Page 7 of 7 FirstFirst ... 4567
Results 61 to 68 of 68
  1. #61
    New Member
    Join Date
    Mar 2012
    Posts
    14
    NW PA
    NH TC40A
    Default Re: How do you store you logging/tow chain?
    Well, DON'T leave one on the floor / floorboards. Especially don't if you're running the brush hog. Not even just for a little bit. ALSO, DON'T ask me how I came by this tidbit of knowledge!
    NOW, I use old ammo cans, attached to various points on my skidding winch or tractor. If you QA have a loader, sometimes there's a "slot" between the loader frame and the loader frame that bolts to the tractor. It works well to get some flat stock, about 8" long x 5" wide (whatever will slide into the loader frame opening), and weld a platform (to bolt an ammo can onto) at 90 degrees on one end. Slide the piece into the slot and you have a 'shelf' to bolt an ammo can to . Sorry no pics...
  2. #62
    Join Date
    Aug 2008
    Posts
    631
    Barrington, NH
    Bobcat CT230
    I'm afraid I just toss it in the FEL bucket along with the chainsaw, gas can, wedges, axe, and toolbox.
  3. #63
    Gold Member bubbacuse77's Avatar
    Join Date
    Jul 2008
    Posts
    338
    Wisconsin
    John Deere 3520, John Deere X749
    How do you store you logging/tow chain?-imag0384.jpgmany guys use ammo boxes. cheap and easy, plus they are water tight. I used a standard 5.56 can and that fits my one chain plus a little room for some pins and stuff.
    Attachment 309822
  4. #64
    Silver Member CanuckPT's Avatar
    Join Date
    Sep 2012
    Posts
    130
    West Chesterfield, NH
    2011 Kubota B3300SU
    Default
    Quote Originally Posted by jimainiac View Post
    <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=304585"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=304586"/>
    I also learned this trick here on TBN. Four inch dia. PVC bolted to the loader arm supports. I have chain in the left one and rope in the right one. Drain holes in the bottom.
    I want to see if I can make this work on my B3300SU with 504FEL. I bought materials today.
  5. #65
    Join Date
    Sep 2010
    Posts
    117
    St. Croix, Virgin Islands
    Kubota L3700SU
    I've got a two inch hitch ball bolted to my drawbar which I loop the chain around while pulling. When not in use, I loop it around the lower 3pt arms which have Pats quick hitch terminations and form a nice slot for chain. It is rare that I have need of a chain with implements attached and never with rotating machinery on the PTO.
  6. #66
    Elite Member newbury's Avatar
    Join Date
    Jan 2009
    Posts
    2,907
    From Vt, in Va, going to MS
    Kubota's - B7610, M4700
    Quote Originally Posted by Buty View Post
    I like to have my chain with me at all times but haven't found a good place to put it on my tractor. How do you deal with this? Thanks.
    Since more than half my chain usage is with my truck I stow my chains in plastic containers. I've about 14 of the Harbor Freight and Home depot 15' and 20' chains. My son had been eating which holds 2 each 15' chains. I also like Hellman's Mayonnaise 1 gallon jugs.
    The plastic doesn't rattle or scratch.
    My rides - '95 Kubota M4700, LA1001 FEL :'07 B7610, LA352 FEL, Bush Hog SBX 48 box blade, 18', new Woods BH70-X w/ 16" bucket and Woods thumb, 3pt pallet forks, Dale Phillips PHD, Jinma 8" chipper, Winco 12KW PTO generator with a 2002 7.3L Ford F350 CC DRW 4x4 and '07 Hudson HSE Deluxe trailer - 5 Ton to haul
  7. #67
    Gold Member sd455dan's Avatar
    Join Date
    Oct 2012
    Posts
    331
    North Idaho
    Ford 3000-Rhino 554,Co-Op ,Honda ,Gilson riding mowers
    Quote Originally Posted by TC 40 Chuck View Post
    not sure- but are you describing How do you store you logging/tow chain?-rhino-chain-storage-001.jpg something like this?
    This tractor was missing the cross brace when I got it so when I fabbed up a cross support, cut the box in half (to fit). then drilled and tapped some mounting holes in the cross brace and bolted it all together, works well for chains, and I even leave them in there when mowing with the brush hog
  8. #68
    New Member
    Join Date
    Jan 2009
    Posts
    24
    western oregon
    currently l4400 stick
    Because of this forum I came up with my version of some one else's great idea. The upright for the loader assembly has holes in it at the bottom. I used six inch PVC thick wall pipe with a slip end cap, glued on of course. The cap has a drain hole in the bottom I drilled. Two large bolts go through the loader frame into two holes I drilled in the six inch pipe. At the top I fabricated a brace bracket out of flat stock. I am really pleased with it.
    Attached Thumbnails Attached Thumbnails How do you store you logging/tow chain?-p5070003.jpg   How do you store you logging/tow chain?-p5070006.jpg   How do you store you logging/tow chain?-p5070004.jpg
    L4400GST quick attach bucket and forks
    five ftbrush hog
    Post hole auger
    Leon rear blade
    Lx178 JD
    Husky 372s 394
    haywagons
    big horses
    Loadstar FBD
Similar Threads
  1. Where to find roller for logging chain?
    By MNBobcat in forum Build-It Yourself
    Last Post: 10-10-2009, 02:05 AM
  2. Logging winch drive chain lube?
    By Blane in forum Attachments
    Last Post: 01-17-2009, 08:57 PM
  3. Attaching tow chain
    By KTD in forum Attachments
    Last Post: 06-01-2006, 05:45 PM
  4. Source for binding/logging chain
    By chuckva in forum Attachments
    Last Post: 04-05-2004, 01:33 PM
  5. tow strap or chain?
    By sendero in forum Owning/Operating
    Last Post: 07-26-2003, 06:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
