Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 68
  1. #31
    Gold Member
    Join Date
    Nov 2005
    Posts
    408
    Colebrook, N.H.
    Kubota L3830HST
    Default Re: How do you store you logging/tow chain?
    How do you store you logging/tow chain?-chain-holder-001.jpgHow do you store you logging/tow chain?-chain-holder-002.jpg
    I also learned this trick here on TBN. Four inch dia. PVC bolted to the loader arm supports. I have chain in the left one and rope in the right one. Drain holes in the bottom.
    -Jim
  2. #32
    Member
    Join Date
    Apr 2008
    Posts
    45
    Western Massachusetts
    YM 276D
    Here's my multi item rack.
    Attached Thumbnails Attached Thumbnails How do you store you logging/tow chain?-img_2050.jpg
  3. #33
    Silver Member flyerdan's Avatar
    Join Date
    Aug 2011
    Posts
    212
    Salem, OR
    Hyster H50
    I've got a tray right on the front of the forklift for chains, and a trailer ball and hook for the holes in the fork tips. Keeps everything handy and out of the way. A while back I bought a bunch of ammo cans, both .30 and .50 from a surplus place, the 30's work great for keeping a chain and ratchet straps for behind the seat in the pickup. Not only does it keep everything together and untangled, having handles you can grab them and go if you need to change vehicles for some reason.
    Anxiously awaiting Dr. Savage's return to the airwaves.
  4. #34
    Super Member k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    7,731
    Branson, Mo.
    Kioti DK35se Hydrostat
    Quote Originally Posted by Buty View Post
    Any pics of that? Sounds interesting.
    Unfortunately I don't have any good pix but I will show what I have.. The ground is covered with ice right now, and sliding down the hill to the barn does not sound like much fun. The first is of course the tractor and ballast barrel overall. The second shows the level of the concrete inside, and you can just see the tops of the chain organizer pipes I put in. They are just some scrap 6 inch or so PVC pipe about 9 inches long bolted in by the same bolts that hold the hooks on the side on. I can only get one chain in each, and the third one just lays on the concrete of the ballast barrel. Also on the barrel are three 2 inch pvc pipes for handle tools (rakes, shovels, brooms etc.). On the back is the 2 inch receiver tube, which I use for my sprayer. I have about $100 in the whole thing, including the barrel. the last pix is an old one before I put the chain organizers in the barrel taken in 2010.
    James K0UA
    Attached Thumbnails Attached Thumbnails How do you store you logging/tow chain?-090812-004.jpg   How do you store you logging/tow chain?-090812-004-noted.jpg   How do you store you logging/tow chain?-dscf0422.jpg   How do you store you logging/tow chain?-dscf0321.jpg
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. Satisfied Everlast PA160 welder owner
  5. #35
    Gold Member sd455dan's Avatar
    Join Date
    Oct 2012
    Posts
    322
    North Idaho
    Ford 3000-Rhino 554,Co-Op ,Honda ,Gilson riding mowers
    I like to have my chain with me at all times but haven't found a good place to put it on my tractor. How do you deal with this? Thanks.
    When I got this tractor it was missing the front cross brace for the Koyker loader so I incorporated this steel box to hold chains. works ok. Also it helps to have holes in the bottom for drainage...How do you store you logging/tow chain?-rhino-picking-up-blow-down
  6. #36
    Member
    Join Date
    Nov 2012
    Posts
    27
    Canton, GA
    Kubota L3200
    Thanks for all the input guys!
  7. #37
    Bronze Member GBOUTDOORS's Avatar
    Join Date
    Feb 2013
    Posts
    50
    S.E. Mass.
    Bx2360
    Hey wesmann is that made to slip over the rops? I like it easy on and off. Great ideas now you guys have made a ton of work for me out in the barn next good day. Thanks. :-)
  8. #38
    Veteran Member Redbug's Avatar
    Join Date
    Aug 2004
    Posts
    1,786
    Columbia, SC
    Kubota L3830HST
    Hey, don't forget me...here's mine! I have one on each side.
    Attached Thumbnails Attached Thumbnails How do you store you logging/tow chain?-tractor-chain-2-22-13   How do you store you logging/tow chain?-tractor-chain-2-22-13
    Dave
    "If your sport does not put grease, blood, or dirt under your fingernails, then it's just a game!"
  9. #39
    Join Date
    Jun 2004
    Posts
    1,315
    KY
    Kubota L3830, Ford Golden Jubilee, AC B, '39 Sears Economy, Polaris Ranger 400
    Default
    Quote Originally Posted by magicheater View Post
    I presumed that is where they are used but do you keep them there for storage?
    Yep they hang there most of the time.
    Attached Thumbnails Attached Thumbnails How do you store you logging/tow chain?-image-1740522281.jpg
  10. #40
    Silver Member Catfish Man's Avatar
    Join Date
    Feb 2012
    Posts
    172
    West Virginia
    Massey Ferguson 2615
    Ford 1715
Similar Threads
  1. Where to find roller for logging chain?
    By MNBobcat in forum Build-It Yourself
    Last Post: 10-10-2009, 02:05 AM
  2. Logging winch drive chain lube?
    By Blane in forum Attachments
    Last Post: 01-17-2009, 08:57 PM
  3. Attaching tow chain
    By KTD in forum Attachments
    Last Post: 06-01-2006, 05:45 PM
  4. Source for binding/logging chain
    By chuckva in forum Attachments
    Last Post: 04-05-2004, 01:33 PM
  5. tow strap or chain?
    By sendero in forum Owning/Operating
    Last Post: 07-26-2003, 06:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
