Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Gold Member Hay Dude's Avatar
    Join Date
    Aug 2012
    Posts
    326
    Delaware Valley
    McCormick, JCB, Kubota
    Default Beacon on roof?
    kubota doesnt seem to offer a roof mount beacon option for M series tractors.
    Suction cup doesnt give me confidence.
    I thought about gluing a piece of galvanized metal to the roof and buying a magnetic base beacon.
    Anyone else know of a mounting system or better way?
    I assume coiled cord just gets plugged into cig lighter socket, but would like to have factory kubota lighted rocker switch in one of the blank spaces.
    M series Kubota MFWD tractors. JCB Fastrac New Holland PT & Pottinger front mount discbines. NH round hay balers. GM, Ford, IH, trucks.
    Hay Farmer & shipper. We grow & ship about 1,500 4x5 round bales/yr.
  2. #2
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    7,148
    north idaho
    Kioti DK45SE hst cab
    Default Re: Beacon on roof?
    for my kioti i made a simple angle iron bracket that fit on the bolts that hold the cab roof on. then i added a standard 3 wire trailer disconnect plug and ran it down to an aftermarket lighted set of rocker switches. The Whelen flashing light i bought required 2 switches.
    A similar thing should work for any type of cabbed tractor. i too shied away from suction cup. I made line so it can be easily removed from bracket for the summer.Beacon on roof?-parts-1-jpgBeacon on roof?-light-bracket-jpgBeacon on roof?-bracket-finish-1-jpgBeacon on roof?-mounted-1-jpgBeacon on roof?-running-1-jpgBeacon on roof?-switches-1-jpg
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  3. #3
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,377
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    I used a piece of galvanized fastened to the roof with silicone calk on our BX2660. Works well to hold a magnetic beacon on the roof (as long as you dont drive under a branch).
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  4. #4
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    yek.. rtv caulk makes a good bond that CAN be removed without damage to the panel....
  5. #5
    Elite Member 4shorts's Avatar
    Join Date
    Jul 2008
    Posts
    3,253
    Bay Roberts, Newfoundland
    Kubota 5740,BX25D
    I've fabricated a coupe of roof bars for my top light. I guess its not considered a beacon but one could be attached the same way. One I built for the kubota 4240 and another for the Kubota 5740. It is bolted to the existing bolts on the cab ans my wiring is ran down inside the cab. Works well for me.
    ...Excellence is not a skill. It is an attitude...
    Check us out on the web at www.specialtyrepairscustommods.com
    YouTube Video's: http://www.youtube.com/user/7863348?feature=guide
    2011 Kubota 5740/854 FEL/L2674 Blower/Artic Angle blade with 3rd function set up,Rain Tracker Wiper system, custom built vertical exhaust,Grammer Air Ride Seat and other custom stuff
    2013 Kubota BX25D with many mods
    Kubota ZTR ZG 222 Z
    Custom Toyota Fork Lift
  6. #6
    Join Date
    Aug 2012
    Posts
    326
    Delaware Valley
    Where are you getting your lighted rocker witches from on line?
  7. #7
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    beacon.. I thought it said bacon this morning and got hungry..
  8. #8
    Super Member
    Join Date
    Aug 2004
    Posts
    6,747
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    Quote Originally Posted by Soundguy View Post
    Polyurethane caulk (Flextra is one brand) or the auto parts windshield caulk also is great stuff.
    You just can not believe what I have glued with that stuff!
  9. #9
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    now.. the urethane Windshield stuff is a bit extreme you may remove paint and fiberglass trying to get that stuff off.
  10. #10
    Join Date
    Jan 2011
    Posts
    7,148
    north idaho
    i got my lighted switches from rr yacht service. they sell lots on ebay
    rryachtserviceinc | eBay
    rryachtserviceinc
    Contura Switch on Off 2RED Lenses Spreader Lights | eBay
    currently own
Similar Threads
  1. Roof beacon on an M series
    By Builder in forum Kubota Owning/Operating
    Last Post: 03-26-2010, 08:21 PM
  2. 3000 Twenty Cab Beacon Installation
    By Chris_VA in forum John Deere Owning/Operating
    Last Post: 11-29-2009, 02:25 PM
  3. Sheet metal roof compared to shingle roof?
    By Sigarms in forum Rural Living
    Last Post: 07-12-2008, 02:27 PM
  4. Rotary Beacon
    By Shawangunk in forum New Holland Owning/Operating
    Last Post: 02-22-2004, 10:06 PM
  5. Another roof ? How do I get lichens off roof?
    By Von in forum Rural Living
    Last Post: 06-10-2002, 08:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
