Page 6 of 7 FirstFirst ... 34567 LastLast
Results 51 to 60 of 64
  1. #51
    Elite Member oldballs's Avatar
    Join Date
    Dec 2009
    Posts
    2,872
    Kansas...USA
    Kubota B2620 , Case 448
    Default Re: Yet another bucket-mod thread
    Quote Originally Posted by mjncad View Post
    Welding and concrete work are simple in concept; but a lot more difficult to do in reality.
    You said it!!!!! and that's differance between the pro and the amateur. But most of my concrete work is...
    a. not settled b. not cracked c. not pretty.
    Kubota B2620 HST (2012) Case 448(1983)
  2. #52
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Here's a few photos from today's work. After grinding out nearly all of the 6011 welds and going over with 7018, I am adding a 2nd and 3rd pass, building up weld in the joint. I also welded the sides of the base plate and closed off the hooks per suggestions here.
    Yet another bucket-mod thread-img_1225-jpgYet another bucket-mod thread-img_1226-jpgYet another bucket-mod thread-img_1227-jpg
    I just got done putting the last set of beads on and grinding off a few little bits of spatter. Tomorrow's task will be putting on the receiver tube.
  3. #53
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,711
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    I have to say those welds dont look half bad. You are getting the hang of it. NOW if you can do that in all positions you will be on your way to becoming not a slow welder or a fast welder but a half-fast welder.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  4. #54
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,444
    Branson, Mo.
    Kioti DK35se Hydrostat
    Joshua, your welding is getting better and better.. Keep at it.. I am just a Half-"fast" welder myself, at best, on a good day.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  5. #55
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Thanks, James and Gary. I think that first pic on the left is one of the better beads I've ever run. I'm right proud of it. The fact that that one was better than the others is more luck than skill, but the fact that I got even one looking like that says to me that there's at least a smidge of skill in there.
  6. #56
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    All done! Just need to paint it up and take some final pics. I have got to remember the way that welds cool. The receiver tube is cocked just a few degrees to one side because I welded one side up before welding the other. I thought that the tacks would hold it square, but no dice. So I guess the right thing to do is a few inches on one side, then a few inches on the other?
  7. #57
    Join Date
    Jun 2009
    Posts
    27,444
    Branson, Mo.
    Quote Originally Posted by joshuabardwell View Post
    Joshua, you have probably seen this before, but it is well worth watching again. It deals with tackups and "pulling" and how to overcome it.
    ARc Welding Project -Everlast PowerPro 256 - YouTube
    James K0UA
    James K0UA
  8. #58
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    Lots and lots of clamps go a long way to keeping things from creeping around during the welding process.
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  9. #59
    Veteran Member troutsqueezer's Avatar
    Join Date
    Sep 2010
    Posts
    1,308
    Pilot Hill, CA.
    Kubota B21
    I was going to pop in with a comment after seeing your first weld passes but you've improved on them greatly so no need. I would spray the bare metal with self-etching primer before painting though.
    Ditto on the tooth bar.
    - Dennis
    Once you see the bandwagon, it's too late.
  10. #60
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by troutsqueezer View Post
    Thanks for the compliment. Those first beads were pretty bad, and I'm glad I went back and ground them out. I still have a lot of practice to do with 6011, but as long as 7018 keeps working for me, I may never get to it. ;-) I mean, I will probably do it some day, because 6011 is such a bread-and-butter rod that I couldn't respectably show my face if I could work it, but I have a long way to go with "easy" rods before I need to start challenging myself like that.
    Here's a photo of the finished job.
    Yet another bucket-mod thread-2012-12-15-15-08-a
Similar Threads
  1. bucket mod
    By 4shorts in forum Customization
    Last Post: 05-10-2012, 09:08 PM
  2. Bucket mod - hitch receivers vs hooks
    By jimmyj in forum Kioti Owning/Operating
    Last Post: 01-20-2009, 08:47 AM
  3. Bucket mod
    By Freds in forum Customization
    Last Post: 04-27-2006, 11:47 PM
  4. 4-in-1 4in1 bucket mod.
    By gray in forum Attachments
    Last Post: 11-17-2004, 11:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
