Results 61 to 64 of 64
12-15-2012, 04:48 PM #61
Re: Yet another bucket-mod thread
Great job Josh!
John Deere 4110HST
FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
John Deere 4x2 Turf Gator
View some of my projects/adventures in my Picasa Album
Simple JDParts Tutorial HERE
01-05-2013, 07:51 PM #62Veteran Member
- Join Date
- May 2012
- Posts
- 2,265
- Location
- Knoxville, TN
- Tractor
- Bobcat CT225
I got some use out of the hooks today. The attached photos show one of the main intended uses of the hooks: moving the walls that I use to turn my utility trailer into a makeshift livestock trailer for moving pigs to the processor.
I was easily able to pick up all the walls at the same time and drive them to their storage location.
01-05-2013, 07:54 PM #63
02-17-2013, 05:48 PM #64Veteran Member
- Join Date
- May 2012
- Posts
- 2,265
- Location
- Knoxville, TN
- Tractor
- Bobcat CT225
Just a quick update: after leaving my bucket out in the rain for a while, I noticed rust dripping from under the plate. I decided the best thing to do was to go ahead and stitch weld around the whole thing. Even if it may not be needed for strength, it'll keep water out from under there. The only problem was that I couldn't get an electrode in near the front of the 2" receiver, but what can you do? If anybody else is doing this and plans to go with plate instead of angle iron, I'd suggest going ahead and doing a full seam weld instead of just "enough" beads to hold.
Similar Threads
bucket mod
By 4shorts in forum CustomizationReplies: 16Last Post: 05-10-2012, 08:08 PM -
Bucket mod - hitch receivers vs hooks
By jimmyj in forum Kioti Owning/OperatingReplies: 15Last Post: 01-20-2009, 07:47 AM -
Bucket mod
By Freds in forum CustomizationReplies: 17Last Post: 04-27-2006, 10:47 PM -
4-in-1 4in1 bucket mod.
By gray in forum AttachmentsReplies: 2Last Post: 11-17-2004, 10:41 PM
