Page 6 of 7 FirstFirst ... 34567 LastLast
Results 51 to 60 of 69
  1. #51
    Gold Member xring100's Avatar
    Join Date
    Dec 2012
    Posts
    436
    Livingston County, Michigan
    Kubota M8540
    Default Re: LED Lights
    Hey Guys i'm new to the forum but i Mounted two Rigid Industries Dually Wide angle D2's (Made in USA) on my M8540
    These things are 27 watts but produce almost twice the light output as a standard 55 watt halogen. They do produce heat as others have mentioned in this post. I mounted them using a RAM mounts so i can easily adjust them or face one backwards and one forwards. My 35 watt Kubota rear work like looks like a flashlight compared to these things. I should really set up my SLR to take some comparison shots of the Tractor head lights compared to the Rigid. at approximately 100 yards distance from tree line to my barn. with the LEDS on i light up an area about 50 -100 yards wide at the tree line depending on placement. Switching the tractors high beams on only makes a miniscule difference in the light being thrown out.
    These lights are not cheap but besides being made in USA rigid also includes a full wiring harness with OE type waterproof connectors a lighted switch and relay. I typically only use the stock headlights when traveling public roads
    Dually D2s (Set of two)
    LED Lights-2012-03-07_18-28-23_211.jpg LED Lights-2012-03-07_18-28-12_943.jpg LED Lights-2012-03-07_18-47-58_588.jpg LED Lights-2012-04-06_10-09-38_563.jpg
  2. #52
    Veteran Member bandit67's Avatar
    Join Date
    May 2004
    Posts
    1,539
    Foothills, Colorado
    B3000 HSDCC
    Quote Originally Posted by xring100 View Post
    That's some serious light. I've been considering putting those in the stock fog light mounts on my Super Duty. Only concern is I may not be able to run the fogs all the time like I do with the stock ones because they may be TOO bright for oncoming traffic.
    2012 Kubota B3000, block heater, filled rears, rear wheel spacers, fender extensions, LA403 w/60" bucket, BH77 w/12" bucket & mechanical thumb, Kubota pin-type QA, Kubota forks, Caroni TM1600 flail, Buhler Allied YC6010 3pt blower, Meyer 72" FEL mounted plow, Midwest LR2072 rake
    Previous machines:
    2008 Kubota B3030 (Open Station), LA403, BH75, 4 - 55w halogen front & rear ROPS mounted worklights with L39 dash switches
    2004 Case NH DX24E Subcompact
    Kubotas from Barlow's
  3. #53
    Join Date
    May 2004
    Posts
    1,539
    Foothills, Colorado
    B3000 HSDCC
    Quote Originally Posted by LRH View Post
    Nylock 2nd choice.
    A word of caution: DO NOT use nylock nuts in cold climates without also using Lok-tite. In the cold, the nylon must shrink a bit, and probably also gets slick, and the nuts can just back right off from the vibrations. I learned that the hard way 5 years ago. Ever since, when I've had to install nylock nuts, I've added Lok-tite and never had that problem since.
    Previous machines:
  4. #54
    Join Date
    Dec 2012
    Posts
    436
    Kubota M8540
    Quote Originally Posted by bandit67 View Post
    Bandit your right these things throw out a ton of light i was afraid if i bought the original dually diffused that they wouldn't have enough light output and didn't want buyers remorse. i think they would have been been fine but have no regrets.
    If you got the driving lights for your F250 you wouldn't need the low or high beams on your truck. Plus they would be great to flip on when some moron coming at you fails to turn off his high beams after being warned. I used to love doing that when i had two 150 watt sealed beam KC day lighters.
    I've actually sent Rigid a request to build a Set of DOT approved lights i think they would be awesome.
    Duallys Diffused (Set of two)
  5. #55
    Elite Member Scooby074's Avatar
    Join Date
    Aug 2006
    Posts
    4,419
    Nova Scotia
    BX 25
    Click image for larger version.
ID:	292304 Click image for larger version.
ID:	292296 Click image for larger version.
ID:	292297 Click image for larger version.
    Interesting idea in using the RAM mounts. I'd have never thought that, even though I use, and LOVE Ram products for my GPS and phone mounts.
  6. #56
    Join Date
    Dec 2012
    Posts
    436
    Kubota M8540
    Default
    Quote Originally Posted by Scooby074 View Post
    Thanks i use the ram mounts on my motorcycles for gps and cup holder as well. I've never seen them used before for lights but as an engineer i was trying to come up with a good solution, this works well. One of these lights facing forward and one rearward for moving snow with a backblade works well. As you know it only takes seconds to reposition a RAM mount
    Dave
  7. #57
    New Member ilucas's Avatar
    Join Date
    Aug 2012
    Posts
    10
    Southern NH
    Kubota L3710
    Have them on my F350 for back up lights when plowing......went with the d2's also (difussed)...now I want them on the tractor, lawn mower, boat.......
    I noticed on 4shorts thread, his alley lights look exactly like the dually d2's but when i went to the site where he bought them they look more like a knock off manufacturer and about 30% less expensive. Just curious.....that was one heck of a thread 4 shorts!!!! Awesome!
  8. #58
    Veteran Member 4shorts's Avatar
    Join Date
    Jul 2008
    Posts
    2,395
    Bay Roberts, Newfoundland, Canada
    Custom 2011 Kubota 5740 HSTC-3, Grand Cab. Yep. Life is grand! 2013 Kubota BX25D.
    Quote Originally Posted by ilucas View Post
    Ya I noticed he don't have the same lights that I bought from him. Totally different. Not sure why that is
    Now that I've had the opportunity to use my LED's at night with all this snow we have I got three problems.
    #1. There to bright . It's crazy how bright they are in a good way
    #2 They are so bright that when I turn them off while traveling on he road and turn on the tractors OEM lights it seems like I have no lights at all on
    #3. I just never want to turn them off
    Glad you enjoyed that thread. If you want to see how the lights worked out I uploaded a night vid last evening.
    Night video Jan 28 2013 - YouTube
    ...Excellence is not just a skill. It is also an attitude...
    Photo's of my restoration work and tooling: http://www.flickr.com/photos/15602393@N05/
    YouTube Video's: http://www.youtube.com/results?searc...rch_type=&aq=f
    2011 Kubota 5740/854 FEL/L2674 Blower/Artic Angle blade with 3rd function set up,Rain Tracker Wiper system, custom built vertical exhaust,Grammer Air Ride Seat and other custom stuff
    2013 Kubota BX25DTLB With Wallenstein BXM32
    Kubota ZTR ZG 222 Z
  9. #59
    Join Date
    Aug 2012
    Posts
    10
    Southern NH
    Kubota L3710
    haha....the light video was excellent.... it was so good that I think I may put a 14" light bar on the plow frame between the 2 Intensifier lights on the Fisher and wire them to the upfitter switches!
    Nice that you knock down the street banks for that woman.... I love to do that too!
    Thanks for sharing!
  10. #60
    Join Date
    Sep 2010
    Posts
    128
    Mississippi
    Kubota M9540 HD 4x4
    Those of you that have mounted led work lights, do you prefer the spot or flood lights. Also, do you prefer the 18W or 27W? I don't need to light up a field, just have enough light to feed hay with.
Similar Threads
  1. LED Lights
    By SpringHollow in forum Power Trac
    Last Post: 02-06-2013, 08:40 AM
  2. LED Lights
    By MikeyB in forum John Deere Owning/Operating
    Last Post: 11-23-2012, 08:07 PM
  3. LED Lights
    By Red Horse in forum Trailers & Transportation
    Last Post: 07-06-2012, 11:21 PM
  4. What to do with these LED Lights
    By woodlandfarms in forum Power Trac
    Last Post: 01-23-2012, 12:58 AM
  5. led lights
    By tjferns in forum Projects
    Last Post: 12-25-2011, 11:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
