Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
  1. #21
    3v0
    3v0 is offline
    Gold Member 3v0's Avatar
    Join Date
    Jan 2013
    Posts
    446
    Oklahoma Pan Handle, United States
    Kubota BX2200
    Default Re: Calculated lost loader lift capacity with quick attach.
    Quote Originally Posted by puckgrinder85 View Post
    I havnt noticed any real decrease in capacity.
    This made me think.
    So far the heaviest thing I tried to lift was a tree stump with root ball. The rear of the BX2200 came off the ground and leaned to one side as the front axle pivoted. Yeah what a feeling! But I did not have the box blade on the back that i normally use for weight.
    So far I am liking the tach-n-go system.
  2. #22
    Bronze Member Tchara's Avatar
    Join Date
    Feb 2013
    Posts
    77
    Temple, TX
    Branson 3520R
    I just bought a 3520R Branson, and had the FEL upgraded to a westendorf 170. The specs on the westendorf brochure stated it is compatible for tractors 20-80 Hp.
    I upgraded the FEL because the OEM loader would not raise high enough to load my 8ft dump truck. One of the reasons for buying the tractor. I have heard about filling the back tires with water to prevent tipping. I'll have a boxblade attached to the back.How much counter wieght should I use?
  3. #23
    3v0
    3v0 is offline
    Join Date
    Jan 2013
    Posts
    446
    Kubota BX2200
    Unless somebody has that loader on that tractor all we can do is guess. Because the upgrade loader lifts higher it must have the load further ahead of the front wheels. That requires more weight on the back
    You can figure it out. If you have a drive on scale you can use try this. Park the tractor with the loader just off the ground and the rear wheels only on the scale and get a reading. Then add a know amount of weight, say 100 lbs, in the loader bucket and weight the back wheels again.
    Subtract the second weight from the first. This number will tell you how much lighter the rear of the tractor gets for each 100 lbs of weight in the loader bucket. Knowing that and your loader capacity you can figure out what you need.
  4. #24
    Gold Member
    Join Date
    Oct 2010
    Posts
    322
    08 Cub Ex3200
    Quote Originally Posted by 3v0 View Post
    This made me think.
    Well heres the one caveat with that: If you're constantly using the lift capacity of your tractor, you likely need a larger tractor to suit your needs.
    I've tried lifting certain things and plowing snow, I havnt noticed much difference, nothing noteable by the seat of the pants. However, I built my own quick attach and my pins are a mere 3-4 inches out further (maybe) away from the originals. Surely every aspect of the loader got weaker but again, nothing for me to worry about because I rarely use the full lift capacity of the tractor. Sure I pop the pressure relief when lifting but if i do, its too much for the tractor, pretty simple.
  5. #25
    Join Date
    Nov 2010
    Posts
    116
    Waukesha Co, WI
    1986 Ford/NH 1520, 2010 Kubota BX2430, 1950 Allis Chalmers WD, 2001 NH EC35 (track hoe)
    Default
    I have a BX and thought the same, so I bought a tractor that has 3x the lift capacity and still run with it maxed out. I equate it to a barn - no matter how big it is I will always find a way to fill it to the point I "need" a bigger one. At some point, I will probably get a bigger tractor to do more, but I don't think it will be big enough either.
  6. #26
    Join Date
    Apr 2012
    Posts
    640
    pa
    kubota 7040sud
    i been there had an l3800 traded up to a 70hp still a little small on the fel
  7. #27
    Super Member JerryG's Avatar
    Join Date
    Apr 2000
    Posts
    7,090
    Northwest Arkansas
    MF 1440-4 PowerShuttle
    A little late. I have seen front wheels centers broken out (had tight lug nuts). I have also saw spindles and front axle saddles broken. These have always been on tractors with loaders.
  8. #28
    Join Date
    Jan 2006
    Posts
    166
    Jerry -
    Agreed, broken spindles are not that uncommon and while they can be caused by metal fatigue, they are often caused by shock load. While a few might call this a design defect, most would cause it abuse of the machine by heavily overloading the loader, or in the case of one Case tractor I saw that had *massive* spindles, etc., the guy drove it over a concrete drainage ditch at full speed. There was no defect in the metal of that tractor, and it was heavily over-engineered. It was a DO error (dumb operator).
  9. #29
    Join Date
    Apr 2000
    Posts
    7,090
    Northwest Arkansas
    Several damaged parts such as these can be broken by metal fatigue or by shock load. A shock load can even be the last straw that finished them off. There are many problems caused by DO syndrome.
  10. #30
    3v0
    3v0 is offline
    Join Date
    Jan 2013
    Posts
    446
    Kubota BX2200
    Another or different tractor in not in the picture any time soon if ever. I know the BX will never lift the stack of sheet rock out in the garage. That is asking it to do something it was never designed for. A tractor big enough to do that would too big for most everything else so the BX still looks good.
    Does anyone know what a BX esp a BX2200 loader bucket weighs. The myTractorTools.com fixed forks are said to be about 170 lbs and the tach-n-go are at 50 lbs.
    The only info I have found on the LA211 lift capacity is 450 lbs at full height.
Similar Threads
  1. Quick Hitches Does Quick Hitches Compromise Lift Capacity?
    By eastexan in forum Attachments
    Last Post: 05-21-2011, 10:55 PM
  2. Quick lift capacity question
    By Piston in forum Owning/Operating
    Last Post: 01-08-2011, 08:52 AM
  3. Lifting Capacity of the Front Mount Quick Attach
    By niedejb in forum Kubota Owning/Operating
    Last Post: 03-10-2010, 05:51 AM
  4. Your Loader Lift Capacity....More?
    By jgbanshee in forum Owning/Operating
    Last Post: 01-12-2008, 10:55 PM
  5. JD 300X/C loader quick attach loader arm brackets
    By BloomingtonMike in forum John Deere Owning/Operating
    Last Post: 03-22-2006, 08:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
