Page 15 of 21 FirstFirst ... 512131415161718 ... LastLast
Results 141 to 150 of 206
  1. #141
    Join Date
    Jul 2011
    Posts
    54
    Billings, MT
    kubota L3400, Farmall 'A', Farmall F-14, Ford 860, JD 4520
    Default Re: Homemade quick attach
    Rich. Thanks for posting pictures of your adaptors and such. Your receiver hitch adaptor gave me all kinds of ideas. I had the thought of building some sort of an attachment that could be welded on, cut on, butchered and altered to suit any given need as situations arose. But with your setup, I can leave it alone and simply make any adaptor to fit the attachment. Hm, it just so happens that I have an oddball reveiver hitch laying around somewhere, now if you will excuse me,,,,,,,,,,,,,,,,,,,,,,,,
    steve
    P.S., just looked at the pictures again. Any one else notice that Rich drilled out some large nuts and used them as bushings?
  2. #142
    Gold Member 600rider's Avatar
    Join Date
    Jul 2007
    Posts
    311
    union city pa
    2004 kubota b7510
    Nice catch Steve! I had not noticed that but what a great idea! dom tubing ppbbbht!
    I also like your hitch Rich! looks good and functions as it should! Kubota didn't make a QH for my LA302l .....so I DID!!
  3. #143
    Join Date
    Sep 2012
    Posts
    171
    Ottawa Ontario
    Kubota B3300SU
    I also like the hitch idea -- an completely missed the nuts. I've drilled out nuts in the past for other (similar) purposes but never thought of it for this.
    Rich, what's that trimmer attachment?
  4. #144
    Join Date
    May 2012
    Posts
    2,235
    Knoxville, TN
    Bobcat CT225
    I got a little more work done. First, I took the DOM tubing to a local machine shop, where they reamed it out to the proper size to receive the 1" pin. It cost $25, which is about as much as a reamer would have cost me, but I decided it was worth the cost to have it done right, versus me hacking away at it. All told, the DOM tubing has been the single most expensive part of this endeavor: $12 for the tubing, another $15 for the shipping, and another $25 to have it reamed out. I guess the factory bushings were also about $50, come to think of it.
    I drilled the holes with a hole saw, then put the bandsaw in the vertical position and cut straight in to make the "cup" for the top. I have been drilling my holes 1/8" oversize to allow precise placement of the bushings, but for the top hole, I drilled it exactly to size, so that I could hit the 9-o'clock and 3-o'clock position exactly with the vertical parts of the "cup".
    Cutting the DOM tubing in half lengthwise to make the bottom of the "cup" was difficult. I finally ended up just pushing it through the bandsaw in the vertical position. I did this before cutting it to length, to give me an extra few inches of tube to grip onto.
    Next, I cut the top of the side plate down. We had previously discussed leaving the back of the bracket longer than the front, to allow pushing on the implement to line up the loader arms with the implement. After thinking about how the bracket will be used, I am thinking that it may make more sense to leave the front of the bracket long, to allow for reaching out and picking up the implement, versus pushing into it. For a three-point hitch, which was the original example, it seems like having the back of the bracket long makes sense, because you can't "reach out" with a three-point. You are just going to push into the implement and then lift. But with loader arms, you can reach out and pick up, and it seems that would give better visibility, since the QA adapter would be going underneath the bucket pins.
    Next step is to tack weld the bushings in place and then get some flat plate made up to finish the vertical walls of the "cup". But I can't run the grinder while the kid is taking a nap, so I can't weld at the moment. More to come!
  5. #145
    Join Date
    May 2012
    Posts
    2,235
    Knoxville, TN
    Bobcat CT225
    I've got another question for y'all: what does the factory QA do about grease on the bucket-side? On the loader-side, I can use the factory pins that have zerks, and the loader arms and hydraulics have grease channels. But on the bucket side, none of that is true. And on the top, the pin isn't even fully enclosed. I'm not sure which would be more of a PITA: manually greasing the bucket-side pins, or cutting grease channels and installing zerks.
  6. #146
    Silver Member Sfrankland's Avatar
    Join Date
    Jun 2012
    Posts
    110
    Newfoundland
    Mahindra Max 28 XL
    Default
    The pins on bucket side do not move so they don't really need much grease. You can smear some on the pins but they will just be a mess when you remove the bucket.
  7. #147
    Join Date
    May 2012
    Posts
    2,235
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by Sfrankland View Post
    Oh, of course. It's only when the loader arms extend and retract that the pin angle changes, and only on the arm side. Thanks!
  8. #148
    Join Date
    May 2012
    Posts
    2,235
    Knoxville, TN
    Bobcat CT225
    I've got another question. In the video example on Youtube, the guy picks up the bucket with the top pins and it falls into place against the QA bracket such that the holes line up and the bottom pins can be easily inserted. How is this accomplished? What does the bucket butt up against to line up the holes? It can't be that the bracket is flush with the back wall of the bucket. It seems like that would make it too hard to pick the bucket up. Is there maybe a spacer or something?
    I can think of various ways of solving this problem, but I have a sense that there may be a much more clever solution that already exists.
  9. #149
    Super Member
    Join Date
    Mar 2008
    Posts
    6,445
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Quote Originally Posted by joshuabardwell View Post
    Usually the top hooks are J shaped to that you can pickup the bucket with them.
    Aaron Z
    If mankind minus one were of one opinion, then mankind is no more justified in silencing the one than the one - if he had the power - would be justified in silencing mankind.
    John Stuart Mill
  10. #150
    Veteran Member GPintheMitten's Avatar
    Join Date
    Sep 2009
    Posts
    1,047
    Flushing, Michigan
    Kubota B2620
    Default
    Joshua, are you going to grind the plates to clean them up before welding? ...after you kid wakes up?
Similar Threads
  1. Homemade Quick Attach Plate
    By jaquetarr in forum Power Trac
    Last Post: 10-22-2009, 10:30 PM
  2. Homemade quick attach plates
    By BobRip in forum Power Trac
    Last Post: 10-30-2007, 09:02 AM
  3. 430 Quick Attach Bucket to skid steer attach
    By CLinton_in_FL in forum John Deere Owning/Operating
    Last Post: 07-17-2006, 11:57 AM
  4. Grapple Quick Attach "Quick Clear Grapple Rod Bucket"
    By jeepinator in forum Attachments
    Last Post: 03-15-2006, 11:01 PM
  5. Quick Hitches Implement bushings for quick attach/quick hitch
    By Gary_in_Indiana in forum Attachments
    Last Post: 06-25-2003, 07:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
