Results 1 to 6 of 6
  1. #1
    New Member LongGone2saskatchewan's Avatar
    Join Date
    Feb 2013
    Posts
    23
    Default Make a cab
    I am thinking of building a cab for my 3316 mahindra and was wondering if anyone has done it. If anyone has any plans or pics that would help alot. I'm planning on using 1inch square tubing and angle iron and probably plexiglass for windows. Would it be possible to add a/c or do I need a compressor. Thanks to anyone that can help.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    Posts
    Register now to remove this ad.
  3. #2
    Member
    Join Date
    Dec 2012
    Posts
    40
    Orillia Ontario
    50&51 8N Ford
    Default Re: Make a cab
    Welcome I've never built a cab ,just use Leather snowmobile two peice suit. But if you go to search for DIY cab there is a Mahindra cab build in the list that comes up. Welcome & good luck with your cab build. Bruce
  4. #3
    Veteran Member kiotiken's Avatar
    Join Date
    Aug 2011
    Posts
    1,798
    Dunrobin, Ont
    2012 Kioti DK45 HST Cab
    Type "cab build site:tractorbynet.com" or "DYI cab site:tractorbynet.com" etc into google.com. You'll get dozens of build threads with step by step pictures.
  5. #4
    Member
    Join Date
    Nov 2010
    Posts
    29
    Sask
    WHITE 700
    I didnt make a cab, I modified a cab from a different tractor to work. I dont have doors, but it makes all the difference in the world when blowing snow!
    And we had lots of snow this year in Saskatchewan, didnt we!
    Attached Thumbnails Attached Thumbnails Make a cab-bare-cab.jpg   Make a cab-bare-tractor.jpg   Make a cab-tractor-cab.jpg
  6. #5
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,741
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Quote Originally Posted by LongGone2saskatchewan View Post
    A factory cab takes the place of the ROPS so the frame needs to be strong enough to do that, unless of course you build around the ROPS and leave it in place. I would still make the framing of similar material as a factory cab in case of a roll over, you don't want the cab crushing in on you and spraying broken shards of plexiglass (by the way I would use automotive safety glass and not plexi as it scratches too easily). Easiest way to get a cab idea is to go to a dealer that has a cabbed tractor in the smallest size comparable to your tractor, take photos, measurements of the framing etc and scale it down to your tractor. YES you have to have a compressor to have an AC and a condenser with fan. You could perhaps find one of the after market units like they used to sell for cars, but I haven't seen one of those un years, but assume they are still available. You would have to determine if there is room on your engine to install a compressor also and likely have to fabricate a bracket to hold it. Likely the only thing you will be able to do it put in a hot water heater and make the cab doors removable for summer time work. Put in a fan for some cooling. Dad had a combine once with a cab and only a fan in it and it was not too bad, it keep the chaff off of you.
    I was looking at a aftermarket cab (LS FORUM) where someone posted a link to one site. The cab was over $5200 and didn't include AC or heat, mirrors, windshield wipers/washer, stereo, outside work lights, or turn signal lights like a factory cab has. Adding all the "accessories" brought the price to over $10,000. I now know why folks elect to build their own.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  7. #6
    Member
    Join Date
    Nov 2012
    Posts
    34
    Upstate NY
    Kubota B2710
    Surplus Center has some cabs for $600 that would be a great start. They could be modified to fit just about any compact tractor. The glass and wiper alone are worth the price.
    Surplus Center - CURTIS RED 1MF1233SS TRACTOR CAB MF 1428V 1233
Similar Threads
  1. Canopy Make a cab
    By LongGone2saskatchewan in forum Mahindra Owning/Operating
    Last Post: 02-25-2013, 06:00 PM
  2. john deere 3x20 or 4x20 cab tractor owners. Have a question about your cab seals.
    By shortthrow50 in forum John Deere Owning/Operating
    Last Post: 03-03-2012, 11:54 PM
  3. Do they make a 60HP HST Cab Model?
    By shooterm in forum Kubota Owning/Operating
    Last Post: 11-11-2010, 08:10 AM
  4. Kubota B3030HSDCC cab or John Deere 3720 cab? Please help!
    By FRIZ in forum Buying/Pricing/Comparisons
    Last Post: 07-16-2009, 04:03 PM
  5. John Deere 4720 cab vs Kubota GL5030 cab
    By Pokeboater in forum Buying/Pricing/Comparisons
    Last Post: 12-10-2008, 10:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
