Results 21 to 30 of 65
02-03-2013, 03:53 PM #21Silver Member
- Join Date
- Aug 2012
- Posts
- 156
- Location
- In a city in a state
- Tractor
- Kubota B3200
Re: Educate me on beefing up the FEL bucket to add hooks
2012 Kubota B3200 FEL/BH w thumb R4
02-03-2013, 04:04 PM #22
Putting angle on the front, like in the second picture, won't give you much additional strength. Even if you completely face welded them together. You put it on the back side to make a tube. The idea is to put the width in line with the direction of pull, and then put something at a 90 degree angle to keep it from twisting. Think I-beam or angle iron.
Don't poo poo the bolt on hooks just because you have a welder. They are used because they don't weaken the area they are mounted to. If you are worried about them loosening, spot weld the nut.
02-03-2013, 04:23 PM #23Gold Member
- Join Date
- Oct 2010
- Posts
- 322
- Tractor
- 08 Cub Ex3200
Thats what I would do as well and was my first thought when I saw the pictures. I would overhang the angle too past your hooks a decent distance if you dont plan on going all the way to spread out the weight/ twisting forces. The angle on the front of the lip could still tear and peel up the rounded bend, at least if the angle is on the backside its helping out the front lip by spreading the stress out.
Ps- the bucket looks pretty stout, if it were me I would think you could just gusset the top lip to the bucket top in the area of the hook placement, but that my opinion.
02-03-2013, 05:23 PM #24Elite Member
- Join Date
- Jan 2009
- Posts
- 2,697
- Location
- Figuring the picking points of jelly donuts.
- Tractor
- John Deere, 4200
You two have a really good point. I wonder about using two pieces of angle iron one front and back. But the back one would have to be structural angle where one leg is longer than the other. That way he could get a weld down on the back of the bucket. Or weld a piece of flatbar to the toe of the angle iron so the flatbar could be welded to the back of the bucket. Make your own C-channel with one long leg.
02-03-2013, 06:49 PM #25
I welded some 3/8 stock on top and underside lip of my bucket, then welded on the hooks and a 2-5/16 ball.
currently own
2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
Quick Attach 79" loader mount snowblower & rear powerpack
Quick Attach 84" Snow Blade
Quick Attach 42" pallet forks
02-03-2013, 09:45 PM #26Elite Member
Advertiser
- Join Date
- Mar 2005
- Posts
- 5,876
- Location
- 4000\' mountains of Southern California
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
I think that someone has already said this, but keep in mind that this is a tractor that will lift 1065lbs at the pivot and 730lbs at just under 20inches out. Just how strong does it need to be? It's not like we are talking about an M model here. I know that it needs to be done right, but I would be considering the actual capacity of the loader for what really needs to be done.
just my
02-03-2013, 10:32 PM #27
Not wanting to hijack the thread here but wanted to know how you like the piranha toothbar?
Tom
02-04-2013, 06:18 AM #28
John Deere 4110HST
FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
John Deere 4x2 Turf Gator
View some of my projects/adventures in my Picasa Album
Simple JDParts Tutorial HERE
02-04-2013, 06:26 AM #29
That's why I didn't get too carried away with my bracing. Welding the flat bar between the rear lip and the back of the bucket formed a box section of steel, and that's strong enough for anything I'll do with it.
Most of us over-build things, I've been doing it for so long now that I have to tell myself "You really aren't building a bridge here.."
I find that the Kubota buckets are built pretty strongly to begin with.
Sean
02-04-2013, 05:31 PM #30Silver Member
- Join Date
- Aug 2012
- Posts
- 156
- Location
- Tractor
- Kubota B3200
Similar Threads
FEL bucket hooks
By RyGuy24 in forum CustomizationReplies: 5Last Post: 04-19-2012, 11:36 AM -
Loader Add Chain Hooks on FEL Bucket
By Mybota3400 in forum Kubota Owning/OperatingReplies: 12Last Post: 12-23-2010, 01:20 AM -
Bucket Hooks best uses for FEL bucket hooks?
By donn12 in forum AttachmentsReplies: 12Last Post: 01-08-2009, 11:39 PM -
FEL Bucket Hooks
By cisunix in forum CustomizationReplies: 41Last Post: 03-29-2006, 12:21 PM -
FEL Bucket Hooks
By Anonymous Poster in forum Kubota Owning/OperatingReplies: 13Last Post: 03-23-2001, 02:35 PM
