Results 31 to 40 of 51
07-02-2012, 10:37 PM #31Silver Member
- Join Date
- Feb 2012
- Posts
- 246
- Location
- Albion, Indiana
- Tractor
- 1710 Ford
Re: carry-all for back of tractor
The forks I bought I got at an auction. They were 3' forks from a forklift that someone had built a 3PH frame around. There are various forks available though from Northern Tool, Rural King, etc.
07-02-2012 10:37 PM # ADS
07-17-2012, 09:06 AM #32
I'll tell you, the forks are the way to go. I built my forks (patterned off the Agri-Fab ones) out of rectangular tubing. They're light and mighty versatile for moving stuff around - Then I built a carry-all platform from some big ol pallets, it seemed like the perfect thing for bringing back firewood. Then I had to unload the wood.... so now I use the forks to take pallets to my wood site, have the kids fill the pallet (4 boards sticking up 3' along the sides), bind the load to the pallet and carry it back to the house where I set the whole pallet down with the rest of the palleted wood pile... no more loading and re-stacking! I did find that a 4x4 pallet of split cherry lifts the front end of my 9N if it's over 3' high! (so will the kids, nephews & sister-in-law going for a ride....)
"Do it right..... or do it over"
07-17-2012, 09:15 AM #33Platinum Member
- Join Date
- Jan 2012
- Posts
- 933
- Tractor
- 2012 John Deere 3520 Deluxe Cab
My carry all dumps loads like a dump bed with the use of a hydraulic top link. Just a thought for you guys
07-17-2012, 10:45 AM #34
I cobbled this slip-on 3PH tool carrier in about 20 minutes.
Knees got tired of carrying tools in the bucket.
Loved it so much I jury rigged some line to the ROP that allowed it to accommodate long handled tools.
It's just slip on slip off...just adjust the 3ph down limiter wing nut so the tool carrier always angles up and it's good to go.
LESS...is more.Kubota B1750 with chains on all 4 turf tires. CC1440 & GT2550
07-17-2012, 10:54 AM #35Veteran Member
- Join Date
- Feb 2011
- Posts
- 1,743
- Location
- Trivoli, IL
- Tractor
- SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
carry all's are nice.
but 3pt hitch pallet forks can work nicer.
used to just back up into a log or some lumber and off you go
you normally can find some pallets here and there if you call around to ask. so you can cut your lumber up. and place right on another pallet. and just keep filling pallets without ever loading, unloading.
if you have a larger size generator even though it might have wheels can be a pain to drag across the yard, let alone trying to lift it up into back of a pickup truck. when you do need it, when power goes out. place it on a pallet and use a couple straps to fasten it down. and move it with pallet forks.
build a tool holder box on a pallet
having a receiver hitch on the 3pt, that you can place a ball on. to pull a small trailer. for me really helps. more so if i am just using the tractor alone to trim trees. ya FEL is all nice and all to put stuff in. but small trailer behind me. can help me get more stuff on. without it falling out every time i go to stop.
my issues come down to. a point were i have mounted hooks around the tractor so i can toss tools into a 5 gallon bucket, and hang directly on tractor. due to FEL and 3pt hitch are normally being used to carry something else that i need for a project. or project is big enough having second person, to drive a truck while i drive tractor. and just load the truck up with various tools.
if you use 2" to 4" sch 40 PVC pipe with end cap on bottom, and use of some pipe hanger. long handle tools like shovels, and rakes, easily slip in. and hold the tools fairly well. TIP: drill a small hole in end cap to let water to escape out of the pipe.
personally prefer a long bolt i can place hooks of a chain on. and then let rest of the chain rest in a bucket or like. so i do not have to untangle the chain when it comes time to use it.
i have regular straps and chains along with binders for snugging things down on a trailer for hauling things. but tend to be overly long and cumbersome. and will drill descent size holes were ever i can. so i can use bungie cords. though it normally comes down to some wire, either thin electrical fence wire, or bailing wire.
due to bumps and no suspension on a tractor. using an old ammo box. vs a cheap or even expensive tool box will normally vibrate open vs an ammo box. to hold small tools, pins, etc... ya tend to quickly learn, when ya spend half a day picking stuff up, then stopping a few times after that as you eventually see the stuff that fell out of a small tool box that came open.Ryan
07-22-2012, 09:43 AM #36
Crash.....
I have a MIG welder (which I am not too good with.....)
WHERE do you get the diamond plate for the floor and WHERE do you get the diamond mesh wire that you used for the sides?
Thanks
07-23-2012, 12:01 PM #37
My buddy built the same kind of thing for dumping firewood into his basement hatch. Here's a video of it:
1953 John deere Model 40 - Homemade TPH Hauler - YouTubeChris - "Glassback"
Simplicity 12.5 LTH, 48" belly mower, 16 cu ft trailer, hand crank pencil sharpener
07-23-2012, 03:23 PM #38Veteran Member
- Join Date
- Jul 2009
- Posts
- 2,302
- Location
- SW WA
- Tractor
- Kubota BX2360
07-23-2012, 04:09 PM #39
Nice Video. Id ike to comment on how it dumps. I assume its all in the top link and how its lower than usual.This make it dump. Where usually the link is at a certain height that makes it raise level.So this is arranged good considering there isnt a hydraulic upper link.
07-23-2012, 04:41 PM #40Veteran Member
- Join Date
- Dec 2002
- Posts
- 1,937
- Location
- Foster, RI
- Tractor
- JD 750
He may indeed but it made me nuts to watch him carefully stack it on the carrier. I would need to build this thing a little deeper, put some sides on it and just throw the wood in. He could do 2 loads in the time he used to stack one load. Making the floor deeper and putting sides on would offset the larger amount carried by stacking on the smaller carrier vs. the thrown in wood for the deeper carrier. I dunno perhaps the guy has some ocd and this makes him happier to do it this way just as I would do with my method to stroke my add.
Similar Threads
tractor supply carry all
By shortthrow50 in forum VideosReplies: 24Last Post: 03-21-2012, 10:39 PM -
Question-Carry All for Compact Utility Tractor
By billyii in forum AttachmentsReplies: 8Last Post: 07-20-2010, 10:24 AM -
Back on the Tractor Again.
By Rickstir in forum Mahindra Owning/OperatingReplies: 1Last Post: 04-02-2010, 08:50 AM -
My Tractor is back ,already!!!!!!!!
By harry trattner in forum Kioti Owning/OperatingReplies: 2Last Post: 10-25-2007, 09:04 PM -
Tools to Carry on the Tractor
By Turfman in forum Owning/OperatingReplies: 8Last Post: 09-04-2002, 09:20 PM
