Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Nov 2012
    Posts
    14
    wooster ohio
    pulling team
    Default cub cadet diesel puller
    i am looking to put a d1105 kubota in a cub cadet 1641 does anyone know what i need to do as far a motor mounts and also want to know if the hydro would change to the rearend in a 124 cub without much trouble
  2. #2
    Super Member
    Join Date
    Apr 2000
    Posts
    6,597
    central New York
    all makes and models
    Default Re: cub cadet diesel puller
    As much as I like Cub Cadets and Kubotas with some of the best being with a Cadet with a kubota engine I have several things that I question while writing this. Cadet did use the Kubota engines and I am unsure of the interchangability for them but I'd say the smaller engine with a parts tractor that had the diesel should have everything to make one work.
    The larger engine should really bring one to life if it will fit under the hood!
  3. #3
    New Member
    Join Date
    Nov 2012
    Posts
    14
    wooster ohio
    pulling team
    i know that cub put diesels in like the 782 and others but i did not know what the motor mounts were like and how the clutch fit
  4. #4
    Gold Member
    Join Date
    Feb 2011
    Posts
    405
    princeton nc.
    JD 2320
    Quote Originally Posted by scottyoung View Post
    there is no clutch.
    the engine is mounted backwards in the chassis
    the 1641 are for the most part identical/interchangeable on most of the hydro tractors
    but I doubt most of them will hold up to a bigger diesel than what was in the 782D's especially when in a hard pull and no tire slippage. I have broken multiple axleshafts in a 982.
    2010 JD 2320, 200cx, Frontier 1060R RFM, 2048 BB, LR1072 rake, IMatch, 5 suitcase weights.
    NEED MORE IMPLEMENTS!
  5. #5
    New Member
    Join Date
    Nov 2012
    Posts
    14
    wooster ohio
    pulling team
    will a d 1105 fit into a 124 cub without to much fabrication
  6. #6
    Gold Member
    Join Date
    Feb 2011
    Posts
    405
    princeton nc.
    JD 2320
    I don't know the dimensions of the D1105 but I would have to say no, the 124 is a narrow frame model. the 782 is a styled(wide)frame and the engine it has FILLS the framerails of the 782.
    so if the d1105 is bigger then it wouldn't fit without major modifications
  7. #7
    New Member
    Join Date
    Nov 2012
    Posts
    14
    wooster ohio
    pulling team
    i gave up on the 124 diesel idea found out that it has a cracked head now looking to put a v twin in for pulling the engine came out of a 1650 repowered i think that it should fit with minor modifing to the frame i have pulled the 124 this summer it did good just want more power . i still want a diesel puller so if any one knows where a good wide frame, perfer a 108 or that era rolling chassy with a gear rearend give me the location perfer that it is close
  8. #8
    Gold Member Bigkrank's Avatar
    Join Date
    Jan 2009
    Posts
    325
    NW Ohio
    Here is a D1105 in a 582/782 frame
    Attached Thumbnails Attached Thumbnails cub cadet diesel puller-1-09-11-jpg   cub cadet diesel puller-15-web-jpg
    Several garden tractor pullers
    Kubota B2630
    Kubota ZD1211
    Ford 655D backhoe
    Bobcat T190, various attachments
    Numerous Farmalls
  9. #9
    Gold Member
    Join Date
    Feb 2011
    Posts
    405
    princeton nc.
    JD 2320
    and NONE of it will fit under the 782 stock sheetmetal, and the 124 is a good 6" narrower!
  10. #10
    Join Date
    Jan 2009
    Posts
    325
    NW Ohio
    Quote Originally Posted by scrappy isb67 View Post
    Plenty of pics here with D1105 under stock 782 sheetmetal:
    http://sports.groups.yahoo.com/group...ractorpulling/
    Kubota B2630
    Kubota ZD1211
    Ford 655D backhoe
    Numerous Farmalls
Similar Threads
  1. 7205 Diesel Cub Cadet won't start
    By Framloe460 in forum Cub Cadet Tractors
    Last Post: 07-24-2010, 09:11 PM
  2. Oil & Fuel Cub Cadet 1572 Diesel
    By d_day2613 in forum Cub Cadet Tractors
    Last Post: 08-18-2009, 11:19 AM
  3. Oil & Fuel Cub Cadet 1572 Diesel
    Last Post: 08-13-2009, 08:07 AM
  4. Oil & Fuel Cub Cadet 1872 Diesel
    Last Post: 06-24-2009, 04:14 PM
  5. Oil & Fuel 1782 Diesel cub cadet
    By rcsavager21 in forum Cub Cadet Tractors
    Last Post: 04-20-2005, 12:27 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
