Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Join Date
    Feb 2012
    Posts
    1,716
    Albany OR
    Case 580B, Long 460, Allis-Chalmers 160
    Default Re: Solution for a Clay Packed Twelve(12) Inch Backhoe Bucket
    I built a narrow (6") ditch bucket for my 580B several years ago, have clay soil, spent as much time dumping as filling :=(
    If I ever need that function again, I'll either rent a trencher or build one of these (don't remember where I got the pic, I do a LOT of "researching", spelled T-H-E-F-T :=)
    Solution for a Clay Packed Twelve(12) Inch Backhoe Bucket-clayditchbkt-jpg
  2. #12
    Join Date
    Apr 2006
    Posts
    2,175
    western NC
    Ventrac, Steiner
    You bucket looks like a cribbing bucket. We use them to crip out the ballast between crossties on the railroad. They do pretty good for digging narrow trenches too.
  3. #13
    Member
    Join Date
    Sep 2009
    Posts
    30
    West Virginia
    1976 Economy Power King 1614
    I found this somewhere.
    Attached Files Attached Files
  4. #14
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,741
    Murray, KY
    1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
    Thanks fisherridge. Without the drawing was struggling with the design concept.
  5. #15
    Member
    Join Date
    Jan 2004
    Posts
    33
    Hi,
    That is the basically the thing I did except I welded the ends inside the bucket next to the upper edge. That way there is nothing to remove off the machine when you change buckets. I did not tie the two chains together with a cross chain, but made them quite loose, so they could flop around.
    Joe
  6. #16
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,199
    Central Ohio
    Kubota MX5100
    Quote Originally Posted by handymansvs View Post
    Hi,
    Joe
    So when you dump the bucket, the chains dont actually pull tight then??
    I would think with them attached to the dipper like in the pic, that having them draw up tight when the bucket is dumped, would be more effective?
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  7. #17
    Gold Member
    Join Date
    Oct 2007
    Posts
    440
    Levittown & Long Eddy NY
    09 kubota L4400, 4x4, R4's
    Quote Originally Posted by muddstopper View Post
    what no hand ties lol rail roader myself
    L4400 kubota
  8. #18
    Gold Member
    Join Date
    Jun 2008
    Posts
    385
    Search google for "Mythbusters cement truck"
    There are 10 types of people who understand binary, those who do and those who don't.
Similar Threads
  1. 80% Clay Loom?!? Which Bucket?
    By Lockport in forum Attachments
    Last Post: 05-12-2011, 08:32 AM
  2. My last question on Kubota 161 is 12 inch or 16 inch bucket!!!
    By millpond in forum Construction Equipment
    Last Post: 08-21-2009, 09:07 PM
  3. Backhoe Will clay soil plug up a 9" backhoe bucket?
    By sixdogs in forum Attachments
    Last Post: 05-09-2008, 06:09 PM
  4. 16 inch or 18 inch bucket?
    By HighLoader in forum Construction Equipment
    Last Post: 06-26-2007, 11:38 AM
  5. Clay difficult to remove from 9ins trench bucket
    By R_Redding in forum Construction Equipment
    Last Post: 02-12-2006, 05:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
