Page 5 of 7 FirstFirst ... 234567 LastLast
Results 41 to 50 of 69
  1. #41
    Veteran Member coobie's Avatar
    Join Date
    Sep 2004
    Posts
    1,587
    S.Michigan
    Kubota RTV 900, JD 740,Kioti DK 40 with KL401 loader 2011 ford F250.
    Default Re: LED Lights
    Quote Originally Posted by pedalstomper78 View Post
    Saw the XK Glow ones and Northern tool. Pricey! The ones from Tractorhelp.com are $55 each right now.
    I found the same set at www.towtruckleds.com for $179 shipped so I bought another set for the rear of my Kubota RTV 900.coobie
    Kioti DK40se with KL401 loader,Kubota RTV 900,John deere X740,Kioti 73 inch tiller.Ingersoll 4020 3pt,troy bilt tiller,Billy goat brush cutter.
  2. #42
    Join Date
    Sep 2004
    Posts
    1,587
    S.Michigan
    I looked those up and there 27watt 2100 lumens the XK glows are 35 watt 2800 lumens.coobie
  3. #43
    Gold Member Furu's Avatar
    Join Date
    Nov 2009
    Posts
    465
    Washington
    JD 4720
    I have noticed a lot of the web sites do not list the lumens. Not being an LED expert can one expect that the same watt LED from one web site to another is the same lumens approximately for comparison purposes?
    The other thing is that some web sites state that the unit is shockproof etc and others do not and even on the same site a 27 watt may be shockproof but a 35 or 42 watt is not. Is this because they are not or is it a just lack of description space and attention to detail in the description?
    I notice the difference in pricing between one site and another on the 27 W and again on the 50 W floods is rather large.
    JD 4720 - 400CX FEL, Woods BB-720 Brush Bull and BH90X backhoe, Salsco 6210XT PTO Chipper, Farmi 501 Logging Winch, Bo-Dozer Grapple, LP RBT4096, Cammond Road grader/leveler and Rankin Trash Forks
  4. #44
    Silver Member msb1766's Avatar
    Join Date
    Oct 2007
    Posts
    193
    Guilderland, New York
    2010 SC2450 Cub Cadet/Yanmar 2003 Craftsman GT5000 1969 Wheelhorse GT14 1969 Gravely L 5' Back Blade Subsoiler/Middlebuster 52" Ratchet Rake
    I received my 50 watt flood light today and it is heavy and really well built.
    Here are some pictures of the light:LED Lights-img_0554.jpgLED Lights-img_0556.jpgLED Lights-img_0557.jpgLED Lights-img_0558.jpgLED Lights-img_0559.jpg
    I will get more pictures up once I get it all wired up.
    Cub Cadet/Yanmar TLB Sc2450, Ratchet Rake, Front Snowblower, Back Blade, Spreader, Middlebuster.
    Craftsman GT5000
    Wheelhorse GT-14
  5. #45
    Silver Member cschulz's Avatar
    Join Date
    Jun 2011
    Posts
    203
    Ortonville,MI
    Kubota BX2660
    Here is a much better company than dealing with ebay/ chinese. They have a much better variety and pricing also. Similar chinese products but an american company to deal with direct over the phone or in person if you live in california.LOL Check out the prices on the HID kits also. I bought HID for my truck and they have been going strong for 3 years now.
    http://www.ddmtuning.com/Product-Cat...uck-ATV-Marine
    Chris
    2011 Kubota BX2660 Loader/ 60"Mower
    My Tractor Tools QA and Grapple System
    BT601 Back Hoe
  6. #46
    Veteran Member dstig1's Avatar
    Join Date
    Apr 2010
    Posts
    1,909
    W Wisc
    Kubota L3130
    I just added 4 LED lights to my tractor for winter snow removal needs. I picked up 4 of the 27 W floods from seller "ledstores" on ebay. They sell the typical China stuff, but are based in the US so shipping was pretty quick. You have to specify flood or spot when buying from them or they will randomly pick for you. I assumed the floods were more suited for this.
    Pictures are lousy as I only had my cell phone on me and it was getting dark when I finished. The brackets were a bit of a lucky find. The metal place had some alum 1/4" that had been bent into a shallow channel in the drops piles, so I grabbed one of those pieces and sliced it into 2, drilled a couple holes, and milled a slight recess so they would stay put on the ROPS. Basic flat alum bar plus bolts for the retainer brackets. I kept them all to the inside for door clearance as there was only an inch or two before and I didn't have much to spare. Basically 2 facing forward (the outer ones), 2 facing back, and they can rotated and adjusted as needed. Separate switches for forward and back sets ran directly off the battery on a new 15A fuse. Wires were run in split loom tubing up and around the back side of the ROPS using those zip tie mounts with foam tape on them. It is reasonably clean install and should do the job.
    This should do the trick...
    You can see the red light on the switch box inside the ROPS at the lower right. Only the front set is on.
    -Dave
    "Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
    L3130HST, QA, 723 Loader, 48" Forks, 48" Grapple, Ancient Farmi Skidding winch
    Trailer - 10k/16' twin axle w/elec brakes
    2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
  7. #47
    Gold Member Boeing's Avatar
    Join Date
    Sep 2010
    Posts
    416
    Botetourt, Va
    kubota L3010
    I posted about LED vs. Flourescents in another post but I was mainly asking about inverters. Wanted to give my 2 cents here though. I have 12V batts recharged by solar panels in a shop building in Virginia. I started with incandescent screw in bulbs but used alot of current and gave little light. (60W) I went to Flourescent, equivilent 60's and use 15Watt. These bulbs were blowing out within a WEEK...???? I have pretty much narrowed the cause to the solar charge controller when it cycles from 19V to 16V to 14.6V......the CFL's can't take that.
    I bought LED's thru E-bay. Two different types, both screw in, both 6 WATT and both put out ALMOST as much light as the flourescents. So far they seem unaffected by the voltage changes. The two types are....1) normal looking screw-in bulb with 6 internal LED's about $18. 2)The other type is also screw-in but has a round, square shouldered base that protrudes like Capt. Video's "ray gun" (anybody old enough to remember him?) This bulb, also from E-bay, was only about $6.00. Both put out equal light and have survived voltage spikes. For household/barn use (non-mobile) hope this helps. Rob
  8. #48
    Silver Member Hammy's Avatar
    Join Date
    Aug 2007
    Posts
    167
    Spokane, WA
    Kubota MX5000 4x4
    Has anyone else found the tractorhelp.com website horrible? I've tried submitting an order for the past couple of days but it wont let me submit my payment to finalize it. The website is also extremely slow. I tried making an order on a couple different computers, different internet, and even my iPhone but all failed. I was going to call and place an order but they have no phone number? Heck, I don't even know where they're based. Someone said in the USA, how do we know for sure?
    Anyway, just seeing if its just on my end or if you guys have found this true as well? I sent them an email but haven't heard back.
    Kubota MX5000 4x4, Woods LC108 loader w/72" Q/A bucket, Woods BH90-X backhoe w/ hyd. thumb, tooth bar, ANBO GR-M6 grapple, loaded R-4 tires.
    AND A GREAT WIFE!
  9. #49
    Join Date
    Aug 2007
    Posts
    167
    Spokane, WA
    Kubota MX5000 4x4
    Quote Originally Posted by Hammy View Post
    Just an update...
    I heard back from Tractorhelp.com and it turns out they were having some server issues but its getting taken care of. And to answer my question about being located in the good old USA? Yep, in Ohio.
    They look like a really good company that I would like to do business with and their response to my email was great. I thought I would pass the word on in case anyone else was having an issue with their site. Don't give up on them, their working on it.
    Take care
    AND A GREAT WIFE!
  10. #50
    LRH
    LRH is offline
    Join Date
    Oct 2005
    Posts
    229
    GA USA
    '97 NH Boomer 1925 HST 4WD, // Kubota B3030 HSTC
    Regardless of what lights one purchases; put the nut/lock washer for both the vertical/horizontal adjustments in your scrap/junk/extra hardware box/drawer/trash can and use flat washers @ all locations lubed with just a finger rub of oil/light grease and lock nuts; tri-crimp interference style 1st choice, Nylock 2nd choice. This will allow adjustment without CCW rotation loosening the the nut as well as CW rotation causing binding/possible cracking of cast aluminum housings. Just a firm turn will make tweaking the aim easy and vibration will not change the aim. If after a few years the lamps are hard to turn, just loosen the lock nut a few degrees. Just a suggestion; it has always worked better for me on things that might need to be tweaked/adjusted at some point. On some applications a nylon oil drain gasket sandwiched between two flat washers works well where easier turning is desired.
    '97 NH Boomer 1925 HST 4WD / 4' Bush Hog Squealer / RDTH 60 finishing mower / old unknown make rear blade & unknown disc /40+ year old 6' IH labeled ex highway dept rotary cutter / misc other.
    new: Kubota B3030 HSDC
Similar Threads
  1. LED Lights
    By SpringHollow in forum Power Trac
    Last Post: 02-06-2013, 08:40 AM
  2. LED Lights
    By MikeyB in forum John Deere Owning/Operating
    Last Post: 11-23-2012, 08:07 PM
  3. LED Lights
    By Red Horse in forum Trailers & Transportation
    Last Post: 07-06-2012, 11:21 PM
  4. What to do with these LED Lights
    By woodlandfarms in forum Power Trac
    Last Post: 01-23-2012, 12:58 AM
  5. led lights
    By tjferns in forum Projects
    Last Post: 12-25-2011, 11:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
