Results 11 to 20 of 51
06-28-2012, 02:03 PM #11Platinum Member
- Join Date
- May 2008
- Posts
- 723
- Location
- Prince Edward Island, Canada
- Tractor
- Kioti DK45SC
Re: carry-all for back of tractor
Mine (also a TSC one) is a lot like that. I put hinged sides on mine that can be folded in flat against the vertical front part. These sides also have vertical channels on the outboard (in)sides so I can slip in tailgate boards, if needed. There are also support brackets on the sides for a drop-in seat board, if I ever want to do that. Finally, I have a wooden chainsaw scabbard mounted along with the tool-holding pipes.
Mostly, I use it in the configuration you show to move blocked firewood.
BOB
06-28-2012, 10:17 PM #12Platinum Member
- Join Date
- Sep 2010
- Posts
- 711
- Location
- Fort McCoy, Florida
- Tractor
- Kioti DK45se HST - Rhino 660 4X4 - Snapper Pro ZTR - Craftsmen mower
Building these things is great fun. Your really only limited by your imagination or "borrowing" ideas you see from other folks. David- looks like you got a nice size frame there to work with. Bob - I made the scabbard for the chain saw, but had a tree fall across my road, so I hooked it up as it was and just haven't gotten around to sticking it on - my bad.
I am going to add a removable hitch to the back so I can tow around my flatbed trailer. I just have to figure out how to make it secure, but not be in the way when I have it sitting on the ground. I'm also thinking about some sort of platform for the front to use to stand on and/or transport my portable generator if I have a load of stuff on the carry-all.Doug P
06-29-2012, 08:14 AM #13Veteran Member
- Join Date
- Jan 2009
- Posts
- 1,514
- Location
- Rushville, Ohio
- Tractor
- Massey 180 Diesel
I built this one a few years back. Deck is 3' X 6'. Large enough to haul square bales of hay, also big enough to haul enough material, that I'm ready for a break, a if I shoveled it on. I have used it for when cleaning stalls also. Gathering rocks, etc. Seems I don't mind loading it, just hate to unload it so....
( Hope this link works..)
http://www.tractorbynet.com/forums/b...carry-all.html
06-29-2012, 11:06 AM #14Elite Member
- Join Date
- Aug 2011
- Posts
- 4,836
- Location
- Ladysmith, VA
- Tractor
- Kioti DK50SE HST w/FEL, John Deere LX266 & STX38 Mowers. Stihl MS290 20" bar, & FS190
Former Submariner & Army SGT
2011 Kioti
DK50SE HST, KL-401 FEL w/72" bucket, tooth bar, & Ratchet Rake, 2 rear remotes, canopy, WR Long RBG72 Grapple, Woods BB72X cutter & TSG-50 stump grinder, TSC PHD, & more to come. Mowers 2003 JD LX266 42" deck mower, & old JD STX-38 (12.5 hp).
Managing 51 Acres of Virginia hills with ponds & streams, mature market timber, riding trails, horse pasture, long gravel drive, veggie garden, & yard.
06-29-2012, 01:20 PM #15Veteran Member
- Join Date
- Jan 2009
- Posts
- 1,514
- Location
- Rushville, Ohio
- Tractor
- Massey 180 Diesel
Thanks for the compliment..!! Sure, a single action will work, as long as you have enough weight to push down, and return the oil. I have a 3 pt. cement mixer that has a single action, but has a helper spring to help bring it back to mixing level, but don't hink you would need one for something like this. I just happened to have this double action laying around I bought right, at a community auction, just itching for something to do.
I've had several people ask me to build them one, and may someday, when time allows. Just too many irons in the fire at this moment...
06-30-2012, 07:12 PM #16Gold Member
- Join Date
- Nov 2010
- Posts
- 254
- Tractor
- John Deere 855
Here is my carry all. Just a standard TSC carry all that I built a two piece deck and back board that are 3' long by 4' wide out of treated pine.
I found with my lifting capacity this is plenty big enough. With my tractor I found I could lower all three connection points 9" and it would raise the deck almost to tail gate level of my pickup.
............... Hardest part may be getting a picture to attach........
06-30-2012, 08:33 PM #17
Wyobuckaroo, I like that..... I see the orig holes and upper attachment pin. Is that what you raised 9"? Also, how much weight do you think that would lift? thanks
06-30-2012, 09:06 PM #18Bronze Member
- Join Date
- Jan 2012
- Posts
- 52
- Location
- Southwest Oregon
- Tractor
- JD 3032E
06-30-2012, 09:09 PM #19Elite Member
- Join Date
- Feb 2011
- Posts
- 3,429
- Location
- Tucson AZ
- Tractor
- New Holland TC-45
::"I STARTED out with nothing....I still have most of it."
New Holland TC45 1,300+ hours - FEL - back hoe - post hole digger - Hydraulic Gannon - cement mixer - pressure washer - 1975 Dodge 500 flat bed - 1974 chevy C65 6 yard dump truck.
All home made by me. loading forks - 2 drags - roller - Sheep's Foot - Pusher (to unload flat bed truck.) - pickle fork digger - Log splitter -
06-30-2012, 09:15 PM #20Bronze Member
- Join Date
- May 2012
- Posts
- 56
- Location
- fort worth, texas
- Tractor
- iseki 1300TX
Similar Threads
tractor supply carry all
By shortthrow50 in forum VideosReplies: 24Last Post: 03-21-2012, 10:39 PM -
Question-Carry All for Compact Utility Tractor
By billyii in forum AttachmentsReplies: 8Last Post: 07-20-2010, 10:24 AM -
Back on the Tractor Again.
By Rickstir in forum Mahindra Owning/OperatingReplies: 1Last Post: 04-02-2010, 08:50 AM -
My Tractor is back ,already!!!!!!!!
By harry trattner in forum Kioti Owning/OperatingReplies: 2Last Post: 10-25-2007, 09:04 PM -
Tools to Carry on the Tractor
By Turfman in forum Owning/OperatingReplies: 8Last Post: 09-04-2002, 09:20 PM
