Results 1 to 9 of 9
02-02-2013, 05:24 PM #1Silver Member
- Join Date
- Sep 2010
- Posts
- 248
- Location
- Western, NY
- Tractor
- Bolens (Iseki) H1502; LS R3039
Idiot Light
Since my driveway is short, and has a bunch of road frontage (not to mention a 55mph road), I felt it best to mount a Idiot Light on my tractor. Can be thought as me being an idiot in the road, or me trying to avoid idiots on the road, your choice!
I wanted it to be semi protected when the ROPS was up, so it hangs underneath. I extended the mounting forward, to make side visibility better. I have the wires set up appropriately to allow the ROPS to fold down still too, as i need it dropped to fit in the shed.
I have yet to wire it up fully, need to decide on a switch, and find warmer dryer weather to lay underneath to run the wires. (wired to my booster pack to show it working)
02-02-2013, 08:44 PM #2
Re: Idiot Light
Looks good!!!
Kyle - CompactTractorFan
Kubota BX25 w/R4's (23 hp, 17.7 PTO hp), Loader, Backhoe, 60" Mid Mount Mower, Cyclone Rake Z-10 Lawn Vacuum, CountyLine Carryall, Ferris 48" Walk-Behind Mower, Honda 21" Walk-Behind Mower, Mighty Mac 4" Chipper/Shredder,
2000 Dodge Intrepid, 2012 Ford F-150 EcoBoost
02-02-2013, 08:52 PM #3
Re: Idiot Light
I agree, it looks good. But with the light upside down like that, won't all the blinker fluid run out?
As to a switch, I went to Advance Auto and picked up a 20 or 30 amp toggle switch and wired directly to the battery with an inline fuse. I mounted the switch under the hood to keep it out of the weather, and to keep visiting chidren from turning it on and running my battery dead. Raising the hood to turn it on doesn't bother me, cause I gotta check the oil and antifreeze anyway.
Don
MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
02-02-2013, 08:58 PM #4Silver Member
- Join Date
- Sep 2010
- Posts
- 248
- Location
- Western, NY
- Tractor
Re: Idiot Light
I have one spot I am considering putting the switch in the dash - It will most likely get wired to the battery via relay, and power feed to the switch from the key.
The hood on this is not 'convenient' enough to hide a switch under there - loader has to be up, and the front 'brush guard' folded down to open the hood.
02-02-2013, 09:05 PM #5
Re: Idiot Light
Don
02-04-2013, 08:31 PM #6
Re: Idiot Light
I mounted 3 switches on my tractor and just put a rubber cover for the switches to "water proof" them. They just slide on over the toggle and have a molded in nut that screws on over the mounting nut. I got them at TSC and I know that Surplus Center has them also. the one switch is mounted in the dash so no snow or rain gets to it. the other two are mounted on a bracket I fabed up and are exposed to the elements but I have not had any problems to date!
02-05-2013, 09:21 AM #7
Re: Idiot Light
Will the existing rear light circuits have enough capacity for the new light? If so everything you need is already there!
If a dedicated circuit is required use an ordinary outdoor 120/240 volt electrical box with switch clamped to the roll bar. You could run the wires in plastic conduit with the area that must bend covered with the slip on auto type covers or even just a piece of flexible tubing. .
Egon
50 years behind the times
Livin in a
Worn out skin bag filled with rattlin bones
02-05-2013, 10:00 AM #8
02-07-2013, 04:09 PM #9
Similar Threads
idiot light blinking
By ket1954 in forum YanmarReplies: 10Last Post: 12-08-2011, 10:58 AM -
Idiot light
By MLD in forum Owning/OperatingReplies: 112Last Post: 10-09-2008, 09:36 AM -
Idiot Light replacement
By CAT1 in forum YanmarReplies: 7Last Post: 07-04-2004, 06:49 PM -
idiot light
By Anonymous Poster in forum YanmarReplies: 8Last Post: 06-28-2003, 11:34 PM -
Idiot light came on
By msuttner in forum YanmarReplies: 3Last Post: 06-25-2003, 01:51 PM
