Page 8 of 8 FirstFirst ... 5678
Results 71 to 80 of 80
  1. #71
    Join Date
    Jul 2004
    Posts
    1,985
    Bancroft, Ontario
    JD4300
    Default Re: Kens Bucket hooks Price worth it?
    I keep seeing hooks fastened to the top of JD buckets. When I got my 4300 I did the same thing until the first lift. I then straightened the top of my bucket and reinforced it with a piece of 3" Chanel Iron from one side to the other. I've bent the lip under it, but the top of my bucket is still straight ten years later.
  2. #72
    Gold Member gumshu's Avatar
    Join Date
    Jun 2009
    Posts
    469
    Atascadero, Ca. & Selma, Or.
    Kubota M7040, Bobcat CT235, Kubota BX23 TLB & RTV 900
    WHERE DO YOU GUYS BUY kEN'S BUCKET HOOKS?
    F350 6.4 Dually, PJ 14K 20', PJ 3.5K
  3. #73
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    ::Sent from a standard desktop keyboard::
    My Photobucket
  4. #74
    Join Date
    Jun 2009
    Posts
    469
    Thanks Will
  5. #75
    Join Date
    Nov 2012
    Posts
    96
    Land Between the Lakes
    John Deere 3038e and LS K 5047
    Just ordered a set,,,, i moved a small tree the other day... and thought there has got to be a hook i can buy to make this work easier.....
    can't wait...looks like a very high quality product,
    John Deere 3038e
    Kentucky
  6. #76
    Join Date
    Dec 2010
    Posts
    185
    Love, VA
    Kubota B7100 HST 4WD
    Quote Originally Posted by jmc View Post
    Most of the stuff we buy is made by the tens of thousands or more at a time by the cheapest labor that can handle the job. We get spoiled by this efficiency and expect it in everything we buy. With a small market like bolt-on hooks, I doubt if Ken is getting rich.
    You are right. I make telescoping stabilizers for tractors. Most small tractors don't come with them, and the manufacturer doesn't make them. So, I first met my own need, revised them, and eventually started making them for people. I have to keep a lot of different sizes of steel in stock here at the house, welder, plasma cutter, high quality cold cut saw, etc. I also stock lots of hardware- different length and diameter clevis pins, cotterless pins, etc. I make many trips to the post office, 20 miles round trip. I make each set individually. I get lots of emails, and about half decide to buy them. I assume that for the others, they think my prices are high. I have worked it out this way- material costs, labor, shipping. I don't mark up the material; I know how many hours I spend making and painting a set, so I don't have an hourly figure, but rather know whether I am making a fair hourly amount; and shipping, which I charge what the post office charges me. In other words, I try to keep the costs fair, while being sure that I have made some profit. So, I am confident in my price, both in what I make and the value that the customer gets. I would imagine that Ken is in the same place; you make a custom product, you price it to be profitable, but not price yourself out of reasonability. Being that there is no other product like it, that makes it fair. You are paying mostly for his ingenuity and the convenience. You are paying for a bolt on hook, so that you don't have to repaint your nice bucket after welding a hook on. You can also remove the hook and transfer it to another spot, or another tractor. You can reinforce it easily, which you can't do with a weld on hook.
    From one small business fabricator to another, I think his price is fair.
    "For I am not ashamed of the gospel of Christ..." Romans 1:16
    94 Dodge Ram 2500 CTD
  7. #77
    Elite Member oldballs's Avatar
    Join Date
    Dec 2009
    Posts
    2,877
    Kansas...USA
    Kubota B2620 , Case 448
    Buying Ken's was the only way to go for me, a non-welder. And on the BX bucket the top needed extra plates to raise the hook for clearance over the narrow lip as I recall. Anyway they worked great with the height raised and a set of backer plates. In fact, I put a set on the Pallet fork frame for moving large brush piles when falling dead pine trees.
    When the BX was traded for the B2620, I removed the hooks and bolted them to the new tractor. I'm happy. Mike
    Kubota B2620 HST (2012) Case 448(1983)
  8. #78
    Bronze Member bullopa's Avatar
    Join Date
    Jun 2012
    Posts
    56
    Stephentown, NY
    Kioti DK40SE
    Did you get/use them yet? I love mine - have pulled about 50 stumps up to 15" in diameter with them. Makes life much easier.
  9. #79
    Join Date
    Nov 2012
    Posts
    96
    Got them in the mail yesterday,,,, nice product...
    will bolt them on tomorrow and head to the farm for some tree work... i will bost some work in action photos....
    Fast service...thanks...
    John Deere 3038e
    Kentucky
  10. #80
    Super Member jeff9366's Avatar
    Join Date
    Jan 2011
    Posts
    6,530
    Fanning Springs, Gilchirst County, North-Central Florida
    Kubota Tractor Loader L3560 HST 37-hp / 5,400 pounds
    PHOTOS: Ken's Bolt-On Grab Hooks At Work.
    In this case holding 3/8" chain. Ken's 5/16" hooks grab 3/8", 5/16", 1/4" and 3/16" chain securely.
    I consider 5/16" chain optimal for use with my 33-hp/1,800 pound kubota. If I ever run across 1/4" GRADE 70 chain I will buy 10' to try. During warmer days here in Florida chain gets really H E A V Y in the afternoon.
    I use 3/16" chain only to pull out 1" - 1-1/2" saplings. Smaller chain grips saplings and shrubs better than heavier chain, which often slips on small stuff. I try to pull everything by the roots so I can mow easily, later.
    I have one of Ken's grab hooks bolted on the cross-drawbar which is convenient when I want to pull something relatively heavy, which could stress the FEL.
    I used the rear cross-drawbar Ken's hook to pull out the timber in photo #1 + #2 from under a large mass of "mother" wild grape vines. Trunk was 5' longer when it came out, but one section broke off when I lifted the whole thing with the FEL. This was a max lift without rear counter-balance.
    I have a big Speeco pivoting grab hook for the traditional center drawbar but I hate to mount it for just one or two pulling tasks. Cannot leave the Speeco mounted because it will swivel around and bend the "check chains"/sway limiters when the three-point hitch is raised and lowered. ((Ask me how I know!))
    Payne's clamp-on aluminum debris forks visible in photo #1 + #2.
    Ken's bolt-on hooks, made in Maryland, are TOUGH.
    Attached Thumbnails Attached Thumbnails Kens Bucket hooks Price worth it?-img_0451-jpg   Kens Bucket hooks Price worth it?-img_0452-jpg   Kens Bucket hooks Price worth it?-img_0453-jpg
Similar Threads
  1. Strengthened bucket, added bucket chain hooks
    By hyperrust in forum Attachments
    Last Post: 03-22-2012, 01:00 AM
  2. Ken's Bolt On Grab Hooks
    By DennisFolsom in forum Customization
    Last Post: 08-26-2011, 10:48 PM
  3. Yet again, bucket hooks.
    By whodat90 in forum Customization
    Last Post: 12-06-2006, 05:42 PM
  4. Bucket hooks
    By Kevin37 in forum Owning/Operating
    Last Post: 04-29-2004, 11:17 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
