Page 2 of 7 FirstFirst 12345 ... LastLast
Results 11 to 20 of 62
  1. #11
    Gold Member gkh7890's Avatar
    Join Date
    Sep 2007
    Posts
    252
    SW Ohio
    DK40SE HST
    Default Re: Need more HP in my 2012 gmc 2500 6.0L
    I have to agree on the duramax option. No disrespect intended with this....but why would you pay $30K to $40K or more for a new truck and then void the warranty for 100-150hp? I'd trade it in for duramax if I were you! If you've got the deep pockets.....go for it.
    Can you turn it back in on that new program GM has "if you don't like it?"
    Good luck!!
    _____________________________________________
    2010 Kioti DK40SE HST
    401K FEL
    Brush Bull 72, 6' disc, Homemade pallet forks
  2. #12
    Join Date
    Jan 2012
    Posts
    933
    2012 John Deere 3520 Deluxe Cab
    I think you made a big mistake. Your considering a supercharger? By the time it is said and done, you have voided your warranty, most likely will have tuning issues, later on blow your engine due to a bad tune (happens all the time) and then before the blown motor will have spent more than what the deisel would have cost. Even so if all went well intially, that motor wont last long becuase it wasnt setup for blown application with forged internals it will live a short life with the towing. Leave the truck oalone or cut your losses and learn your fromyour mistake. Should have gone deisel from the beginning bud. Sorry to piss on your parade but you should have did more research before your buy. I have an extensive history with doing blown and turbo applications in mustangs so just wanted to let you know, its not something that you do once and all will be good and dandy for the next couple years.
    Also, gears are the only thing that will make a difference. intake and exhaust will not make any seat of the pants gains. only gains on the dyno but minescule. A programmer wont make anything noticeable either. Programmers will only make huge gains on deisel applications
  3. #13
    Join Date
    Jun 2007
    Posts
    888
    So. Maine
    Kioti 3054xs TLB
    Quote Originally Posted by AGRIMAN View Post
    I guess it depends on what your plans are for the truck, but I think 4.56s are a bite much for a daily driver on 35s. A Super Charger or Turbo will wake it up.
    I would opt for 4:88's. My Tundra's stock ratio is 4:30's on original 275 65 18's(31.5" tall) and it works well
    2004 3054xs
    1231 FEL
    Markham tooth-bar
    2376 BH, 9 and 18 inch buckets
    DR PTO chipper
    Blizzard B74 sno-blower
    250 hrs
  4. #14
    Join Date
    Apr 2012
    Posts
    743
    pa
    kubota 7040sud
    do have the 4.11 gear rears in it how much do u want to pull with it i put 12k with my 3500hd srw gasser 4.11 gears reg cab its not a race car only have 322hp from factory it pulls fine i would not do any thing the voids your warrenty thats just plain dumb
  5. #15
    Platinum Member Katahdin's Avatar
    Join Date
    Dec 2010
    Posts
    753
    Scarborough, ME
    Yanmar LX4500, Toro z420
    Stock 40 inch tires, 135hp, 6.72 gears, its all I'll ever need. I've got maybe 5 grand in it. Programmable what?
    Need more HP in my 2012 gmc 2500 6.0L-deuce_tractor-jpg
  6. #16
    Super Member WilliamBos's Avatar
    Join Date
    May 2004
    Posts
    5,061
    Innisfil, Ontario, Canada
    MF 1635 12x12 Powershuttle
    Trade for a Duramax.
    Thanks,
    Will
    2017 Ram SXT 1500 Crew Cab 4x4 5.7 Hemi 6 speed auto.
  7. #17
    New Member
    Join Date
    May 2012
    Posts
    20
    Mo
    Kubota 3130
    Im new here but not new to the lsx engine world. You have a solid performance platform. Get a cam headers and a whipple supercharger. If you went with heads too you could add 200hp no problem and keep reliability. If you want to keep it alive go with a good dyno tune. When shopping for a tune ask if they use hp tuners in my opinion its the best for forced induction. Look at ls1 tech or lstruck.net. I had a dd 05 4x4 2500 with the 6.0 it made 700hp at the wheels on a mostly stock bottom end. It was a monster. That was a turbo truck. I would still have the truck but sold it a dyno day I had no plan to sell but a guy made me a offer i couldnt refuse.
  8. #18
    Gold Member
    Join Date
    Feb 2011
    Posts
    405
    princeton nc.
    JD 2320
    and the cost to add 200 hp th the 6.0 would easily trade him into a DMAX and get him a truck that can actually PULL something instead of being PULLED by something when it breaks down from trying to tow with a hi hp gasser.. the 6.0 in stock form will be his limiting factor for towing and turning up the hp will not make it any better.
    2010 JD 2320, 200cx, Frontier 1060R RFM, 2048 BB, LR1072 rake, IMatch, 5 suitcase weights.
    NEED MORE IMPLEMENTS!
  9. #19
    Join Date
    Jul 2007
    Posts
    874
    WV
    John Deere 1026R
    Default
    Quote Originally Posted by shortthrow50
    So true! Risk/reward not worth it for a daily driver. If you want power buy a duramax then spend 10k getting dual turbos to keep the drivability in check, bigger injectors, and a fueling chip.
    If you want cheap and powerful buy an older dodge Cummins, but be prepared for dodge handling and rust!
  10. #20
    Join Date
    May 2004
    Posts
    5,061
    Headers are a waste of money, and factory manifolds flow better than in the past,more powerblock BS!! Your warranty will be voided the second the supercharger is added! There goes any resale value if you trade it in! Programs for fuel mileage are total BS, and a waste of money. Get a Dmax, because it will be cheaper than modding the 6.0!!
    Thanks,
    Will
Similar Threads
  1. 2010 GMC 2500 6.0 gas
    By Skinnyman in forum Trailers & Transportation
    Last Post: 09-10-2012, 08:27 AM
  2. GMC 2500 Towing Capacity
    By abb in forum Trailers & Transportation
    Last Post: 01-31-2010, 11:09 AM
  3. 08 gmc 2500 HD
    By GreatWhitehunter in forum Trailers & Transportation
    Last Post: 02-22-2008, 12:36 PM
  4. GMC 2500 4x4 pricing
    By ShantyBranch in forum Related Topics
    Last Post: 10-27-2001, 09:05 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
