Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,128
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: Allis Chalmers WD 45 power steering conversion
    there's this wonderfull thing out there called the internet. One of it's features is a search.
    i like google.. but there are many others.. including bing.. etc..
    Here's one of the 68 trillion hits i got on 'orbital valve' taks about them a lil bit.
    Rockstomper.com
    If i was a betting man.. I'd bet that 'steering motor' might turn up similar amounts of results.
    post back if ya need some more ideas.
    ( they are just ways to convert from mechanical stering box to power steering.. the basics of which are a pressurized DA cyl or a pair of SA cyls, specific valving, and a pressure source... )
  2. #12
    Bronze Member biker4jc's Avatar
    Join Date
    Aug 2012
    Posts
    82
    Burton Mi
    AC WD 45, JD 212
    Took your advice and looked it up. Found a very informative website on how Hydro steering works. It was done by a guy who'd into extreme 4X4, but the terminology and technical stuff was very accurate. I guess from what I understand of hydraulic steering, aka "fully power", I imagine I'm more interested in a power assist type of unit. I did want to thank you though Soundguy as you did force me to learn, exactly what I asked for.
    The hydraulic steering directional control valve / metering section is the heart of the system. Note, many many people erroneously refer to this as an "orbital valve". This is incorrect. The hydraulic industry does not refer to them as "orbital valves". Orbital is a nomenclature (name) reserved for referring to a specific type of hydraulic motor, that has nothing to do with hydro steering. Not one of the the 3 major US manufacturers refers to their steering valves as "orbital valves". However, Eaton/Car-Lynn does market a hydrostatic steering unit that has the trade name Orbitrol™ and this may be where the error originates.
    This is a brief excerpt from what I read. Again, many thanks Soundguy for helping me with the research!
  3. #13
    Join Date
    Mar 2002
    Posts
    42,128
    Central florida
    psc calls theirs an orbital steering valve, many just call them steering control valves.
    I know you think the lil blurb you posted means alot.. but if you call any hyds supply place and mention orbital valve.. they will know what you mean.
    that and steering motor.
    just common terms nowadays.
    have fun building your power steering setup.
  4. #14
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    The power steering on the old WD 45 (not old at the time we had it) was just an inline hydraulic motor of some kind. It was basically cut into the steering rod prior to the gear box in front. I dont remember where the hydraulic power came from. I suppose this was one of the orbital motors soundguy has mentioned. It wasnt like the hydrostatic steering of today the has a hydraulic cylinder to move the wheels. As I recall, it was a pretty large mechanism 6-8" or so in diameter but I could be wrong on the size as everything I remember from back then as being larger than they are today. I guess this is due to seeing from a childs eyes. I was pretty young then, but still old enough to drive the WD which took some getting used to using the hand clutch when mowing with it rather than the foot clutch. After a little break-in period, the hand clutch was smoother to use than the foot clutch for easing back on implements for hookup. This was the first tractor we had with PS so I got to drive it while my Dad drove the 861 Ford.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  5. #15
    Join Date
    Mar 2002
    Posts
    42,128
    Central florida
    the description reminds me of an old power steering setup for a farmall.. right inthe rod before it enters the hood.
  6. #16
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    This one was right in the rod just before the steering gear box on the tricycle front end. It did work well though.
  7. #17
    Join Date
    Mar 2002
    Posts
    42,128
    Central florida
    i seen a farmall M or 300 thathad one mid rod right before it entered the hood. charlynn maybee?
  8. #18
    Join Date
    Mar 2003
    Posts
    631
    Northern Maryland
    Kubota B82004WD
    Just in case they might help, here are a couple of photos of the Kubota supplied after-market power steering kit I added to my B8200 10 years ago. The steering link was removed, and this valve unit went in its place. The valve controls the push-pull cylinder, and I believe it's an assist like what you are after. Works great, and not too complicated if I could install it.
    Attached Images Attached Images
Similar Threads
  1. Replies: 9
    Last Post: 02-28-2012, 04:26 PM
  2. Allis Chalmers 610 re-power
    By Johndeere3720 in forum Parts/Repairs
    Last Post: 09-02-2011, 07:44 PM
  3. power steering conversion
    By gbeerman in forum Mitsubishi/Satoh
    Last Post: 05-03-2011, 06:00 PM
  4. 5030 allis chalmers/ clutch housing/pwr steering
    By willyecoyote in forum Parts/Repairs
    Last Post: 11-20-2003, 02:17 PM
  5. Power Steering Conversion Kit for MF 35
    By dourobob in forum General Vintage Tractors
    Last Post: 09-11-2002, 07:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
