cable to pull wires through the ROPS. While hunting through my storage boxes for some wire, I found an extra garage door cable. I folded the ROPS and fed the cable down from the top, plain end first. When I got to the bottom, I poked around a bit, and was able to get the cable out through the open area at the front of the bottom of the ROPS tube. (Due to the brackets for the ROPS and the backhoe, you can't look straight up into mine, and you can't get into it directly from the rear of the tractor.) I taped my wires to the cable and first pulled them all the way out the top of the lower ROPS section. Then, using needle-nosed pliers, I was able to pull each wire out through the hole in the side of the ROPS, between the taillight mounting bolt holes.
I had selected a spot on the plastic panel behind the 3PT hitch control to mount the switches. I measured carefully, installed my switches in the panel (which I had removed), then discovered that I hadn't done enough exploration. There is a steel plate under that plastic panel. It doesn't sit close enough to the plastic piece to mount the switches through both. In the first photo, you can see my solution to the problem. I drilled holes in the corners, made a couple of cuts, and folded a chunk of the panel to make a rectangular opening. This steel panel doesn't really carry any load, so I think it's still strong enough.
The third photo shows the location of the switches. These are heavy duty, supposedly waterproof, toggle switches that I ordered from Vetco. With shipping, 3 of them cost more than my lights did. I am pleased with the switch location. My hand drops easily to where they are and I can use them by feel.
The 4th and 5th photos show the finished light installation. Note the flexible conduit to protect the wires. I need to get some Liquid Rubber, or something similar, to seal where the wire exits from the top side (as mounted) of the rear-facing lamp. While at it, I will seal all of them.
Photos 6, 7 and 8 were taken outdoors without using the flash on the camera. They don't really do justice to how much the added lights brighten up the sides and the rear. Also, the operator's station is well illuminated. I think they will make the tractor more visible to oncoming traffic when I am clearing the intersection of my driveway with the road.:)
The last photo is the view to the rear from the driver's seat. The photo looks a bit dark, but without the rear light, you would see nothing but blackness. Again, the camera did not do it justice. You really can see back there quite well.
Overall, I'm quite happy with the setup.:D
The one disappointment I did have was that when the tractor light switch is in the position that gives you flashers plus headlights, the work lights are not powered. They are only powered when the tractor switch is in the headlights and tail lights position. I would like to be able to run the flashers when the work lights are on. For that reason, I may run a separate wire and fuse back from the battery and power the work lights independently of the tractor light switch and wiring harness.
In my brief trial of the new lights, I can see why some folks are buying or making glare hoods. I have an idea for some home-made ones that I may try.
I have an LED warning beacon with a magnetic mount. I want something stronger for its original purpose (my construction inspection work), so I may dedicate that one to the tractor. My problem with that is that my ROPS will just fit through the garage door in the up position. However, I have been thinking of ways to get around that limitation. If I do put the warning beacon on, I would be less concerned about not being able to run the flashers at the same time as the work lights.
More to come, but that's enough for tonight. Stay tuned.
2010 Volvo XC90 SUV (A56859)
2010 Volvo XC90...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
PEDESTAL FAN (A58374)
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
2007 Ford E-350 Passenger Van (A55973)
2007 Ford E-350...
