Page 3 of 8 FirstFirst 123456 ... LastLast
Results 21 to 30 of 73
  1. #21
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,901
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Default Re: FEL, TORO Groundsmaster Put Together
    Quote Originally Posted by Dr Dave View Post
    Cool build, how much can you lift?
    I struggle with anything much over a hundred pounds.
    The biggest thing with the TORO is a log that I weighed on the platform scales at 805 pounds. It will lift 300 pounds with no extra counter weight on the back.
    640 lbs. of concrete.
    FEL, TORO Groundsmaster Put Together-p6270006-jpgFEL, TORO Groundsmaster Put Together-p6270002-jpg
    The big cottonwood tree trunk, on the brush fork. Notice one extra suitcase weight on the back.
    FEL, TORO Groundsmaster Put Together-p7240003-jpgFEL, TORO Groundsmaster Put Together-p7240006-jpgFEL, TORO Groundsmaster Put Together-p7240007-jpg
  2. #22
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    How difficult is it for you to climb on and off the rig due to the loader frame?
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  3. #23
    Join Date
    Feb 2013
    Posts
    7,901
    Meridian, OK
    Quote Originally Posted by mjncad View Post
    Not very difficult, since the seat is offset to the left side. You climb in just like a skid steer.
    If the arms are down, step on the bucket, or fork frame, grab the arms and step on the TORO frame on the right side, then grab the steering wheel and slide into the seat. If the arms are up enough to duck under, just step on the TORO frame on the right side, grab the steering wheel and slide into the seat.
    The first two pictures show the seat offset.
    FEL, TORO Groundsmaster Put Together-p6271761-jpgFEL, TORO Groundsmaster Put Together-p8171919-jpgFEL, TORO Groundsmaster Put Together-p8171931-jpgFEL, TORO Groundsmaster Put Together-p8181939-jpg
  4. #24
    Join Date
    Aug 2006
    Posts
    5,114
    A couple
    Thanks for the reply. Since the seat is slightly offset to the left, you could always try and find an old Mack DM-400/600/800 badge to add to the rig.
  5. #25
    Join Date
    Feb 2013
    Posts
    7,901
    Meridian, OK
    Yep, I remember those, with the narrow cab and the big air cleaner on the right.
  6. #26
    Join Date
    Aug 2006
    Posts
    5,114
    A couple
    The cab was the same 2-man width as the "R" series primarily meant for over the road applications; but the "DM" series had the cab offset to the left for better visibility according to Mack. Yep, they usually had a large can air cleaner on the right side, and I seem to recall the inlet was at the end of a long pipe placing it around the roof line. They were cool looking trucks.
  7. #27
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,382
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    What model was it that had the skinny cab that was offset? There is a steel company around here who runs at least one straight truck that has a skinny one man cab that is slightly offset to the left. They run long steel past the sides of the cab.
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    — Robert Heinlein, Time Enough for Love
  8. #28
    Join Date
    Aug 2006
    Posts
    5,114
    A couple
    If the cab is real boxy, it could be a CCC (Crane Carrier Corporation). Or maybe it's a modified yardbird tractor. IH had a one-man cab variant of the Loadstar back in the 70's but the cab was centered.
    If you can snap a picture, we can guess better.
  9. #29
    Join Date
    Feb 2013
    Posts
    7,901
    Meridian, OK
    Some pictures taken 6-14-2009, using the brush fork and a deckover 8 x 16 trailer.
    Loaded the trees on the trailer, then hooked on and pulled it to the brush pile, unhooked and unloaded it with the TORO.
    FEL, TORO Groundsmaster Put Together-p6140001-jpgFEL, TORO Groundsmaster Put Together-p6140004-jpgFEL, TORO Groundsmaster Put Together-p6140005-jpgFEL, TORO Groundsmaster Put Together-p6140006-jpgFEL, TORO Groundsmaster Put Together-p6140007-jpgFEL, TORO Groundsmaster Put Together-p6140010-jpg
  10. #30
    Elite Member Don87's Avatar
    Join Date
    May 2010
    Posts
    4,226
    SW Pa.
    Massey Ferguson GC2400
    Quote Originally Posted by Xfaxman View Post
    OK.............I just gotta ask.
    In every picture, you are hooked to the trailer. Watcha doin, flipping the brush over your head onto the trailer???
    Don
    MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
Similar Threads
  1. Toro Groundsmaster for pasture maintenance?
    By QRTRHRS in forum Toro / Wheel Horse
    Last Post: 02-21-2011, 08:16 PM
  2. Toro Groundsmaster 52 or 62
    By dholly in forum Toro / Wheel Horse
    Last Post: 11-12-2010, 12:50 PM
  3. Anyone put larger rams on their bx24 FEL arm?
    By bx24 in forum Kubota Owning/Operating
    Last Post: 10-18-2008, 07:26 AM
  4. Mitsubishi In Groundsmaster!
    By Groundskeeper in forum Mitsubishi/Satoh
    Last Post: 10-16-2007, 10:23 PM
  5. FEL quick connect covers won't stay put
    By hazmat in forum New Holland Owning/Operating
    Last Post: 08-24-2004, 03:33 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
