Results 1 to 6 of 6
02-19-2012, 04:24 PM #1New Member
- Join Date
- Feb 2012
- Posts
- 5
- Location
- macclesfield,nc
- Tractor
- l4200
Changing cat 1 to cat 2 on kubota L4200
I have a Kubota L4200. I was wanting to change from cat 1 to cat 2 so I can use all my implements I have here on the farm. Is there a kit offered by Kubota od someone else that could be done?thanks for your help.
02-19-2012, 10:14 PM #2Platinum Member
- Join Date
- Feb 2012
- Posts
- 599
- Location
- Summit. Ms
- Tractor
- JD 4840, 450j, 310, komatsu D31, IH 1486, MF 135
Would just changing the pins on your cat 2 equipment down to cat 1 be simpler and cheaper?
02-20-2012, 12:15 AM #3Elite Member
- Join Date
- Jun 2008
- Posts
- 4,735
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
Re: Changing cat 1 to cat 2 on kubota L4200
As far as the lift arms, I have seen the weld on ball/socket ends at different tractor supply houses (Agri-Supply, Attwoods, TSC)that you could cut off your Cat 1 and weld on Cat 2. As for the 3rd arm, just buy Cat 2 and swap them. Should be just a swap assuming you have clearance at the tractor for the larger ball end. Might have to grind it down a bit for clearance. Sounds like maybe a two hour welding job at most. By having the Cat 2 balls on the arm, just buy some sleeves and you can still hook it up to the cat 1 pin. Just grease the sleeves good before putting them in otherwise you may have to cut them out with a torch after they corrode up (dont ask me how I know this)
2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
02-20-2012, 12:11 PM #4Super Member
- Join Date
- Apr 2000
- Posts
- 5,852
- Location
- central New York
- Tractor
- all makes and models
Least work would be to change the pins to cat 1 that you wish to use on both sizes and just use a bushing on your cat 2 tractors.
I'd be watching for the cat 2 hitches that do have the cat 2 width as well as the pins! They might not work or just barely.
02-28-2012, 07:38 AM #5Silver Member
- Join Date
- Sep 2009
- Posts
- 229
- Location
- North Mississippi
- Tractor
- Cub Cadet 8404 or DK 40 Kioti
I just welded some cat 2 directly to the cat one arms so i could use the emplements without pulling parts on and off durring the day. its worked good for years.
02-28-2012, 09:07 AM #6
Just a thought, is there enough room between the tires for the wider cat 2 stuff. I know my Kubota is very narrow in the back.
_____________________________________________
2007 Kubota L3400HST, LA463 FEL with Markham tooth bar, Woods BB60X rotary cutter, Woods GB65 box blade, KK 6' landscape rake, John Deere 2 row corn planter, Fimco 60 gallon boom sprayer, KingKutter 5' tiller and a Kubota 1000 lb ballast box with more to come.
Armed men are citizens, unarmed men are subjects.
Similar Threads
Ford 601 Workmaster PTO Problem
By swampdog in forum Parts/RepairsReplies: 17Last Post: 05-25-2012, 04:56 PM -
9N steering
By RobertN in forum Ford Vintage TractorsReplies: 5Last Post: 07-23-2011, 08:59 PM -
JD 125 shid loader
By Hooked_on_HP in forum Parts/RepairsReplies: 2Last Post: 01-24-2011, 04:12 AM -
using a cat 2 box scraper with a cat 1 hitch
By davygp38 in forum AttachmentsReplies: 13Last Post: 06-24-2010, 08:58 AM -
Kubota 2 Year Survey
By rlk in forum Kubota Owning/OperatingReplies: 8Last Post: 10-23-2003, 11:30 PM
