Results 1 to 9 of 9
  1. #1
    Join Date
    Dec 2010
    Posts
    176
    Love, VA
    Kubota B7100 HST 4WD
    Default Telescoping stabilizers for a John Deere 5300
    I made a set of stabilizers today for a friends JD5300. His turnbuckles are still holding up, but I make these for a side living, and hadn't tackled such a large set yet. I make small, medium, and large sets for tractors up to about 35 hp, and have gotten a few requests for larger machines. But, until now, I didn't have the right sized steel. These are a prototype, which I think will outperform his turnbuckles, both in strength and ease of use.
    The photos show 3 things- a medium set for a BX2360, the prototype for the JD, and a factory turnbuckle off of my own B7100, all for size comparison.
    extralarge002.jpg photo by br549_red | Photobucket
    extralarge001.jpg photo by br549_red | Photobucket
    "For I am not ashamed of the gospel of Christ..." Romans 1:16
    94 Dodge Ram 2500 CTD
  2. #2
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,836
    Frederick County, VA
    Kubota BX2360 & L4240 HSTC
    Default Re: Telescoping stabilizers for a John Deere 5300
    Those looks good.
    Also if you get the IMG code on photobucket the pics will show up directly on the forum.
  3. #3
    Member
    Join Date
    Nov 2012
    Posts
    40
    ND
    Case IH DX25E, Case 444, JD440I, JD510
    Your workmanship looks very professional.
    I don't see why they are not offered as an option at the dealership.
    Many people do not realize the need (if we are talking about the same thing). With more than one 3 point attachment, and using the tractor just about everyday, I found myself either letting the implement sway from side to side without tightening the turn buckles, or putting up with the pain of adjusting them everytime I changed equipment back there.
    So I made my own set of stabilizers years ago, when I change equipment I remove a pin from each stabilizer , move the lower lift bars off one set of lift pins on to another implements set of lift pins, and then resecure the stabilizer. See pic Telescoping stabilizers for a John Deere 5300-stabilizer.jpg
    It's a poor picture, but I have a compact tractor and can only have a short stabilizer, I needed one end to have threads for fine adjustment to get the holes line up. I also use swivels on each end. The stabilizer pictured has 4 parts: (1l) a drilled rod with swivel, (2) a threaded rod with swivel, (3) a drilled square tube for the drilled rod to slide into - the tube as a nut welded on one end for the other rod to thread into, and (4) the lock pin.
    Please disregard lower pic, I can't figure out how to delete it as it is in error.
    Attached Thumbnails Attached Thumbnails Telescoping stabilizers for a John Deere 5300-stabilizer.jpg
  4. #4
    Join Date
    Dec 2010
    Posts
    176
    Love, VA
    Quote Originally Posted by ilander View Post
    So I made my own set of stabilizers years ago, when I change equipment I remove a pin from each stabilizer , move the lower lift bars off one set of lift pins on to another implements set of lift pins, and then resecure the stabilizer. See pic Click image for larger version.
    They might be an option, although I haven't found them for this application. I am pretty aware of what is offered, and if the manufacturer already makes them, and the price is comparable or less, I will give that information to the customer. I did a search in the case of the 5300, and didn't come up with anything.
    Thank you for the complement- yours looks substantially built. I do like the idea of heim joints at both ends, although I only use them when the case necessitates them. In most cases, the original equipment and/or desigh supports clevis pins, which work fine. I use heim joints when an exceptional amount of movement is involved. Otherwise, they are an expensive item (in the case of the 5300, a little over $20 a piece my cost), and as you know, keeping a price reasonable is absolutely necessary.
    A photo of them installed- JD5300003.jpg photo by br549_red | Photobucket
  5. #5
    Elite Member Baby Grand's Avatar
    Join Date
    Nov 2007
    Posts
    2,596
    Windsor, CT.
    L3240GST, B5100D & G5200H
    A set of Mark's stabilizers really reduced the time it takes to remove and hitch up different attachemnts on our Kubota B5100.
    Very nice workmanship, great value, and Mark is a pleasure to do business with, too.
    That's the problem with trouble.
    It always starts out as such fun."
    - Randall Brown
  6. #6
    Join Date
    Jul 2004
    Posts
    1,553
    Bancroft, Ontario
    JD4300
    A few years ago JD changed their stabilizers to a pin that drops in from the top. Mine is the old style that requires you to get a mirror and lean against the muddy tire to see the hole... The dealer offered to upgrade mine but it would have been hundreds of $$$
  7. #7
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,836
    Default
    Hodge, have you thought about making some for antique tractors like a Ford 8N. You would not need the stiff arm on them then.
  8. #8
    Elite Member Mace Canute's Avatar
    Join Date
    Nov 2006
    Posts
    3,143
    Saskatoon, Saskatchewan
    Quote Originally Posted by pat32rf View Post
    My JD 3010 has pins that drop in from the top; I always figured it came that way from the factory. If someone changed them over at some point in the past I'm sure glad he did!
  9. #9
    Gold Member
    Join Date
    Jan 2011
    Posts
    468
    Fanning Springs, Gilchirst County, North-Central Florida
    Kubota B3300SU 33-hp / 1,900 pounds
    I installed STABILWORK'S (by Mark Hodge) pin adjustable lift-arm-stabilizers ((Kubota calls the Check Chains, still.)) on my Kubota B3300SU. (33-HP / 1,800 pounds)
    High quality work. Close tolerances. STABILWORKS sure saves a lot of sweat and bad words when attaching implements.
    Kubota factory Check Chains for B3300SU weigh 3.7 pounds the pair. Stabilwork's check chains/Large weigh 14.4 pounds the pair.
    Perhaps now I will be able to reverse-smooth with my 630 pound Rollover Box Blade without fear of deforming the lift arms, which are engineered to PULL not PUSH.
    BUT I WANT TO PUSH.
    StabilWorks
    Kubota tractor stabilizers Kubota www.stabilworks.com - YouTube
    Check 'em out.
    Attached Thumbnails Attached Thumbnails Telescoping stabilizers for a John Deere 5300-img_0461.jpg   Telescoping stabilizers for a John Deere 5300-img_0462.jpg   Telescoping stabilizers for a John Deere 5300-img_0439.jpg
Similar Threads
  1. John Deere 5300
    By jdonm in forum New Member Introductions
    Last Post: 06-10-2010, 12:37 PM
  2. John Deere 5300
    By jdonm in forum John Deere Owning/Operating
  3. New John Deere X520, for 5300.
    By savart in forum John Deere Lawn & Garden
    Last Post: 02-27-2010, 05:09 PM
  4. 96 john deere 5300 transmission
    By schiker in forum John Deere Buying/Pricing
    Last Post: 08-23-2009, 11:01 AM
  5. John Deere 5300
    By KRH in forum John Deere Owning/Operating
    Last Post: 12-19-2005, 08:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
