Results 21 to 30 of 68
02-21-2013, 06:50 AM #21Member
- Join Date
- Nov 2012
- Posts
- 27
- Location
- Canton, GA
- Tractor
- Kubota L3200
02-21-2013, 07:28 AM #22Super Member
- Join Date
- Nov 2011
- Posts
- 6,442
- Location
- Ohio
- Tractor
- Kioti DK 40-Massey ferguson 135-Simplicity Conquest
Re: How do you store you logging/tow chain?
I keep Two 20Ft chains in my Homer box behind the seat
Murph ------------ Sent from my HP laptop
Nothing runs like a Deere when being chased by a Kioti
02-21-2013, 07:33 AM #23
I carry 3 twenty footers and 1 six footer in the top of my ballast barrel. in 6 inch PVC "containers"
James K0UA
Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. Satisfied Everlast PA160 welder owner
02-21-2013, 08:09 AM #24Member
- Join Date
- Nov 2012
- Posts
- 27
- Location
- Canton, GA
- Tractor
- Kubota L3200
02-21-2013, 08:26 AM #25
02-21-2013, 09:06 AM #26
02-21-2013, 09:17 AM #27
02-21-2013, 09:28 AM #28Elite Member
- Join Date
- Jun 2008
- Posts
- 4,735
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
I don't have need for chains all the time but when I need one, I just throw it in the floorboard of the cab up against the seat mounting. It is out of the way there and for sure wont fall off and get lost. I suppose that if I wanted to haul it all the time, I could place it behind the seat, but in doing that, I would likely eventually whack the cab glass back there and break it. Most of the time mine is stored by the door to my shop coiled up on the floor patiently waiting for me to need it for something. I have a 20 foot 5/16" and a 15 foot 3/8" that I use for tie-downs on my trailer and for dragging trees over and out. My BIL and I occasionally combine his 2 chains and mine to attach to a tree to pull it when cutting them down so they go the direction we want as most of them are hung up with each other and don't want to fall. He puts his on his bush hog and occasionally forgets that they are there. One time his chain fell into the deck hole for removing the blades and all of it ended up in the stump jumper and took some maneuvering to find the end and fish it all back out, that is after we finally found it in there. Amazing how that chain crawled in there like a snake.
2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
02-21-2013, 09:46 AM #29
I also keep a box blade on the tractor most of the time so there are two 16' and a 20' on there. I have a bigger box blade on order but more weight on the box
blade is a good thing anyway so it seems like the logical place for me. I'm going to add some things on the new box blade to make this a little neater, hopefully. Maybe even improve on my custom saw carrier.
I like some of the other solutions that people have shown here. This is a great place to learn new ideas.
02-21-2013, 09:56 AM #30
Similar Threads
Where to find roller for logging chain?
By MNBobcat in forum Build-It YourselfReplies: 8Last Post: 10-10-2009, 02:05 AM -
Logging winch drive chain lube?
By Blane in forum AttachmentsReplies: 15Last Post: 01-17-2009, 08:57 PM -
Attaching tow chain
By KTD in forum AttachmentsReplies: 15Last Post: 06-01-2006, 05:45 PM -
Source for binding/logging chain
By chuckva in forum AttachmentsReplies: 6Last Post: 04-05-2004, 01:33 PM -
tow strap or chain?
By sendero in forum Owning/OperatingReplies: 44Last Post: 07-26-2003, 06:18 PM
