Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
  1. #11
    Join Date
    May 2012
    Posts
    975
    Default Re: led lights tying into factory lights? Kubota L4330
    Quote Originally Posted by JRP View Post
    If you wire an LED backwards it it a short circuit. They conduct when forward biased, and glow when reverse biased. Be sure to observe polarity.
    I'll mention that to him. Thanks.
    "The only thing necessary for the triumph [of evil] is for good men to do nothing." Edmund Burke*
    “If you continue in My word, then you are truly disciples of Mine;and you will know the truth, and the truth will make you free.” Ancient of Days
  2. #12
    JRP
    JRP is offline
    Join Date
    Aug 2001
    Posts
    590
    South Texas
    Kubota M6800
    Default
    Well, I'll be the first to point out I was wrong. Disregard what I wrote above.
    JRP
  3. #13
    Join Date
    Nov 2011
    Posts
    589
    Southwestern Virginia
    JD 5055E
    led lights tying into factory lights? Kubota L4330-tractor-stuff-003.jpgled lights tying into factory lights? Kubota L4330-tractor-stuff-002.jpgHere is my nothing fancy installation. Two 27 watt LED floods looking forward and two toward the rear. All are fed from the 10 amp work light circuit.
  4. #14
    JRP
    JRP is offline
    Join Date
    Aug 2001
    Posts
    590
    South Texas
    Kubota M6800
    Default
    Quote Originally Posted by Notforhire
    <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=284938"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=284937"/>Here is my nothing fancy installation. Two 27 watt LED floods looking forward and two toward the rear. All are fed from the 10 amp work light circuit.
    How do they work at night?
    JRP
  5. #15
    Join Date
    Nov 2011
    Posts
    589
    JD 5055E
    They seem to give plenty of light. They are floods, so I don't think they have the reach of regular headlamps, but should do well for snow removal ect. I had used regular driving lights on my last tractor, by disconnecting the headlights and tapping into that circuit. It worked well, but required more time and effort than using the work light feed. I don't do much night work, and the LEDs made for a easy hookup. Total cost was about $140 w/ brackets and wiring.
  6. #16
    Member
    Join Date
    Jul 2006
    Posts
    28
    Sherbrooke, Quebec, Canada
    Kubota L3540 w LA514 FEL
    I bought 2 12v Par-36 55 watts ATV/Truck/RV Utility Rubber Work Lamps (around 15$ each) and installed it on brackets inside the ROPS so it's not in the way when going in the woods. I connected it with the connectors that are located under the seat. I already had the Kubota 35 watts worklignt installed and connected at the same place. Since all 3 cables goes to the sams fuse that is 10 amps, I changed it for a 15 amps (35 watts + 55 watts + 55 watts = 145 watts / 12 volts = 12 amps). A 10 amps fuse is too tight for those 3 lights at the time but, since it only draw 12 amps when they are all on , it won't damage the wires. I have to admit that I never try letting them on for a very long period of time (hours). Hope it will help you.
  7. #17
    Bronze Member PandDLong's Avatar
    Join Date
    Apr 2012
    Posts
    76
    Southern Alberta
    Kubota L3540
    Can you put up a picture of inside ROPS lights - I want to do the same but I am really not sure about the brackets? Did you make them or buy them?
  8. #18
    Elite Member
    Join Date
    Sep 2003
    Posts
    3,946
    New Brunswick, Canada
    Kubota L5030 HSTC, MF 5455
    There must be a rule or something, they all do it. My Kubota and MF both are the same. On my Kubota since I have a cab with worklights I just unpluged the harness from the bulbs so I could use the running lights.
    My MF has a fancy setup so you can't use the worklights while the 4 ways are on so I have to use the grill mounted lights on the road at night. Have to almost drag the bucket or raise it silly high.
    Go for it. Stupid kubota engineers mounted M6800 headlights low, below the FEL bucket. The plastec lenses also faded milk jug white. I added two lights higher, inside the FEL frame hood guard. I clipped one wire in the factory harness that went to the factory high beam filament and wired it to the new lights. Now the low-high switch operates the factory low (dim) beam, or my high and bright beam which shine over the FEL bucket instead of into the bucket back. The work light circuit goes to the rear work light.
    Do it.
  9. #19
    Veteran Member bandit67's Avatar
    Join Date
    May 2004
    Posts
    1,539
    Foothills, Colorado
    B3000 HSDCC
    Funny all the LED posts now. Back in the old days of 2008 when I did my ROPS work lights, LEDs were way more expensive, and there weren't anywhere near the number of options that are available now. Because I used Halogens, my factory rear work light wire still sits unused.
    I wired in 2 relays off the battery (one for each pair of front & rear lights), then installed Kubota L39 worklight dash switches to make it look factory installed. If I were to ever want to add LEDs to that setup, there's enough power to run about 20,000 lumens worth of LEDs up on the ROPS.
    led lights tying into factory lights? Kubota L4330-155_5575.jpg led lights tying into factory lights? Kubota L4330-155_5563.jpg led lights tying into factory lights? Kubota L4330-worklight-bracket-1.jpg led lights tying into factory lights? Kubota L4330-worklight-bracket-2.jpg
    2012 Kubota B3000, block heater, filled rears, rear wheel spacers, fender extensions, LA403 w/60" bucket, BH77 w/12" bucket & mechanical thumb, Kubota pin-type QA, Kubota forks, Caroni TM1600 flail, Buhler Allied YC6010 3pt blower, Meyer 72" FEL mounted plow, Midwest LR2072 rake
    Previous machines:
    2008 Kubota B3030 (Open Station), LA403, BH75, 4 - 55w halogen front & rear ROPS mounted worklights with L39 dash switches
    2004 Case NH DX24E Subcompact
    Kubotas from Barlow's
  10. #20
    Join Date
    Nov 2011
    Posts
    589
    JD 5055E
    Quote Originally Posted by PandDLong View Post
    Take a look at my light mount photo, in my earlier post. Just flip the light over and they will be inside the ROPS.
    Bill
Similar Threads
  1. LED Lights
    By rider9403 in forum Customization
    Last Post: 02-14-2013, 12:08 AM
  2. LED Lights
    By SpringHollow in forum Power Trac
    Last Post: 02-06-2013, 08:40 AM
  3. LED Lights
    By Red Horse in forum Trailers & Transportation
    Last Post: 07-06-2012, 11:21 PM
  4. led lights
    By tjferns in forum Projects
    Last Post: 12-25-2011, 11:36 PM
  5. How are Kubota factory work lights wired?
    By Johnbro in forum Kubota Owning/Operating
    Last Post: 12-18-2010, 05:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
