Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
  1. #11
    Gold Member Piperflyer's Avatar
    Join Date
    Dec 2006
    Posts
    254
    USA
    Kubota3030HST
    Default Re: Building a "man lift / work platform" for FEL. Opinions wanted. thanks
    Quote Originally Posted by nybirdman View Post
    Add a safety belt ,either way.
    I would make sure of an strong enough attachment point for a safety harness also and make sure your wearing one. I have seen what happens when worers have been thrown out of lifts.
    'Life's Journey is not to arrive at the grave safely in a
    well preserved body, but rather to skid in sideways, totally worn out, shouting, 'Holy S... What a Ride!!
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #12
    Join Date
    Jun 2012
    Posts
    740
    Mt Crawford Va
    massey GC 2400 JD LA 145
    I built one for the builder I worked for that had rails made of 2in metal conduit. Very light but good and strong. made the front rail removable and a gate on each end that was removable so it could be used as a big platform with only a back rail. If you are going to mount it to the forks "square" tubing works well. We made the floor out of 3/4 advantec that stuff just does not come apart, we used it for sub floor in the houses we built.
  4. #13
    Veteran Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    2,113
    South West MI
    John Deere 2030, John Deere 6415
    I would make the top rail 42" high.
    I would make a 6" high "kick plate" all the way around the bottom to prevent a foot from slipping out.
    I would NOT make it pallet fork mounted. Forks could protrude out the front and damage something the tractor operator does not see.
    I you have a door, make it so it can ONLY open IN, NOT out.
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  5. #14
    Join Date
    Jul 2007
    Posts
    150
    Shalersville,Ohio
    2011 Kubota L3240DT
    Quote Originally Posted by Zebrafive View Post
    All good sugestions. Sounds like the one we use at work. I've been up 50'. You should have a top rail at 42" a mid rail and a toe kick. The ones we use have tabs out the back to put a pin through to lock it to the forks, that is when the operator remembers .
    Jeff
    2011 Kubota L3240DT
    724 SSQA loader
    513 JD brushhog
    6.5' Meyers Snow Plow
    Loader Mounted Boom Pole
    Loaded Rear Tires
  6. #15
    Veteran Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    2,268
    Southern VT
    '10 Kioti DK 40se/hst
    Excellent idea! Definitely want a high railing because of the tractors ability to dump the forks accidentally, which in turn could dump the manlift's cargo, ie. your worker(s). You could go either way, forks mounted lift or QA plate attached to your loader arms.
    Could you take a stock scaffold and re-work it to your needs? Or something similar as a base to start with?
    2010 DK-40se/hst, Kioti KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower, 72" Ratchet Rake. HLA Series 2000 7' snowplow, Aquiline MPC Rear chains. Diamondplate aluminum canopy. Fit Rite Top-N Tilt hydraulics.
    Scag Wildcat: Kawasaki 26HP.
    Bunch of STIHL chainsaws : 011, MS192T, MS200T, MS180C, MS230, MS270(Wood Boss), 038 Farmboss (1986 Anniversary edition).
  7. #16
    Platinum Member Rustyiron's Avatar
    Join Date
    Mar 2011
    Posts
    801
    Lakes Region, Maine
    M 9540 Kubota
    Quote Originally Posted by Piperflyer View Post
    I used to tell my guy's that if they fell, on the way down, they were fired. And when they hit the ground, they were trespassing
    I built a lift that fit on the forks, this way they were much more universal and a natural for a telehandler. I made the platform @ 4' above the ground for extra height and it was able to give a worker about a 12' "reach" while sitting on the ground (no tractor) The platform is about 4x12, all structural steel. It has a "cradle" on the back to hold lumber or tools. The front side (away from the tractor) will open up completely, like for working on a wall or setting windows & doors. Sorry, the pics are not that great.
    Attached Thumbnails Attached Thumbnails Building a "man lift / work platform" for FEL.  Opinions wanted.  thanks-dsc00433.jpg   Building a "man lift / work platform" for FEL.  Opinions wanted.  thanks-dsc00385.jpg
    We need more people to WORK for a living and less people to VOTE for a living!
    (proven on 11/6/12)
  8. #17
    Gold Member
    Join Date
    Sep 2008
    Posts
    448
    North East TX
    Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
    I
    Excellent Idea I had not considered. thanks
  9. #18
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    Here's mine. No door, kept it simple.
    Just built out of scraps so dimensions came out to what ever.
    ::Sent from a standard desktop keyboard::
    My Photobucket
  10. #19
    Veteran Member chopped's Avatar
    Join Date
    Dec 2008
    Posts
    1,312
    New England yankeee
    Building a "man lift / work platform" for FEL.  Opinions wanted.  thanks-img_0859.jpgBuilding a "man lift / work platform" for FEL.  Opinions wanted.  thanks-img_0860.jpgBuilding a "man lift / work platform" for FEL.  Opinions wanted.  thanks-img_0861.jpg
    This mine. used metal and cost was about 8 dollars overall....even used some heavy angle iron at a 45 degree angle for the QA to 'hang' on and then rebar for the hole to take the pins on the bottom.I have already used it as a ''bucket'' to move washer and dryer. (lightweight stuff like that)..So if you have no/or removable from rail then you and double the use.
  11. #20
    Super Member
    Join Date
    Feb 2008
    Posts
    7,869
    somewhere usa
    stuff
    Here one I built for my 110tlb it is used with my pallet forks. The floor is a standard 7' scaffold board and can be raised to the top if needed. I also have a set of drop in top rails for the hier positions if needed. It does bolt to the pallet fork backstop to prevent it from sliding off the forks.
    While these manlifts are handy they are a liability issue too, sure need to be careful when using them.
    Attached Thumbnails Attached Thumbnails Building a "man lift / work platform" for FEL.  Opinions wanted.  thanks-platform-forks-2-003.jpg   Building a "man lift / work platform" for FEL.  Opinions wanted.  thanks-platform-forks-2-001.jpg
Similar Threads
  1. Buying Advice 60" FEL bucket on B3200/B3300 is "light duty"??
    By jim_wilson in forum Kubota Buying/Pricing
    Last Post: 05-15-2012, 10:56 PM
  2. Finished my man lift platform.
    By brewdog in forum Build-It Yourself
    Last Post: 09-18-2011, 09:17 AM
  3. Building SS Quick attach latch "HELP WANTED"
    By ktm010 in forum Build-It Yourself
    Last Post: 03-16-2011, 06:22 PM
  4. Replies: 0
    Last Post: 02-08-2011, 01:46 PM
  5. will "303" work as a "UDT"
    By tsterkel in forum Oil, Fuel & Lubricants
    Last Post: 09-04-2009, 08:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
