Additional Tractor Work Light Ideas
   / Additional Tractor Work Light Ideas #1
clee4020
Mississippi
Kubota M9540 HD 4x4
Would like to add 2 work lights pointing forward and 1 or 2 pointing rearward to my Kubota M9540 under my canopy to my ROPS. I wind up feeding cows when I get home from work and the factory lights are almost useless when you stick a roll of hay with FEL. I am leaning towards LED due to the low current draw. I am looking for ideas and especially pics.
I mounted these flood lights ( LED 90-deg flood light ) to my mule and they are plenty bright up close, but would like to have something shine out a little further.
   / Additional Tractor Work Light Ideas #2
How about something like this. They are standard equipment on the B26.
   / Additional Tractor Work Light Ideas #3
The top two rear lights are standard - the bottom two rear lights are one set of the optional work lights available for the B26.
   / Additional Tractor Work Light Ideas #5
The factory front and rear lights (the upper ones) are attached to the plastic roof cover over the FOPS.
You can add four additional work lights - two on the front and another set on the rear as shown in the photo. The optional worklights for the B26 attach to the ROPS.
Lauren
   / Additional Tractor Work Light Ideas #6
This is my setup has worked well for ten years.
The front lights are long tapered beams I forget the specific name.
The rears are flood type
The center rear light is a driving light.
   / Additional Tractor Work Light Ideas #7
Mine, 2 forward and 2 rear plus my revolving light....Mike
These are some great ideas. What king of lights are they? LED? Halogen?...Since I do a lot of bushhogging and other work around near the woods, I don't think it would be wise for me to mount at the front of my canopy (mostly because others use my tractor too and wouldn't be as careful as I would). I'm leaning towards mounting to ROPS under canopy and probably make some sort of protection for them.
   / Additional Tractor Work Light Ideas #9
Mine are just regular incandescent. They've never gone out yet from vibration or damage, the revolving light filament has broken a couple times tho....Mike
   / Additional Tractor Work Light Ideas #10
I used what ever lights come on a Case 580 backhoe. These things are great.
