Page 2 of 8 FirstFirst 12345 ... LastLast
Results 11 to 20 of 74
  1. #11
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,994
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Default Re: FEL, TORO Groundsmaster Put Together
    Took it to a hydraulic shop to get hoses made. Here are pictures from 8-17-2005, if you right click on the pictures, you can open them in a new tab or window, depending on your browser.
    Hoses on, it works!
    FEL, TORO Groundsmaster Put Together-p8171919-jpgFEL, TORO Groundsmaster Put Together-p8171921-jpgFEL, TORO Groundsmaster Put Together-p8171922-jpgFEL, TORO Groundsmaster Put Together-p8171924-jpgFEL, TORO Groundsmaster Put Together-p8171927-jpgFEL, TORO Groundsmaster Put Together-p8171930-jpg
  2. #12
    Join Date
    Feb 2013
    Posts
    7,994
    Meridian, OK
    8-18-2005 Made this fork carriage many years previous for an old Craftsman loader.
    Works on this one, using longer pins. I later added angle iron to support a shorter pin the normal way.
    FEL, TORO Groundsmaster Put Together-p8181939-jpgFEL, TORO Groundsmaster Put Together-p8181940-jpgFEL, TORO Groundsmaster Put Together-p8181941-jpg
    Boom pole on the forks.
    FEL, TORO Groundsmaster Put Together-p8191942-jpgFEL, TORO Groundsmaster Put Together-p8191943-jpg
  3. #13
    Join Date
    Feb 2013
    Posts
    7,994
    Meridian, OK
    9-2-2005 Wheel(less)barrow on the forks with a load for the recycle pile.
    FEL, TORO Groundsmaster Put Together-p9021950-jpgFEL, TORO Groundsmaster Put Together-p9021952-jpg
    Brinly cat 0 A Frame bolted through the holes in the forks that came with it many years ago.
    FEL, TORO Groundsmaster Put Together-p9211957-jpgFEL, TORO Groundsmaster Put Together-p9211956-jpg
    4' cat 0 box blade
    FEL, TORO Groundsmaster Put Together-pa201975-jpgFEL, TORO Groundsmaster Put Together-pa201973-jpgFEL, TORO Groundsmaster Put Together-pa201981-jpgFEL, TORO Groundsmaster Put Together-pa201979-jpgFEL, TORO Groundsmaster Put Together-pa201980-jpg
  4. #14
    Join Date
    Feb 2013
    Posts
    7,994
    Meridian, OK
    8-24-2005 Had this old tractor brushguard in my scrap pile, so I welded a piece of 2 inch square tubing to it, so that it would fit in the receiver hitch.FEL, TORO Groundsmaster Put Together-p8241944-jpgFEL, TORO Groundsmaster Put Together-p8241946-jpgFEL, TORO Groundsmaster Put Together-p8241947-jpgFEL, TORO Groundsmaster Put Together-p8241948-jpgFEL, TORO Groundsmaster Put Together-p8241949-jpg
    11-7-2005 Ten sacks of horse feed. Notice the old Craftsman Loader for sale by the fence. I was going to use it, but got this wider one.
    FEL, TORO Groundsmaster Put Together-pb071982-jpgFEL, TORO Groundsmaster Put Together-pb071983-jpgFEL, TORO Groundsmaster Put Together-pb071985-jpg
    11-10-2005
    FEL, TORO Groundsmaster Put Together-pb101989-jpgFEL, TORO Groundsmaster Put Together-pb101987-jpgFEL, TORO Groundsmaster Put Together-pb101988-jpg
    P.S. it was dry dirt!
  5. #15
    Join Date
    Feb 2013
    Posts
    7,994
    Meridian, OK
    Forking brush
    FEL, TORO Groundsmaster Put Together-p8181936-jpgFEL, TORO Groundsmaster Put Together-p8181937-jpgFEL, TORO Groundsmaster Put Together-p8181938-jpgFEL, TORO Groundsmaster Put Together-p6022156-jpgFEL, TORO Groundsmaster Put Together-p6022163-jpgFEL, TORO Groundsmaster Put Together-p6022174-jpg
    7-22-06 Removed the receiver hitch from the Toro, modified the brushguard to bolt on where the hitch was, and built a receiver hitch into the brushguard.
    FEL, TORO Groundsmaster Put Together-p7222289-jpg
    That is a 100 pound block of steel laying between the brushguard and the frame.
    FEL, TORO Groundsmaster Put Together-p7222290-jpg
    Two 100 pound tractor weights.
    FEL, TORO Groundsmaster Put Together-p7222291-jpg
    11-30-2005 Added a guard to prevent full speed forward, when it touches a tree trunk at the edge of the burn pile. Guess how I know it would do that!
    FEL, TORO Groundsmaster Put Together-pb302001-jpg
    12-11-2005 Cut a 90 conduit, put it over the cut off exhaust pipe, to keep the brushguard cleaner.
    FEL, TORO Groundsmaster Put Together-pc112015-jpgFEL, TORO Groundsmaster Put Together-pc112018-jpgFEL, TORO Groundsmaster Put Together-pc112019-jpg
  6. #16
    Join Date
    Feb 2013
    Posts
    7,994
    Meridian, OK
    This happened 8-9-2006. Was using the forks to knock the dirt off of the root ball on a willow tree that the dozer dozed. Backed up, but it didn't turn uphill, because the right front tire was almost flat (slow leak). The right front dropped into a hole, and the Toro went over, I fell off of the seat onto the side panel. The engine was still running, I had to raise up and reach under my butt to turn off the key. I was right at the edge of the water, the loader tower was in the water. I got my tractor, put a chain on the left loader arm and pulled it upright.
    Looking south from the dam.
    FEL, TORO Groundsmaster Put Together-p8092304-jpg
    Bottom view.
    FEL, TORO Groundsmaster Put Together-p8092306-jpgFEL, TORO Groundsmaster Put Together-p8092308-jpg
    Rear view.
    FEL, TORO Groundsmaster Put Together-p8092309-jpg
    Front view.
    FEL, TORO Groundsmaster Put Together-p8092310-jpg
    This is the root ball I was knocking the dirt off of.
    FEL, TORO Groundsmaster Put Together-p8092313-jpg
    Notice the 100 pound block of steel at the lower right, that fell off of the brushguard.
    FEL, TORO Groundsmaster Put Together-p8092314-jpg
    I left it chained to the tractor, got on, crossed my fingers, it started and I backed up the hill.
    The loader wasn't up very high and the hole wasn't very big, but it sure went over fast.
  7. #17
    Join Date
    Feb 2013
    Posts
    7,994
    Meridian, OK
    Another use for the forks, 5-10-2009.
    FEL, TORO Groundsmaster Put Together-p4032114-jpgFEL, TORO Groundsmaster Put Together-p4032117-jpgFEL, TORO Groundsmaster Put Together-p4092120-jpgFEL, TORO Groundsmaster Put Together-p4092121-jpg
  8. #18
    Elite Member Don87's Avatar
    Join Date
    May 2010
    Posts
    4,226
    SW Pa.
    Massey Ferguson GC2400
    That's a nice little toy, er tool. Looks very useful to have around.
    Don
    MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
  9. #19
    Join Date
    Feb 2013
    Posts
    7,994
    Meridian, OK
    Quote Originally Posted by Don87 View Post
    Thanks, it is both a toy and a tool, but not a toy tool.
    I have used it a lot, some of the dead trees in that burn pile were pulled by the MF240D, but it didn't have a loader, so the pile was made with the TORO.
  10. #20
    Platinum Member Dr Dave's Avatar
    Join Date
    Feb 2012
    Posts
    849
    sioux city, ia
    Oliver 1855, Case 1840, Cub 1550
    Cool build, how much can you lift?
Similar Threads
  1. Toro Groundsmaster for pasture maintenance?
    By QRTRHRS in forum Toro / Wheel Horse
    Last Post: 02-21-2011, 08:16 PM
  2. Toro Groundsmaster 52 or 62
    By dholly in forum Toro / Wheel Horse
    Last Post: 11-12-2010, 12:50 PM
  3. Anyone put larger rams on their bx24 FEL arm?
    By bx24 in forum Kubota Owning/Operating
    Last Post: 10-18-2008, 07:26 AM
  4. Mitsubishi In Groundsmaster!
    By Groundskeeper in forum Mitsubishi/Satoh
    Last Post: 10-16-2007, 10:23 PM
  5. FEL quick connect covers won't stay put
    By hazmat in forum New Holland Owning/Operating
    Last Post: 08-24-2004, 03:33 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
