herringchoker
Here are three simple (and cheap) improvements I have made to the 3 point hitch on my Kubota B7800. I built all of these from material I had laying around. (Never throw anything out!) I got all of the ideas from fellow TBN'ers.
1. Poor Man's Position Control
Since I don't have position control, I was finding it frustrating to set and re-set the cut height when using the bushcutter. A simple check chain solved that - it's been working great for 5 or 6 years now.
2. Upgraded Sidesway Turnbuckle
A simple disconnect on the right side turnbuckle saves a lot of threading and re-threading the turnbuckle when changing implements. I cut the end off the turnbuckle, welded on a 3/8" shackle and drilled out the shackle and the original turnbuckle eye pin to accept a 3/8" hitch pin. This works great, but I think doing the same thing to the left side turnbuckle will be even better. My final goal is telescopic sway bars.
3. TPH Remote Control
With the cab I built on the tractor, while changing implements it was impossible to raise and lower the TPH and watch the hitch position without climbing in and out of the cab. I'm getting way too old to be doing that, so I just installed a TPH control lever that I can operate while standing on the ground beside the tractor where I can see what is going on. Since the lever is connected to the existing linkage right at the transmission case, it can only activate the famous 1/4 inching function - no high speed movements (since they require moving the lever in the cab to bypass the 1/4" detents).
My thanks to TBN members who posted these ideas over the years.
