Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Join Date
    Jan 2013
    Posts
    52
    Atlantic Canada
    Massey Ferguson 184-4
    Default Cab Heating Options
    What do you think is the best heating option for a cab? I have a homemade cab, but it is uninsulated. If I had to insulate it, what is the best way? I don't know how much power I have to run a heater, so whatever is most energy efficient would be best. Whats your opinion?
  2. #2
    Super Member
    Join Date
    Apr 2000
    Posts
    6,579
    central New York
    all makes and models
    Default Re: Cab Heating Options
    The battery power to run an electric is short on most tractors and the amount of heat is far less then desireable. Go with the cooling system and you will be fine.
  3. #3
    Veteran Member chim's Avatar
    Join Date
    Apr 2002
    Posts
    2,343
    Lancaster County, PA
    Kubota L3200, Ford 1210
    I bought a heater that runs on the engine coolant. An electric heater sized to match the advertised output of 20,000 BTU's would take approximately 488 amps at 12 volts if I did all the conversions correctly.
    Cost was only around $150 and it was a snap to get into the lines at the t-stat bypass. There is a small rubber hose 90 degree bypass fitting with a 5/8" connection on one end and something smaller on the other. It worked well to leave the 90 connected to the block and spin it around and use a double ended 5/8" coupling for the one hose to the heater. The other 5/8" heater hose is connected to where the 90 was disconnected. Since flow needs to be maintained through the bypass, I installed a bypass line with valve in the cab below the heater. If it gets too warm I can close the heater valves and open the bypass valve. Google "AH454 heater" if you want to see who sells them in your area.
    I'm still anxious for a blizzard to give it a real test drive. The best test so far was one night when the temp went down to 17*F. After a little running around the cab was comfy with the two-speed blower on low. The picture shows the heater sitting roughly in its final resting place during the cab build.
    Cab Heating Options-27-small-jpg
    For insulation I used an Armaflex material fastened with contact cement. The cab has a lot of glass and isn't completely airtight so the little bit of insulation is more for aesthetics than function. It's better looking than the back side of the sheet metal panels.
    Cab Heating Options-inside-small-jpg
  4. #4
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    Go with a cooling system heater as others have said. How many cars use electric resistance heat? None that I know of.
    Any insulation will be better than no insulation, and it will help with noise control too.
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  5. #5
    Join Date
    Jan 2013
    Posts
    52
    Atlantic Canada
    Do you have any problems with your windows fogging up?
  6. #6
    Join Date
    Apr 2002
    Posts
    2,343
    Quote Originally Posted by massey184ferguson View Post
    (If that was for me) Since building the cab I don't have enough hours in it to say for sure. I haven't had any fogging so far, but I haven't been using it under the conditions that would most likely produce fog. I expect some fogging when I track snow into the cab to melt and run the humidity way up. I've read where others with cabs have installed an additional fan to blow on the windshield to keep it cleared.
  7. #7
    Gold Member jb62901's Avatar
    Join Date
    Apr 2009
    Posts
    358
    Cassopolis Mi.
    Kubota BX2360
    Had this core many years and put a 4" 12v behind it, keeps the cab 40dg warmer than outside temp.
    http://oi39.tinypic.com/2ebbcbt.jpg
    BX2360 FEL, + Tons of Attachments Many Homemade
  8. #8
    Elite Member vtsnowedin's Avatar
    Join Date
    Jul 2011
    Posts
    3,409
    central Vermont
    John Deere 5045E
    I haven't found that I need a heater in my soft cab as just being out of the wind when dressed for winter weather is enough. Plus heat comes off the center casting of the tractor once it is warm so it is often thirty degrees warmer inside the cab then it is outside. The place that sold me the soft cab does have several 12 volt heaters that plug into a cigarette lighter socket. some with fans built in that can be used to cool in summer. You might have to add a socket if your tractor doesn't have one but there is usually at least one spare fuse socket in the fuse block you can tap into.
    Tractor Cab Electric Heater with 12VDC direct battery hook-up comes with all attaching hardware for your cab enclosure, UTV, RTV or ATV
    Just an option to consider, The cooling system units will certainly crank out more heat if needed.
  9. #9
    Join Date
    Nov 2012
    Posts
    1,530
    mansfield,Il
    john deere
    As far as insulation , look at FEHR cab , They refit older cabs and it is a nice product . You can get a roll of it and cut your own panels . They will send adhesive with it . Very nice product . I did a cozy cab on my snow plowing tractor with this material , worked great .
  10. #10
    Gold Member Jaylegger's Avatar
    Join Date
    Oct 2009
    Posts
    459
    Massey Ferguson GC2600L
    Another option could be something like the Coleman Golfcat 3000 btu heater found here:
    Amazon.com: Coleman GolfCat Perfectemp Catalytic Propane Heater: Sports & Outdoors
    You'd likely have to fashion an appropriately size cupholder (pvc pipe would work) and affix it to the cab frame but by all accounts they work quite well.
    Nightime snowblowing in rain.
    http://www.youtube.com/watch?v=yp50hn8lHf8
    _______________________
    MF2360 Front Snow-blower, 60" MF2340 front blade/Hydraulic angle, Woods BH6000 backhoe, Land-Pride GS1548 Grader/Scraper, 54" 2315 Mulch Mower, DL100 Loader
Similar Threads
  1. 2006 F-250 diesel cab heating problem
    By Robert_in_NY in forum Related Topics
    Last Post: 04-14-2012, 08:46 PM
  2. PT1430 engine cooling/cab heating
    By Badback in forum Power Trac
    Last Post: 05-18-2011, 04:16 PM
  3. Portable heating options.
    By N80 in forum Rural Living
    Last Post: 12-27-2009, 11:30 AM
  4. Northeast Heating Options
    By JDGREEN4ME in forum Rural Living
    Last Post: 11-17-2007, 05:16 PM
  5. L series cab heating and air
    By DUMBDOG in forum Kubota Owning/Operating
    Last Post: 04-19-2007, 10:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
