Page 3 of 10 FirstFirst 123456 ... LastLast
Results 21 to 30 of 94
  1. #21
    Veteran Member Jay4200's Avatar
    Join Date
    Nov 2005
    Posts
    2,017
    Hudson/Weare, NH
    L4200GST w/ LA680 & BX2200D w/ LA211
    Default Re: How do you carry your chainsaw ?
    I would suggest NOT just putting it in your bucket. It is theoretically possible that the saw could bounce out and get run over by the tractor. Theoretically....
    JayC
  2. #22
    Join Date
    Dec 2010
    Posts
    1,412
    Massey
    I drive over rough land. I've bent a new bar holding the saw by the bar such as Stewie's setup. I imagain on smooth land though, it works well.
  3. #23
    Elite Member dex3361's Avatar
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
    Yes it can and does happen I bounced a O45AV Stihl out of my truck while backing out of a rough area and ran over it. I felt rather foolish and poor after the repair parts bill.
    Randall
    1Timothy Chapter 2:
    3 For this is good and acceptable in the sight of God our Saviour;
    4 Who will have all men to be saved, and to come unto the knowledge of the truth.
    5 For there is one God, and one mediator between God and men, the man Christ Jesus.
  4. #24
    Veteran Member grnspot110's Avatar
    Join Date
    May 2007
    Posts
    2,330
    MO
    John Deere 1953-40S, 790, 755, 314, 70 I & Power King 2418
    I put a sleeve on the side of my weight box for the saw, gas, oil & tools in the top of the box.
    Attached Thumbnails Attached Thumbnails How do you carry your chainsaw ?-hpim2246-640x478-jpg   How do you carry your chainsaw ?-hpim2241-640x478-jpg
  5. #25
    Member
    Join Date
    Aug 2012
    Posts
    30
    west, ar
    B3200,B8200
    Quote Originally Posted by DarkBlack View Post
    Were you using a Kolpin Press like his when you bent the bar? The reason I ask is because the power head rests on a padded support plate so it is hard to understand what forces would cause the bending.
  6. #26
    Veteran Member buck12's Avatar
    Join Date
    May 2006
    Posts
    1,216
    NW Mississippi
    Mahindra 2615
    Default
    I was afraid of bending my bar due to the ground I usually operate on so I created this setup. While its not pretty it secures the saw and I don't worry about bending the bar.
    Attached Thumbnails Attached Thumbnails How do you carry your chainsaw ?-image-3323536405-jpg   How do you carry your chainsaw ?-image-3799382991-jpg
  7. #27
    Join Date
    Dec 2007
    Posts
    1,461
    Eastern Ontario
    Jinma 284(Spirit fel), MF 135 (MF200 fel)
    What whacked the saw head to bend the bar? I have the Kolpin bracket on my ATV and a homemade slip bracket in the carryall of the tractor if the bar bends from the weight of the saw head bouncing around under any conditions I'm thinking that the saw head is way too heavy I too have some pretty rough land (livestock has to graze in pairs so one can lift the rock while the other feeds) and I don't worry about the saw bracket after having it that way for about eight years -- JMHO
  8. #28
    Join Date
    Dec 2010
    Posts
    1,412
    Massey
    Quote Originally Posted by parkgt View Post
    No. Just a homemade holster that held just the bar. If the device supports the powerhead also, there shouldn't be a problem.
  9. #29
    New Member
    Join Date
    Nov 2005
    Posts
    23
    Northeast CT
    John Deere 3120, John Deere 332
    Nice.
  10. #30
    Join Date
    Jul 2009
    Posts
    94
    Santa Cruz CA
    BobCat CT230
    Here's mine all from scrap... The plastic bar cover was part of a case that the local hardware store lost so they gave me the other half for free. The bottom of the bar cover was cut out to avoid water /debris accumulation. The assembly mounts with a single 5/16" bolt and "clamps" around the splash guard 1" steel pipe on the tractor.
    How do you carry your chainsaw ?-chainsaw-mount-1-20120707-1917-aHow do you carry your chainsaw ?-chainsaw-mount-populated-20120708-1731-a
Similar Threads
  1. AZ carry
    By BoFuller in forum Rural Living
    Last Post: 09-13-2011, 02:04 PM
  2. Carry all done
    By Freds in forum Attachments
    Last Post: 12-23-2010, 08:18 PM
  3. Carry all
    By lunbrjck in forum Kioti Owning/Operating
    Last Post: 09-04-2009, 07:41 PM
  4. Carry-all
    By billbill1 in forum Chinese Tractors
    Last Post: 11-24-2004, 04:59 AM
  5. How to carry a chainsaw?
    By JC4HD in forum Chainsaws
    Last Post: 03-29-2002, 09:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
