Page 3 of 8 FirstFirst 123456 ... LastLast
Results 21 to 30 of 75
  1. #21
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,159
    Branson, Mo.
    Kioti DK35se Hydrostat
    Default Re: 12v Rocker Switch
    Roger, are you still there? ( I chugged down 2 glasses of wine, and I don't usually drink.. wheww!!) You do understand the 3rd connection is to light up the little LED inside the switch, you put a ground connection there.
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  2. #22
    Join Date
    Jun 2009
    Posts
    28,159
    Branson, Mo.
    Quote Originally Posted by k0ua View Post
    How about this one it looks like the dorman and mounts in a .48 inch hole. and sells for $2.20
    12V ROCKER SWITCH W/ AMBER LED | AllElectronics.com
    James K0UA
  3. #23
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    No, the 3rd wire is ground to light the LED. notice it is thinner.. Hey the wife has come with wine and cheese and cracker... um you are on your own for a while.. sorry.
    Yeah your right. I left for a while, I had to put the tractors in and do a few things. I am back for a while now.
  4. #24
    Join Date
    Jun 2009
    Posts
    28,159
    Branson, Mo.
    Quote Originally Posted by 94BULLITT View Post
    did you see the one just above your post? It is like the dorman, mounts in a .48 hole and is lighted. all for $2.20.. not too bad.
    James K0UA
  5. #25
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Thanks for your help. No I missed it. I need to check a little further before I order a switch to be sure my idea is going to work. If this idea does not work I may go with one inline switch.
  6. #26
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    What is your idea? Let us help, sounds fun.
    Murph
  7. #27
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    I just found something pretty cool. Oracle LED Lighting in Line Controller Dynamic Brightness and Speed Switch | eBayThe only problem is it may not hold up well on a tractor.
    Quote Originally Posted by murphy1244 View Post
    Okay. I have 2 led lights (may get a 3rd for the rear) I am going to put on the BX. I hate drilling holes in stuff. I know you can buy those regular tractor worklights with a switch but I have never found a LED like that. I was going to take mine apart and put a switch in the back of them. But now I just found that cool in line switch.
  8. #28
    Join Date
    Jun 2009
    Posts
    28,159
    Branson, Mo.
    Well it is unique, I have never seen anything quite like that.
    James K0UA
    James K0UA
  9. #29
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    James K0UA
    Don't like it?
  10. #30
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Sounds like what you were looking for. How big are the controls.
    Murph
Similar Threads
  1. 4-1 FEL Circuit Rocker Switch is Possibly Bad
    By sfloggie in forum Owning/Operating
    Last Post: 11-09-2010, 07:03 PM
  2. 4-1 FEL Circuit Rocker Switch is Possibly Bad
    By sfloggie in forum Parts/Repairs
    Last Post: 11-09-2010, 06:30 PM
  3. dash mount rocker switch for winch
    By bk94 in forum ATVs & Utility Vehicles
    Last Post: 08-28-2010, 11:23 PM
  4. JoyStick Knob w/12V Momentary Switch
    By Scotty370 in forum Hydraulics
    Last Post: 04-12-2009, 03:33 PM
  5. Part number for rocker switch on TN
    By Robert_in_NY in forum New Holland Owning/Operating
    Last Post: 07-28-2004, 04:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
