Results 11 to 20 of 94
09-26-2012, 09:37 AM #11Super Member
- Join Date
- Oct 2003
- Posts
- 7,344
- Location
- Northeast, Ohio
- Tractor
- TC-40D SS New Holland
09-26-2012 09:37 AM # ADS
09-29-2012, 04:14 AM #12Platinum Member
- Join Date
- Oct 2011
- Posts
- 750
- Location
- NJ
- Tractor
- Ford 2600, NH TC-25, Bobcat M610, JD X534, DigIt Model 158
Re: New LED lighting for half the price
I looked at a few of the sellers ads and noticed that the work temperature range he gives is -45c to +5. 5c is 40f, this can't be right. Is there any better information on operating temperature range provided with the lights?
09-29-2012, 06:33 AM #13
I think that was a listing error with a zero left off after the +5.
-40c to + 50 c would be more logical, (-40F to 120F)
I don't remember seeing specs listed on paper it the boxes.
The lights came bubble wraped in small boxes that fit in a shipping envelope.
no fancy retail display box with literature to reduce packaging and shipping cost most likely.
I must say they work very nice. iI have only used them in temperatures from 80F down to 42F so far.
The housing for the light is made of a cast aluminum with heat disapating fins on the back.
Nice stainless steel bolts and brackets.
Tom
09-29-2012, 07:45 AM #14Veteran Member
- Join Date
- Feb 2004
- Posts
- 1,063
- Location
- Vanderbilt, Michigan, USeh?
- Tractor
- Mahindra 5035, JD 2240, 420
The big problem with LED lighting in the winter usually involves lights on the rear of tractor trailers [ brake, tail, marker ], where they get packed with snow in the back draft of the trailer. They also suck in some traffic lights and can get covered in snow under certain wind conditions. But these flood type LED lamps get warm enough so that tractor lighting does not seem to have a problem..even when snow blowing. Several folks have mentioned that they do not attract skeeters/moths/etc. at night, too..
2011 Mahindra 5035 HST/loader/595 hoe/18" bucket, 48" QA forks, 1981 JD 2240 Reverser 51ptoHP/2.5 tons of snarling fury, 6' Ford backblade, 30" reinforced dirt scoop, homemade boom, 79" JRW rear snowblower, Son of Jinma 8" chipper, 2002 BR Dodge Cummins H.O. 6spd.
01-08-2013, 03:53 PM #15Member
- Join Date
- Oct 2008
- Posts
- 26
Big Dooley, just wanted an update on your LED lights? Still working good for you? I'm looking at the 27 watt lights from the same seller.
01-08-2013, 05:49 PM #16
2007 JD 2305, 2008 JD 2520 w/200cx loader, Harbor Freight quick hitch, homemade pallet forks, 5' KK tiller, 5' KKxb disc, 4' landpride pulverizer, Frontier RB1072 blade, homemade 5 1/2' lawn roller at 3500lbs, 2005 John Deere 797 w/60" deck, 2009 John Deere 997 w/ 72" deck, 2005 JD HPX Gator w/power dump, 1998 Toro 455D 10.5' deck!
01-08-2013, 05:59 PM #17
2012 JD 2320, HOMEMADE CANOPY, 54" FRONT BLADE, 54" MID DECK MOWER, HYDRAULIC ANGLE 60" REAR BLADE, QUICK HITCH, STAINLESS FRONT MOUNT SPRAY TANK W/BOOM, 200CX LOADER W/ 61" BUCKET, HOMEMADE BALLAST BOX,HOMEMADE BUCKET GRAPPLE
1998 "BIG DOOLEY" Chevy K3500 Crew Cab (36.000 miles & counting)
United Steel Workers Union 12934
01-09-2013, 09:06 AM #18Member
- Join Date
- Oct 2008
- Posts
- 26
Thank you to Big Dooly and newt92 for the recommendations. For any others that are searching, here is a link to the ones I just bought: 2X 27W High Power LED Light Jeep Wrangler Offroad Folklift Komatsu Bow Fishing | eBay
01-09-2013, 11:53 AM #19Member
- Join Date
- Oct 2008
- Posts
- 26
I see some discussion about using a relay for lights. Why would you use a relay and not just a switch in the hot leg of the wire going to the lights?
01-09-2013, 12:11 PM #20
"As you go through life, make this your goal: watch the donut, not the hole"
Kubota B7800
BH-75A Backhoe
Rhino 60'' finish mower
Similar Threads
LED flashlights for tractor lighting - Will it work??!!!
By beppington in forum ProjectsReplies: 16Last Post: 01-02-2012, 04:29 PM -
LED Lighting
By California in forum Related TopicsReplies: 43Last Post: 10-28-2011, 09:21 AM -
Does LED lighting work for artificial plant light?
By arsenix2001 in forum AttachmentsReplies: 5Last Post: 08-02-2011, 05:58 PM -
LED Lighting Experience?
By daveinnh in forum Owning/OperatingReplies: 17Last Post: 05-21-2010, 11:39 AM -
Half Price
By TWO GUNS in forum ATVs & Utility VehiclesReplies: 0Last Post: 10-25-2008, 09:48 AM
