Results 1 to 4 of 4
  1. #1
    Join Date
    Mar 2008
    Posts
    599
    Default Back Hoe Bucket Rebuild
    Back Hoe Bucket Rebuild-005-jpgBack Hoe Bucket Rebuild-007-jpg
    I have located this 24" bucket at the local steel salvage yard. It was in new condition but not the correct deminsions for use with my Bradco 611.
    My boom width inside is 6 1/2" ............. Bucket width is 9", 2 1/2" too wide to fit into the boom ears.
    Bucket cylinder linkage is 5" .................Bucket attathment point is 5 1/4" ( this would work with a couple shims )
    The Bucket pin holes are 1 1/2" ............ Boom pin is 1 3/8".
    I have two problems. The bucket attachment to the boom is 2 1/2" too wide. The second is the 1/8" difference between the pin and bucket bushing size. As this is only 1/8" difference I doubt if a thin bushing would last asit would wear quickly and how would one make a bushing only 1/16" in size ? The first section that pins to the boom will have to be cut off and moved in. This would not present a huge problem if it were not for the compounded bushing problem.
    The best solution would be to look for another bucket but there are no guarantees the deminsions would be closer. Any solutions ??????
    * A month or so ago I had a post about a fixed hitch Harley type rock rake that I converted to a hydraulic pivot. This was a simple project that turned out with near factory looks and performance.
  2. #2
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,954
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Default Re: Back Hoe Bucket Rebuild
    Wouldnt the simpliest thing be to grind off the pin bushing attachments on the bucket and have a machine shop make you some to replace that are wider and the right pin size, 6 welds and you're done. They could be fit on to the back hoe and welded for a perfect fit and pins would help hold them square. Remove it after welding all you can see and touch up the remaining.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  3. #3
    Veteran Member kneedeep's Avatar
    Join Date
    Apr 2012
    Posts
    1,079
    Central AL & MS Delta
    Mahindra 3510 and Mahindra 8560 Cab 4WD
    Getting a machine shop to duplicate your bucket attachment and replacing the wrong ones on the new bucket might work, lots cheaper than buying a 24" bucket
    PROUD AIR FORCE DAD
  4. #4
    Join Date
    Mar 2008
    Posts
    599
    Gary;
    The boom width where the bucket attaches is 6.5 inches. The bucket ears are 2.5 inches too wide to fit inside the boom attaching plates. The cylinder on the lower boom bucket mounts will be fine with some shims. The very top mount on the bucket must be modified to fit the boom. This involves cutting the mounts and moving them closer. Even if I mount them on the extreme outside of the boom bushings the bucket mounts still will have to be moved. I am going to the steel yard to see how close to 1 3/8 inside diameter I can find in dom tubing. Them I can cut off one inch pieces and use the lathe to cut out the correct pin diameter.
    I have measured it every which way and these are the choices I have come up with.
Similar Threads
  1. Back Hoe bucket size
    By fastpat in forum Kioti Owning/Operating
    Last Post: 03-28-2015, 11:49 PM
  2. Help, Back Hoe Bucket Sizes?
    By CJBOTA in forum Kubota Buying/Pricing
    Last Post: 02-13-2012, 05:03 PM
  3. Back hoe bucket has two pin holes??
    By futuresweets10 in forum Construction Equipment
    Last Post: 07-20-2010, 05:19 AM
  4. Bucket for 758C Back Hoe
    By gregkabob in forum New Holland Owning/Operating
    Last Post: 12-11-2007, 12:08 PM
  5. back-hoe bucket extension
    By IndiantownFla in forum Build-It Yourself
    Last Post: 12-15-2003, 09:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
